3003 Discussions
bit rate parameters not affect the communication performance
Oh_i_
I'm tring to control the bit rate and I tried to configure the following parameters:
while using ABVR: accuracy and convergence
and while using VBR: maxbitrate and initialdelayinkb
both doesnt affect the outcome... no matter what parameters I entered the only parameter that does it is the TargetBitKbps.
Petter_L_Intel
Please share all the encoder parameters you used. You can capture these by starting Media SDK tracer tool, starting logging the run your workload.
Petter
Oh_i_
Here are the parametrs I'm using:
CodecId = MFX_CODEC_AVC
TargetUsage = MFX_TARGETUSAGE_BALANCED
TargetKbps = 10000
RateControlMethod = MFX_RATECONTROL_VBR
if(RateControlMethod == MFX_RATECONTROL_VBR)
MAXKbps = 11000 // 10% deviation?
InitialDelayInKB = 10000 // Why is needed?
if(RateControlMethod == MFX_RATECONTROL_AVBR)
Accuracy = 10 // 10%?
Convergence = 10 // 1000 Frames?
FramRateExtN = 25
FramRateExtD = 1
FourCC = MFX_FOURCC_NV12
ChromaFromat = MFX_CHROMAFORMAT_YUV420
PicStruct = MFX_PICSTRUCT_PROGRESSIVE
Width = 192
Height = 1080
GopPicSize = 25
GopRefDist = 1
IdrInterval = 0
CodecProfile = MFX_PROFILE_AVC_MAIN
CodecLevel = 50
IOPattern = MFX_IOPATTERN_INSYSTEM_MEMORY
GopOptFlag = MFX_GOP_STRICT|MFX_GOP_CLOSED
Petter_L_Intel
I see nothing wrong with this configuration except for a few small things:
- InitialDelayInKB : You do not have to set this value. Media sDK will select suitable value for you based on the otehr selected parameters. You can leave this parameter set to 0.
- Width = 192   .   I suspect you intended to set it to 1920?
I tested your encoder configuration on my side and I see resulting average bit rate very close to the selected value.
It could be that your input content is static or have close to no movement at all. In those case the encoder will attempt to reduce the amount of encoded bits significantly, thus not meeting the specific bit rate targets.
Petter
Oh_i_
First, thanks for your replays.
I think I didnt make myself clear. the problem wasn't the average bit rate but the bit rate picks and deviation, I want to strict them to a certain limit by using MaxKbps or Accuracy, if i just wanted to set bit rate I would use CBR as my rate control method...
Example:
ABVR:
While setting accuracy to 10 (is it 10%, because on manual it says somthing about tenth percent?) and convergence to 10, I expect to see max bit rate value of 11000Kbps after 1000 frames - and I don't.
Same for the other option (VBR):
While setting the MaxKbps to 11000, I expect to see no pick above that after a while, and no.
The scene is a regular scene, not too static and not too jumpy, HD camera...
By the way (I), what's more important, communication wise, the maximal bit rate values or the average (median?)?
By the way (II), I noticed that if I freeze the scene, meaning, repeat the same frame for a while, the encoder goes crazy after a while, and it takes few GOPs to recover and put back a good image, do you know any thing about it? (maybe I should open a new thread for that issue?)
Petter_L_Intel
The bitrate control parameters does not impose as strict control on per frame bit rate as may desired.
AVBR Accuracy parameter is specified in units or 1/10% so if you want 10% deviation the you should set the value to 100.  Convergent is specific in units of 100 so to set 1000 convergence window please set the value to 10.
Note that even if the range is specified (should be thought of as an average over the specified convergence window) there is no guarantee that individual frames size has to stay within the window. I frame or large motion may result in spikes and thus also requiring following frames to reduce it's average size to stay within the budgeted # of bits.
There are some features of the SDK to help reduce the frame size variance, such as mfxExtCodingOption2::MaxFrameSize and IntRefType (Intra-refresh aka. rolling I-frame).
We are not aware of any static scene issues. Please make sure you use a recent graphics driver.
Petter
Oh_i_
Thanks for your replay, as I thought...
can you please give some more details about maxFrameSize option?
Petter_L_Intel
Hi Oh,
MaxFrameSize is described in the Media SDK reference manual.
Petter
