Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
bug in sample encode
nadav
I think there's a bug in SDK 2013 R2 samples.
in sample_encode if i use -nv12 in command line - i get wrong output.
it seems that the bug is in CSmplYUVReader::LoadNextFrame for ColorFormat MFX_FOURCC_NV12 when loading  U, V planes.
i've changed the following code:
case MFX_FOURCC_NV12:
h /= 2;
ptr = pData->UV + pInfo->CropX + (pInfo->CropY / 2) * pitch;
for(i = 0; i < h; i++)
if (!m_bIsMultiView)
nBytesRead = (mfxU32)fread(ptr + i * pitch, 1, w, m_fSource);
else
nBytesRead = (mfxU32)fread(ptr + i * pitch, 1, w, m_fSourceMVC[vid]);
if (w != nBytesRead)
return MFX_ERR_MORE_DATA;
break;
 to the code from older simple_encode sample:
mfxU8 buf[2048]; // maximum supported chroma width for nv12
w /= 2;
h /= 2;
if (w > 2048)
return MFX_ERR_UNSUPPORTED;
// load U
mfxStatus sts;
sts = ReadPlaneData(w, h, buf, ptr, pitch, 0, m_fSource);
if(MFX_ERR_NONE != sts) return sts;
// load V
ReadPlaneData(w, h, buf, ptr, pitch, 1, m_fSource);
break;
mfxStatus ReadPlaneData(mfxU16 w, mfxU16 h, mfxU8 *buf, mfxU8 *ptr, mfxU16 pitch, mfxU16 offset, FILE* fSource)
mfxU32 nBytesRead;
for (mfxU16 i = 0; i < h; i++)
nBytesRead = (mfxU32)fread(buf, 1, w, fSource);
for (mfxU16 j = 0; j < w; j++)
ptr[i * pitch + j * 2 + offset] = buf;
return MFX_ERR_NONE;
and it wroked.
it also applies to the ffmpeg integration sample (which i started from...)
please check.
thanks
Petter_L_Intel
I do not see anything wrong with the sample code from Media SDK 2013 R2 with regards to reading RAW NV12 surfaces.
To verify, I tested some NV12 input content with the sample_encode sample (using the -nv12 flag). The streams generated have no color tint or streaking which would indicate any file reading related issues.
I suspect your issue may be not feeding an actual NV12 formatted raw file to the sample?
Petter
nadav
Thanks for check.
youre correct. the input was in YUV420 format (output of simple decode sample)
sorry for the hassle.
Nadav
