I've just started experimenting with Composition, using the sample_vpp example, but I can't get it to work.
I'm using Windows 7 on an i7-3610QM processor, and Media SDK Intel(R)_Media_SDK_2016.0.1 and choosing software mode.(The system analyzer from the Media SDK shows SW support for Enc and Dec all the way up to version 1.19).
I have two 1920x1088 NV12 input files and trying to do a simple composition of a small area of the second onto the first. But in sample_vpp_utils.cpp
sts = pProcessor->pmfxVPP->Init(pParams);
returns a status of -15 which indicates that the parameters provided are not acceptable. I've looked through the parameters and tried a variety of command-line and parameter-file values but always seem to get status -15 returned.
Here is the command line I have set up in the VS2010 debugger:
-lib sw -composite d:\temp\vpp-res.txt -o d:\temp\foutvpp.nv12
And the parameter file is:
primarystream=D:\temp\f1.nv12
width=1920
height=1088
cropx=0
cropy=0
cropw=1920
croph=1088
dstx=0
dsty=0
dstw=1920
dsth=1088
fourcc=nv12
stream=D:\temp\f1-copy.nv12
width=1920
height=1088
cropx=0
cropy=0
cropw=320
croph=320
dstx=100
dsty=100
dstw=88
dsth=72
fourcc=nv12
The parameter structure being passed in appears below, including the ExtParam structure and the two InputStream structures (copied from the debugger watch window). I have trawled through all of the values in the structures but I can't find a reason why the parameters are not acceptable.
Am I missing something ?
- pParams 0x0036cc74 {AllocId=0 reserved=0x0036cc78 reserved3=0 ...} mfxVideoParam *
AllocId 0 unsigned int
reserved 0x0036cc78 unsigned int [2]
reserved3 0 unsigned short
AsyncDepth 0 unsigned short
- mfx {reserved=0x0036cc84 LowPower=0 BRCParamMultiplier=0 ...} mfxInfoMFX
reserved 0x0036cc84 unsigned int [7]
LowPower 0 unsigned short
BRCParamMultiplier 0 unsigned short
- FrameInfo {reserved=0x0036cca4 reserved4=0 BitDepthLuma=0 ...} mfxFrameInfo
reserved 0x0036cca4 unsigned int [4]
reserved4 0 unsigned short
BitDepthLuma 0 unsigned short
BitDepthChroma 0 unsigned short
Shift 0 unsigned short
FrameId {TemporalId=0 PriorityId=0 DependencyId=0 ...} mfxFrameId
FourCC 842094158 unsigned int
Width 1920 unsigned short
Height 1088 unsigned short
CropX 0 unsigned short
CropY 0 unsigned short
CropW 1920 unsigned short
CropH 1088 unsigned short
BufferSize 71305088 unsigned __int64
reserved5 71305088 unsigned int
FrameRateExtN 30 unsigned int
FrameRateExtD 1 unsigned int
AspectRatioW 0 unsigned short
AspectRatioH 0 unsigned short
PicStruct 1 unsigned short
ChromaFormat 1 unsigned short
reserved2 0 unsigned short
CodecId 0 unsigned int
CodecProfile 0 unsigned short
CodecLevel 0 unsigned short
NumThread 0 unsigned short
TargetUsage 0 unsigned short
GopPicSize 0 unsigned short
GopRefDist 0 unsigned short
GopOptFlag 0 unsigned short
IdrInterval 0 unsigned short
RateControlMethod 0 unsigned short
InitialDelayInKB 0 unsigned short
QPI 0 unsigned short
Accuracy 0 unsigned short
BufferSizeInKB 0 unsigned short
TargetKbps 0 unsigned short
QPP 0 unsigned short
ICQQuality 0 unsigned short
MaxKbps 0 unsigned short
