I'm trying to run the sampe_decode in INDE, my hardware is Core M5y70, graphic is HD5300, OS win8.1, the sample version I used is
Intel Media Samples 6.0.0.49, the driver I downloaded is win64_153619.exe.
my runtime parameter is set as
h265 -i 1080p_Big_buck_bunny_1080p_f619.bin -o test.yuv -hw -p 33a61c0b4c27454ca8d85dde757c6f8e
the input stream I used is compressed with x265 in videoLan, with the default setting.
but I got the following failure:
plugin_loader.h :157 [INFO] Plugin was loaded from GUID
Return on error: error code -3, src\pipeline_decode.cpp 641
Return on error: error code -3, src\pipeline_decode.cpp 287
Return on error: error code 1, src\sample_decode.cpp 496
plugin_loader.h :183 [INFO] MFXBaseUSER_UnLoad(session=0x000000FD9EF735C0), sts=
0
I checked that -3 is unsupported feature, does it mean my hardware not support this feature, or I did something wrong?
thanks
Thank you for the logs. Your hw does not support this feature. The current hardware you are using (5Y70 CPU) does not provide hw hevc decode support which is via our graphics driver. You can hevc hw decode on system other than (5Y**) series processors.
Can you send us a log from system analyzer < mediaSDK/tools/system analyzer>, so we have all the available information about the system.
Also, I tried with one of the our input test (Bigs Bunny) elementary stream file and did not see this issue, Can you please try with any other .265 test input file you have, just to isolate issue seen is not due to input file. Let me know if that works!
