Hi
I posted a problem before about below:
https://community.intel.com/t5/Media-Intel-oneAPI-Video/decoding-mpeg2-by-Media-SDK/td-p/1294492
However, I will create a thread again because there is no reply.
I would like to know the following two points.
- Did you fix the problem that noise occurs in mpeg2 decoding of Media SDK by fixing the graphic driver?
- Please tell me the number of the modified driver.
Regards.
Good day to you.
We are working on this internally and will get back to you with an update soon.
Thanks and Regards,
Jyothis V James
Hi.
You should see if the graphics driver team has fixed this issue.
Originally this issue occurred when the graphics driver was updated.
And again, after updating the graphics driver to the latest version, the problem no longer occurs.
Regards.