QPB 0 unsigned short
Convergence 0 unsigned short
NumSlice 0 unsigned short
NumRefFrame 22094 unsigned short
EncodedOrder 12849 unsigned short
DecodedOrder 0 unsigned short
ExtendedPicStruct 0 unsigned short
TimeStampCalc 0 unsigned short
SliceGroupsPresent 0 unsigned short
MaxDecFrameBuffering 0 unsigned short
EnableReallocRequest 0 unsigned short
reserved2 0x0036ccfe "" unsigned short [7]
JPEGChromaFormat 0 unsigned short
Rotation 0 unsigned short
JPEGColorFormat 0 unsigned short
InterleavedDec 0 unsigned short
SamplingFactorH 0x0036ccfa "" unsigned char [4]
SamplingFactorV 0x0036ccfe "" unsigned char [4]
reserved3 0x0036cd02 "" unsigned short [5]
Interleaved 0 unsigned short
RestartInterval 0 unsigned short
reserved5 0x0036ccf8 "" unsigned short [10]
- vpp {reserved=0x0036cc84 In={...} Out={...} } mfxInfoVPP
reserved 0x0036cc84 unsigned int [8]
- In {reserved=0x0036cca4 reserved4=0 BitDepthLuma=0 ...} mfxFrameInfo
- Out {reserved=0x0036cce8 reserved4=0 BitDepthLuma=0 ...} mfxFrameInfo
reserved 0x0036cce8 unsigned int [4]
Protected 0 unsigned short
IOPattern 34 unsigned short
ExtParam 0x0036cb2c mfxExtBuffer * *
NumExtParam 1 unsigned short
- (mfxExtVPPComposite*)pParams->ExtParam[0] 0x0036cbbc {Header={...} Y=0 R=0 ...} mfxExtVPPComposite *
Header {BufferId=1347240790 BufferSz=68 } mfxExtBuffer
Y 0 unsigned short
R 0 unsigned short
U 0 unsigned short
G 0 unsigned short
V 0 unsigned short
B 0 unsigned short
reserved1 0x0036cbca "" unsigned short [24]
NumInputStream 2 unsigned short
InputStream 0x00da2238 {DstX=0 DstY=0 DstW=1920 ...} mfxVPPCompInputStream *
- ((mfxExtVPPComposite*)pParams->ExtParam[0])->InputStream[0] {DstX=0 DstY=0 DstW=1920 ...} mfxVPPCompInputStream
DstX 0 unsigned int
DstY 0 unsigned int
DstW 1920 unsigned int
DstH 1088 unsigned int
LumaKeyEnable 0 unsigned short
LumaKeyMin 0 unsigned short
LumaKeyMax 0 unsigned short
GlobalAlphaEnable 0 unsigned short
GlobalAlpha 0 unsigned short
PixelAlphaEnable 0 unsigned short
reserved2 0x00da2254 "" unsigned short [18]
- ((mfxExtVPPComposite*)pParams->ExtParam[0])->InputStream[1] {DstX=100 DstY=100 DstW=88 ...} mfxVPPCompInputStream
DstX 100 unsigned int
DstY 100 unsigned int
DstW 88 unsigned int
DstH 72 unsigned int
reserved2 0x00da2294 "" unsigned short [18]
Hi There,
I have investigated the issue (-15) observed on your end and would like to confirm VPP composition is not supported by SW. Only HW mode is supported. Please use HW mode for VPP composition, which you have already tested and have it working. We will be updating our manual with this information in next upcoming release.
Hello there,
I just tested sample_vpp composition feature on my end and it works. Please take a look and follow this article here: https://software.intel.com/en-us/articles/video-composition-using-intel-media-sdk.
Update to latest drivers from https://downloadcenter.intel.com/. ;Please note, currently you are using 3rd generation machine ( i7-3610QM ) on which only SW composition support is available.
Thanks for your reply.
When you say it worked for you, did you use the same command line and parameters that I quoted above?
