decoding mpeg2 by Media SDK 2
kohshinToku
Hi
I posted a problem before about below:
https://community.intel.com/t5/Media-Intel-oneAPI-Video/decoding-mpeg2-by-Media-SDK/td-p/1294492
However, I will create a thread again because there is no reply.
I would like to know the following two points.
- Did you fix the problem that noise occurs in mpeg2 decoding of Media SDK by fixing the graphic driver?
- Please tell me the number of the modified driver.
Regards.
JyothisV_Intel
Good day to you.
We are working on this internally and will get back to you with an update soon.
Thanks and Regards,
Jyothis V James
kohshinToku
Hi.
You should see if the graphics driver team has fixed this issue.
Originally this issue occurred when the graphics driver was updated.
And again, after updating the graphics driver to the latest version, the problem no longer occurs.
Regards.
Pamela_H_Intel
Apologies for the delays. Media SDK functionality has been superseded by oneVPL, FFmpeg and GStreamer.
For more information see the oneVPL Landing Page: https://www.intel.com/content/www/us/en/developer/tools/oneapi/onevpl.html where you will find, among other information
oneVPL version 2.x is an API that is the successor to Intel® Media SDK. The Intel Media SDK project is no longer active and will not be updated. Packages and downloads are still available on GitHub*. For continued support and access to new features, Intel Media SDK users are encouraged to move to oneVPL as soon as possible.
Let us know if you have any questions about oneVPL.
