Hi
I am using the multi transcode framework provided by intel.
I am using the opencl filter as a plugin. Is there any facility in framework, I can check the intermediate output of Decoder or output after VPP processing?
Hi Manish,
You can write the output after the operation if you like, not recommended for actual pipeline. I hope that would be for debugging purpose. You can use other encode and decode samples or tutorials to get see the logic/code for writing the o/p.
Subrhi
Topic Options