Yes I had seen that article, but sample_vpp should already have all of the code to do composition ready-to-go so that seemed a good place to start. On my PC QueryVersion reports 1.19 using SW mode which should easily be good for composition (the ref manual says that mfxExtVPPComposite was added in API 1.8 with alpha capability added in 1.9). It should work but it's frustrating that even the simplest composition won't work for me. I've even tried the same parameter list from that article (and lots of other values) and that fails with -15 status aswell.
I'm wondering if there is something in the software library or dispatcher that is preventing use on 3rd gen processors - although this goes against the reason for having a software implementation. It would mean that 3rd gen processors could not do composition at all.
Has anyone else had problems getting composition to work (in software mode) on a 3rd generation processor?
Yes, I used the same command line parameters as you mentioned in previous comment. On 3rd generation processor composition SW feature is supported, as you can see API is supported (only SW). Please see this thread: https://software.intel.com/en-us/forums/intel-media-sdk/topic/557696
Now, to triage this error, Can you check from https://downloadcenter.intel.com/ if latest drivers are installed on the machine. Also, could you please share a log from system analyzer tool: https://software.intel.com/en-us/articles/media-sdk-tools.
Thanks for your assistance. Yes I updated to the latest drivers a few days ago. The Driver update utility suggested TWO driver versions - one for Windows 7 from last year, and one for Windows 10/8/7 from this year that I chose.
Here is the output from the system analyzer tool:
Intel(R) Media Server Studio 2016 R2 - System Analyzer (32-bit)
The following versions of Media SDK API are supported by platform/driver
[opportunistic detection of MSDK API > 1.19]:
Version Target Supported Dec Enc
1.0 HW Yes X X
1.0 SW Yes X X
1.1 HW Yes X X
1.1 SW Yes X X
1.2 HW Yes X X
1.2 SW Yes X X
1.3 HW Yes X X
1.3 SW Yes X X
1.4 HW Yes X X
1.4 SW Yes X X
1.5 HW Yes X X
1.5 SW Yes X X
1.6 HW Yes X X
1.6 SW Yes X X
1.7 HW Yes X X
1.7 SW Yes X X
1.8 HW Yes X X
1.8 SW Yes X X
1.9 HW Yes X X
1.9 SW Yes X X
1.10 HW Yes X X
1.10 SW Yes X X
1.11 HW Yes X X
1.11 SW Yes X X
1.12 HW No
1.12 SW Yes X X
1.13 HW No
1.13 SW Yes X X
1.14 HW No
1.14 SW Yes X X
1.15 HW No
1.15 SW Yes X X
1.16 HW No
1.16 SW Yes X X
1.17 HW No
1.17 SW Yes X X
1.18 HW No
1.18 SW Yes X X
1.19 HW No
1.19 SW Yes X X
Graphics Devices:
Name Version State
Intel(R) HD Graphics 4000 10.18.10.4425 08
NVIDIA GeForce GT 630M 9.18.13.3165 Active
System info:
CPU: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
OS: Microsoft Windows 7 Home Premium
Arch: 64-bit
Installed Media SDK packages (be patient...processing takes some time):
Intel(R) Media SDK 2013 (x86)
Intel(R) Media SDK 2016
Intel(R) Media SDK DirectShow* Sample 5.0.461.91752
Intel(R) Media SDK 2012 R2 (x86)
Intel(R) Media SDK 2016 R2
Intel(R) Media SDK 2014 R2 for Clients (x64)
Intel(R) Media SDK 2012 R3 (x86)
Intel(R) Media SDK Samples 2016
In case it helps, below are the Visual Studio 2010 command lines for the compiler and linker (it's using the SDK 2016 R2 version):
