VPP can't deinterlace RGB32 frames
Maximilian_W_
Hello there!
When i try to initialize VPP like this, i get the error "invalid video parameters" (MFX_ERR_INVALID_VIDEO_PARAM). This error seems to be caused by VPP output parameter "PicStruct: MFX_PICSTRUCT_PROGRESSIVE". Is it not possible to deinterlace RGB32 frames?
"Intel API Implementation: MFX_IMPL_SOFTWARE Version: 1.13"
"AsyncDepth: 0"
"NumExtParam: 0"
"IOPattern: MFX_IOPATTERN_IN_SYSTEM_MEMORY,MFX_IOPATTERN_OUT_SYSTEM_MEMORY"
"-------VPP INPUT-------"
"BitDepthLuma: 8"
"BitDepthChroma: 8"
"Shift: 0"
"FourCC: RGB4"
"Width: 1920"
"Height: 1088"
"CropX: 0"
"CropY: 0"
"CropW: 1920"
"CropH: 1080"
"FrameRateExtN: 1000000"
"FrameRateExtD: 40000"
"AspectRatioW: 0"
"AspectRatioH: 0"
"PicStruct: MFX_PICSTRUCT_FIELD_TFF"
"ChromaFormat: MFX_CHROMAFORMAT_YUV444"
"-------VPP OUTPUT-------"
"BitDepthLuma: 8"
"BitDepthChroma: 8"
"Shift: 0"
"FourCC: RGB4"
"Width: 1920"
"Height: 1088"
"CropX: 0"
"CropY: 0"
"CropW: 1920"
"CropH: 1080"
"FrameRateExtN: 10000000"
"FrameRateExtD: 400000"
"AspectRatioW: 0"
"AspectRatioH: 0"
Kind regards Max!
Surbhi_M_Intel
Hi Max,
To de-interlacing RGB32 frames, you need to set another VPP filter to do color conversion in NV12 format. The supported FOURCC format for deinterlacer is NV12 only.
I hope that answers your query.
Surbhi
