Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3058 Discussions
Whether use Opencl for Nvidia instead of Intel Media SDK
lin_z_1
Due to my computer without Intel HD Graphics, I can not install the Intel Media SDK. The Gpu of my computer is Nvidia, so I can install Opencl for Nvidia.And I want to know if I can use the Intel Media SDK and Opencl for Nvidia application together for efficient video decoding and fast post-processing. I hope the man with the rich experience in Intel Media SDK can give me a result.
Anthony_P_Intel
While you can ues software (CPU) implementation of the Intel Media SDK, hardware-accelerated implementation of the Intel Media SDK requires Intel hardware and drivers.  If your system contains both Intel and NVidia graphics accelerators, you can use both devices for acceleration if you are using Direct3D 11.1 architecture (Windows 8+), however if your want to share both devices in a single usage model you should understand the performance impact of using separate video memory.  Sharing data may require moving that data to and from high performance video memory to general system memory.