/I"D:\Intel Media SDK Samples 2016 6.0.0.142\sample_vpp\\include" /I"C:\Program Files (x86)\IntelSWTools\Intel(R)_Media_SDK_2016.0.2\\include" /I"D:\Intel Media SDK Samples 2016 6.0.0.142\sample_vpp\\..\sample_common\include" /I"C:\Program Files\Microsoft SDKs\Windows\v7.1\Include" /I"C:\Program Files\Microsoft SDKs\Windows\v7.1\Include\um" /I"C:\Program Files\Microsoft SDKs\Windows\v7.1\Include\shared" /ZI /nologo /W4 /WX /Od /Oy- /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D "_ITERATOR_DEBUG_LEVEL=0" /D "_UNICODE" /D "UNICODE" /Gm /EHsc /RTC1 /MTd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Fp"D:\Intel Media SDK Samples 2016 6.0.0.142\sample_vpp\..\_build\Win32\Debug\obj\sample_vpp\sample_vpp.pch" /Fa"D:\Intel Media SDK Samples 2016 6.0.0.142\sample_vpp\..\_build\Win32\Debug\obj\sample_vpp\" /Fo"D:\Intel Media SDK Samples 2016 6.0.0.142\sample_vpp\..\_build\Win32\Debug\obj\sample_vpp\" /Fd"D:\Intel Media SDK Samples 2016 6.0.0.142\sample_vpp\..\_build\Win32\Debug\obj\sample_vpp\vc100.pdb" /Gd /analyze- /errorReport:queue
/OUT:"D:\Intel Media SDK Samples 2016 6.0.0.142\sample_vpp\..\_build\Win32\Debug\sample_vpp.exe" /INCREMENTAL /NOLOGO /LIBPATH:"C:\Program Files (x86)\IntelSWTools\Intel(R)_Media_SDK_2016.0.2\\lib\Win32" "d3d11.lib" "dxgi.lib" "libmfx.lib" "dxva2.lib" "d3d9.lib" "kernel32.lib" "user32.lib" "gdi32.lib" "winspool.lib" "comdlg32.lib" "advapi32.lib" "shell32.lib" "ole32.lib" "oleaut32.lib" "uuid.lib" "odbc32.lib" "odbccp32.lib" "D:\Intel Media SDK Samples 2016 6.0.0.142\_build\Win32\Debug\lib\sample_common.lib" /NODEFAULTLIB:"msvcrt.lib" /NODEFAULTLIB:"msvcrtd.lib" /NODEFAULTLIB:"LIBCMT.lib" /MANIFEST /ManifestFile:"D:\Intel Media SDK Samples 2016 6.0.0.142\sample_vpp\..\_build\Win32\Debug\obj\sample_vpp\sample_vpp.exe.intermediate.manifest" /ALLOWISOLATION /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"D:\Intel Media SDK Samples 2016 6.0.0.142\_build\Win32\Debug\sample_vpp.pdb" /SUBSYSTEM:CONSOLE /PGD:"D:\Intel Media SDK Samples 2016 6.0.0.142\_build\Win32\Debug\sample_vpp.pgd" /TLBID:1 /DYNAMICBASE /NXCOMPAT /MACHINE:X86 /ERRORREPORT:QUEUE
Thanks for sharing the details. This provides insights into your system environment. I do not have exact system configuration (dual graphics) machine here to try on my end. But, I do have following pointers as that would my first step to resolve this issue:
1) I suspect that the issue is caused by dual graphics environment, so disable the NVIDIA graphics or try on some other system with latest processors ( without dual graphics). As, we have limited driver support on 3rd generation graphics : https://software.intel.com/en-us/articles/driver-support-matrix-for-media-sdk-and-opencl.
2) Please uninstall all previous versions of MSDK installed on the machine and only keep the latest copy of mediasdk 2016 R2 version. As, we have observed previously from other customers platform library issues due to previous versions MSDK installed on 3rd generation systems.
OK, I disabled the NVIDIA driver (via Control Panel > Device Manager) and rebooted.
I also uninstalled ALL of the Intel Media SDK versions, rebooted, then installed the Intel Media SDK 2016 R2 again. Then rebooted again. Then checked the Device Manager again to confirm the NVIDIA driver was still disabled.
