3003 Discussions
Why every frame generated from Encoder has PPS/SPS information
zheng_s_
We design a  decoder/encoder feature using SDK, everything works fine. But when we use Wireshark to analyze each package, we realize each frame no matter Key frame or P frame all have the PPS/SPS information. how to control the encoder to generate PPS/SPS for key frame only?
Rūdolfs_B_
I'm having the same scenario, any advice on whether this can be altered?
Anthony_P_Intel
Please see the "RepeatPPS" feature in the reference manual.  The default is 'on'.
Anthony_P_Intel
I should mention that you the session should be initialized with API 1.8 or greater to change the behavior.
Rūdolfs_B_
Hi Tony,
thanks a lot, for somewhat reason I didn't notice that field in the reference manual, works like a charm.
