can not find -lmfx_d
johnson_j_
HI all:
I compile MediaSamplesPreview and i got errors: can not find -lmfx_d
I guess i didn't install some libs, but i can not locate. can anyone tell me.
By the way, I  installed MediaServerStudioEssentialsEvaluation2015R2  on Centos 7.0
Thanks a lot.
Sravanthi_K_Intel
Hello Johnson,
Thanks for bringing up this. The error you are getting is related to the build process not finding the mfx dispatcher library. You can follow these steps to build the library and the samples should build fine. (Note: In release mode, samples build without a problem. This issue you are seeing is related to the debug mode).
1. In /opt/intel/mediasdk/opensource - you will find a readme document that explains how to build the dispatcher in "Build Instructions" section. Follow them, and this will build libmfx.a in /opt/intel/mediasdk/opensource/mfx_dispatch/build/_lib
2. Rename the libmfx.a to libmfx_d.a and copy it to /opt/intel/mediasdk/lib/lin_x64/ folder
And now rebuild using the perl cmake script and the build process should succeed. Let me know if this works for you.
I wish we had made this information available without you having to spend time debugging. We are making changes to improve the health of the product and feedback/questions such as these are always appreciated. Thanks.
