Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
VPP scaling - Issue with text quality
Sujata_G_
We are facing an issue with scaling. Will you please help us resolve this?
We are using VPP module of Intel Media SDK 2016 for scaling.
Sample app attached is scaling video from 720x480 to 720x576. There is no Frame rate conversion.
After scaling, quality of text in the video is not acceptable. It looks like broken.
Attaching tar file for your reference.
Attachment contains the following:
1. simple_vpp.cpp - This is sample app .
compilation command is
g++ -o ../_build/simple_vpp src/simple_vpp.cpp ../common/common_utils.cpp ../common/common_utils_linux.cpp ../common/common_vaapi.cpp ../common/cmd_options.cpp -I/usr/local/include -I../common -I/opt/intel/mediasdk/include  -L/opt/intel/mediasdk/lib/lin_x64 -lmfx -lva -lva-drm -lpthread -lrt -ldl
Usage is :
./simple_vpp -hw -g 720x480 ORG_720x480.yuv SCALED_720x576.yuv
2. ORG_720x480.yuv - Original YUV before scaling.
3. SCALED_720x576.yuv - YUV generated after scaling
The media files attached here are confidential and should not be shared.
