Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
VS2010 libmfx link error
Guilherme_L_2
I'm new in Intel Media SDK and i want to change the encode/decode system of my aplication from ffmpeg to quicksync to make some tests, so i have add the library to my project, maked a class to initialize a encode session, but it don't compile, VS2010 gives me the follow error:
error LNK2001: unresolved external symbol _MFXInit
error LNK2001: unresolved external symbol _MFXClose
error LNK2001: unresolved external symbol _MFXVideoENCODE_QueryIOSurf
error LNK2001: unresolved external symbol _MFXVideoENCODE_Init
error LNK2001: unresolved external symbol _MFXVideoENCODE_Close
error LNK2001: unresolved external symbol _MFXVideoENCODE_EncodeFrameAsync
i have compiled and run the examples, but in my project it's don't work.
I have included the sdk include directory, library directory and the .lib in the project settings.
some one can help me? Thanks
P.S.: sorry for my poor english
Petter_L_Intel
Hi Guilherme,
the link error you're getting is most certainly due to the linker not being able to find the "libmfx.lib" file. Please check you project configuration to make sure the file is named correctly and that it is located in the path you provide.
Petter
Guilherme_L_2
Hi Petter,
Thanks for the answer, but the problem was diferent and i have figured it out, i had to recompile library in the VS2010 and everything worked fine.
thank you for your time,
Guilherme
