converting BGR frame to NV12 frame
nick_k_5
Sorry if similar subject already was here - i trying to find answer but cannot..
I need to encode sequence of BGR frames to h264 stream.
I am using sample_encode Media SDK as example. This example uses as input YUV stream - so it is not my case.
The first. I am trying to use IPP functions: ippiBGRToYCrCb420_8u_AC4P3R(...) for 32 bit BGR or ippiBGRToYCrCb420_8u_C3P3R(..) for 24 bit BGR source frame. SO i obtain 3 planes for YCbCr.
The second - I wrote function which makes interleave of CbCr into single plane to be NV12 compatible. So right now all works.
BUT! Question is how to avoid mixing/interleaving step in my  algorithm?
I was expecting to find IPP function like ippiBGRToYCrCb420_8u_AC4P2R() and ippiBGRToYCrCb420_8u_C3P2R(..) but seem those function do not exist!
What i am doing wrong? What i am missing? I expected that if HW accepts only NV12 source frame then IPP probably should provide functions to convert from ordinal formats to two-plane NV12.. Now i need to do color conversion in 2 steps, so i expect performance loss during conversion because i need intermediate memory buffer written and read.
Alexey_F_Intel
read https://software.intel.com/sites/default/files/mediasdk-man.pdf page 163 listing colour formats convertions supported in HW.
Jeffrey_M_Intel1
This article explains some ways to match up IPP color conversion functions with color formats supported by VPP.  Perhaps something here is closer to what you need?
https://software.intel.com/en-us/articles/using-unsupported-color-formats-with-the-intel-media-software-development-kit
Roman_T_
Hi nick!
In addition to previous posts I can suggest you another one solution of your task.
IPP function ippiBGRToYCrCb420_8u_AC4P2R() exists, but it available in old IPP version (7.1)
So if you will combine the latest  version of Media SDK and IPP 7.1, ippiBGRToYCrCb420_8u_AC4P2R() will be available.
Roman