Then ran the system analyzer tool that gave:
[opportunistic detection of MSDK API > 1.19]:Version Target Supported Dec Enc
1.0 HW Yes X X
1.0 SW Yes X X
1.1 HW Yes X X
1.1 SW Yes X X
1.2 HW Yes X X
1.2 SW Yes X X
1.3 HW Yes X X
1.3 SW Yes X X
1.4 HW Yes X X
1.4 SW Yes X X
1.5 HW Yes X X
1.5 SW Yes X X
1.6 HW Yes X X
1.6 SW Yes X X
1.7 HW Yes X X
1.7 SW Yes X X
1.8 HW Yes X X
1.8 SW Yes X X
1.9 HW Yes X X
1.9 SW Yes X X
1.10 HW Yes X X
1.10 SW Yes X X
1.11 HW Yes X X
1.11 SW Yes X X
1.12 HW No
1.12 SW Yes X X
1.13 HW No
1.13 SW Yes X X
1.14 HW No
1.14 SW Yes X X
1.15 HW No
1.15 SW Yes X X
1.16 HW No
1.16 SW Yes X X
1.17 HW No
1.17 SW Yes X X
1.18 HW No
1.18 SW Yes X X
1.19 HW No
1.19 SW Yes X XGraphics Devices:
Name Version State
Intel(R) HD Graphics 4000 10.18.10.4425 Active
NVIDIA GeForce GT 630M 9.18.13.3165 08System info:
Arch: 64-bitInstalled Media SDK packages (be patient...processing takes some time):
Then I rebuilt the sample_vpp from scratch. And ran it again in the Visual Studio debugger using software mode. QueryVersion says it is using API version 1.19.
It still returns -15 from sts = pProcessor->pmfxVPP->Init(pParams);
So no difference. :(
Hi There,
Thank you for the update. To triage its not a app issue and isolate its not a VS config issue either, can you please try with the prebuilt sample_vpp app at location (<installed directory/Intel Media SDK Samples 2016 6.0.0.142\_bin\x64). Let me know how it goes.
OK. Here is the transcript - tried the 32 and 64 bit versions of sample_vpp.exe and both failed with -15 status.
D:\Intel Media SDK Samples 2016 6.0.0.142\_bin\win32>sample_vpp.exe -lib sw -composite d:\temp\vpp-res.txt -o d:\temp\foutvpp.nv12Return on error: error code -15, src\sample_vpp_utils.cpp 401
Return on error: error code -15, src\sample_vpp_utils.cpp 628
Return on error: error code 1, src\sample_vpp.cpp 192
D:\Intel Media SDK Samples 2016 6.0.0.142\_bin\win32>cd ..\x64
D:\Intel Media SDK Samples 2016 6.0.0.142\_bin\x64>sample_vpp.exe -lib sw -composite d:\temp\vpp-res.txt -o d:\temp\foutvpp.nv12
Hi There,
Thanks for the update. Please send me the package including both the streams and par file. Also, to isolate this is not a specific system issue, Can you try on any other systems you have with latest 4th generation processor and above (without dual graphics). Let me know the results.
The good news is that I have managed to get it to work in HARDWARE mode - I had assumed from a previous thread that it would not work for third generation processors so I have only just tried it, and it does work. This is on the same i7-3610QM third generation laptop. The ref manual says that composition appeared in API 1.8, and QueryVersion in HW mode reports 1.11 on this i7-3610QM so one would expect HW composition to work OK, and it does. Are there perhaps some third generation processors that can not do composition, and some that can?
