VPP - frame rate
Dmitry_Gurulev
Hi All,
Please, help me with VPP FrameRateExtN/FrameRateExtD parameters.I'll try to fill VPP struct from VIDEOINFOHEADER::AvgTimePerFrame with code like the -
vp.vpp.In.FrameRateExtN = 1000;
vp.vpp.In.FrameRateExtD = CRefTime(time_per_frame).Millisecs();
but this fails for some rates. Eg.: try 25/1 - OK, 1000/40 - OK, 30/1 - OK, 1000/33 - FAIL with MFX_ERR_INVALID_VIDEO_PARAM.
Anthony_P_Intel
Hi Dmitry, I'm not seeing any issue with VPP input frame rate of 1000/33. (I'm simply modifying the hard-coded values in the simple projects of tutorial available here: http://software.intel.com/en-us/articles/intel-media-sdk-tutorial) If you can provide a log file form the tracer tool (tools\mediasdk_tracer\tracer.exe), we might be able to see why you are seeing MFX_ERR_INVALID_VIDEO_PARAM. -Tony
Dmitry_Gurulev
Hi Tony,
You are right, the problem is not VPP issue, the cause was sometimes I've got wrong AvgTimePerFrame value. Thanks you drove me to re-test the problem.
