does kabylake support hevc hight tier encode?
l_k_1
I use Intel® Media Software Development Kit 2017 R1,  And kabylake i7-7700.
Could your tell me how to set hight tier for hevc encode ?
Can sdk set params like below ?
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : SMPTE ST 2084
Matrix coefficients                      : BT.2020 non-constant
Anna_B_Intel
Please use ColorFourCC MFX_FOURCC_P010. If you want to run sample_encode with 10bit 4:2:0 input, use -p010 option.
Best wishes,
Anna
l_k_1
Best wishes,
Anna
Hi Anna,
    Thanks for your answer.  But you misunderstand my question.
    I asking how to set params to generate a hevc with high tier?   the sample can not gen a high tier hevc with low bitrate, I there is no param in sdk head files.
    And how to set mfxExtVideoSignalInfo  mfxExtChromaLocInfo etc.
    I try some setting,  mfxExtVideoSignalInfo  work with h264, but can not set to hevc encode.
    below is some hevc sps info I want set, but with no luck in driver 22.20.16.4729.
Bit depth                                : 10 bits
  Please confirm are these sps info support in hevc yet?
  Or I use api wrong.
LK
