hi,
OS: Ubuntu 12.04
MediaSamples_Linux_6.0.16043175.175
MediaServerStudioEssentials2015R6
Platform: i5-4570S
I got following error as setting field "threads_num" to 1 ~
[release] $ time ./sample_decode_x11 h264 -hw -low_latency -vaapi -threads_num 2 -i 1080p.264
libva info: VA-API version 0.35.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
Decoding Sample Version 0.0.000.0000
Input video AVC
Output format YUV420
Resolution 1920x1088
Crop X,Y,W,H 0,0,0,0
Frame rate 30.00
Memory type d3d
MediaSDK impl hw
MediaSDK version 1.16
Decoding started
Frame number: 635, fps: 1122.763, fread_fps: 0.000, fwrite_fps: 0.000
Decoding finished
real 0m0.574s
user 0m0.238s
sys 0m0.039s
[release] $ time ./sample_decode_x11 h264 -hw -low_latency -vaapi -threads_num 1 -i 1080p.264
Return on error: error code -3, /home/dspuser/Downloads/IntellMediaSDK/MediaSamples_Linux_6.0.16043175.175/samples/sample_decode/src/pipeline_decode.cpp 200 ==> -3 means MFX_ERR_UNSUPPORTED. Why it's not supported ??? Any concern inside??
Return on error: error code 1, /home/dspuser/Downloads/IntellMediaSDK/MediaSamples_Linux_6.0.16043175.175/samples/sample_decode/src/sample_decode.cpp 501 ==> 1 means MFX_WRN_IN_EXECUTION
real 0m0.004s
user 0m0.004s
sys 0m0.000s
[release] $
Hi There,
I want to better understand your system.
Can you send following command line ?
$ uname -r
$ ls -l /dev/dri
$ vainfo
You are using Ubuntu 12.04, right ? Just want you know currently CentOS 7.1 is Intel media server studio Gold configuration.
Zachary
Hi Here,
[release] $ uname -r
3.14.5
[release] $ ls -l /dev/dri/
total 0
crw-rw----+ 1 root video 226, 0 Dec 16 01:48 card0
crw-rw---- 1 root video 226, 64 Nov 13 02:07 controlD64
crw-rw---- 1 root video 226, 128 Nov 13 02:07 renderD128
[release] $ sudo vainfo
vainfo: VA-API version: 0.35 (libva 1.3.1)
vainfo: Driver version: 16.4.2.1.39163-ubit
vainfo: Supported profile and entrypoints
VAProfileNone : VAEntrypointVideoProc
VAProfileNone : <unknown entrypoint>
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileH264Baseline : VAEntrypointEncSlice
VAProfileH264Baseline : <unknown entrypoint>
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264Main : <unknown entrypoint>
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264High : <unknown entrypoint>
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointEncPicture
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: <unknown entrypoint>
VAProfileVP8Version0_3 : VAEntrypointEncSlice
VAProfileVP8Version0_3 : VAEntrypointVLD
VAProfileVP8Version0_3 : <unknown entrypoint>
[release]
> Yes, thanks @@y
Thank you
Hi Medwin,
Thank you report this issue. I can reproduce this issue, I will check with develop team and get back to you.
Zachary
This is a feature, it is not a bug, so close this thread.
