It seems that indexing of the non-zero coefficients and sign flags is not right when a block is analyzed (H.264): in all cases the last non-zero coefficient is skipped in the analysis pane, and the other non-zero coefficients are counted in a straight forward way without skipping the non-zero coefficients as it should be according to section 7.3.5.3.3 Residual block CABAC syntax.
Here is an excerpt:
373 145 coded_block_flag 1
257 145 significant_coeff_flag[0] 1
304 291 last_significant_coeff_flag[0] 0
292 242 significant_coeff_flag[1] 1
380 181 last_significant_coeff_flag[1] 0
476 362 significant_coeff_flag[2] 0
284 56 significant_coeff_flag[3] 0
368 112 significant_coeff_flag[4] 0
402 224 significant_coeff_flag[5] 0
466 448 significant_coeff_flag[6] 1
376 305 last_significant_coeff_flag[6] 1
270 128 coeff_abs_level_minus1[2] 0 (indices below should be 6, 1, 0, but not 2,1,0)
257 128 coeff_sign_flag[2] 0
257 256 coeff_abs_level_minus1[1] 4
374 225 coeff_sign_flag[1] 1
374 76 coeff_abs_level_minus1[0] 0
504 152 coeff_sign_flag[0] 0
Appreciate your report!
I do not see any updates since November 3, 2015 (!), i.e. ~4 months.
I wonder if this bug was ever considered? It seems that even product pre-sales support people did not elevate the issue although I notified them about it.
I'll sync with the developer team and update you soon.
Regards, Jeff
According to our records, this issue was fixed in the 2.1.0 release of VPA, which is the most recent release. Please let us know if you're still seeing the issue with this version.
Jeffrey, thank you for the heads up. I hope the new release is available for download as a trial version.