VPP Sample Version 6.0.0.142
Input format NV12
Resolution 1920x1088
Crop X,Y,W,H 0,0,1920,1088
Frame rate 30.00
PicStruct progressive
Output format NV12
Frame rate 30.00
PicStruct progressiveVideo Enhancement Algorithms
Denoise OFF
VideoAnalysis OFF
ProcAmp OFF
Detail OFF
ImgStab OFFMemory type system
MediaSDK impl hw
MediaSDK ver 1.11VPP started
Frame number: 234
VPP finished
I am surprised to see that the Memory type is shown above as "system" - I would have thought it should be video memory for hardware mode ? I was also a bit surprised that sts = pProcessor->pmfxVPP->Init(pParams) returns the warning status MFX_WRN_FILTER_SKIPPED. I don't know what it thinks it has skipped, but composition does seem to work OK
The bad news is that SOFTWARE mode still fails. The only other machine I have around at present is a low-powered laptop with a Celeron N3050 @ 1.60GHz and integrated graphics only. The system analyzer does however show HW support up to SDK version 1.16, and SW up to 1.19.
In software mode on the Celeron, sample_vpp fails in the same way:
D:\Intel Media SDK stuff>sample_vpp.exe -lib sw -composite vpp-res.txt -o fout.nv12
But in hardware mode on the Celeron, sample_vpp succeeds, just like on the i7-3610QM.
So it looks like it is a problem with the software implementation.
How do I send you the files?
Hi There,
Great to hear you atleast have composition working in HW mode. Now, generally SW mode should also work as MSDK always provides a fallback if HW implementation fails. It will be interesting to investigative why SW mode is failing when on the other end HW mode works.
I am surprised to see that the Memory type is shown above as "system" - I would have thought it should be video memory for hardware mode ? -> Please take a look at MediaSDK developer guide.https://software.intel.com/sites/default/files/Intel_Media_Developers_Guide_0.pdf. From the transcript MediaSDK impl hw refers to system HW been used "add d3d" which is video memory. Again, samples are just getting started examples and not production ready, feel free to modify code suitable for your scenario.
How do I send you the files? -> Zip the files and use "Attach Files to Post" to attach them.
> impl hw refers to system HW been used which is video memory.
From the guide:
SYSTEM_MEMORY specifies that CPU memory will be used. This is best for the software implementation.
VIDEO_MEMORY specifies that GPU memory will be used. This is best for the hardware implementation.
It looks like sample_vpp will use SYSTEM_MEMORY even if you use the -lib hw option unless you also supply -d3d or -d3d11 command line options which will then use VIDEO_MEMORY.
So I tried adding the -d3d option expecting to see a significant speedup - instead it ran very much slower! Very strange.
I have attached the files for the software mode problem. There is only one yuv file in the package - use it for BOTH of the input files (will provide a smaller version of the same image composited onto the video).
> > impl hw refers to system HW been used which is video memory -> Correction : impl hw refers to system HW been used add d3d which is video memory. Apologies, I missed including it in previous sentence.
Many performance fallbacks with Direct X 9 (d3d) was addressed by Microsoft with Direct X 11 release. For performance improvement, I recommend updating your OS to Win 8 or above and try with -d3d11 implementation.
Thank you for the package, let me investigate and get back to you soon.
Hi There,
Sorry for the delay in replying. And thanks for looking into this.
> VPP composition is not supported by SW. Only HW mode is supported ...
Do you mean that this will be fixed in the next release (composition will be possible in SW mode), or do you mean that composition will never be possible in SW mode ?
Your reply sounds like the latter which would be very surprising as the SW implementation is supposed to provide a fall-back for any problems with the HW implementation. If composition will never be possible in SW mode then this seems to break the whole point of the SW mode.
Hi There,
Currently, VPP composition is not supported or possible in SW mode. As, HW support is available from 3rd generation and above processors, we recommend taking advantage of HW mode vs SW mode for better performance and quality. But, if you interested in SW mode, please share with me business interest along impact for SW mode via private message.
Thanks. I can manage OK in hardware mode. Hopefully composition support will eventually be added to software mode, if only to offer a complete and reliable fallback support if there are any problems with hardware mode on a client machine. Support must have been missing since API version 1.8 which seems quite a long time.
Thank you for your time in looking into this.
