does overlay_qsv in FFMPEG support alpha channel?
wong__ham
when I use overlay_qsv in ffmpeg to display logo, overlay_qsv not able to transparent background, no matter PNG, APNG , gif or DVB source picture subtitle, for picture subtitle, The best I can do is  adjust tranparent level on subitle layer by alpha value, is this is ffmpeg coding issue or intel hardware can't handle it? as all above content can work 100% fine with ffmpeg fitler overlay, I just don't know this was due to my config problem or what. please kindly advise
ffmpeg -hwaccel qsv -qsv_device 1 -c:v h264_qsv -re -i "test.ts" -loop 1 -i "Logo.png" ^
-filter_complex "[1:v]format=nv12,hwupload=extra_hw_frames=10[watermark]; ^
[0:v][watermark]overlay_qsv=x=30:y=30" -vcodec h264_qsv -q:v 20 -acodec copy -y test.mp4
ffmpeg -hwaccel qsv -qsv_device 1 -c:v h264_qsv -re -i "http://192.168.101.2:7522/upnp/channelstream/transcode/3713217898725769217.ts" -ignore_loop 0 -i "lg-wave-ball-preloader.gif" ^
-filter_complex "[0:v]deinterlace_qsv,scale_qsv=-1:720,vpp_qsv=denoise=20,fps=25[bg]; ^
[1:v]format=yuv420p,hwupload=extra_hw_frames=10,scale_qsv=-1:50[logo]; ^
[0:s:0]format=yuv420p,hwupload=extra_hw_frames=10,scale_qsv=-1:720[sub]; ^
[bg][logo]overlay_qsv=x=30:y=30[bg2] ; [bg2]overlay_qsv=alpha=100" ^
-vcodec h264_qsv -look_ahead 0 -q:v 20 -acodec copy -y test.ts
Durga_Bhavani__Vayil
-filter_complex "[1:v]hwupload=extra_hw_frames=10[watermark]; ^
Remove format then you will get PNG overlay.
Having format=nv12 or yuv420p is internally changing original png image properties.
This will give png image overlay exactly.
Having format=nv12 or yuv420p leads to converting internal properties of png image.
SebGreen
this gives me:
[Parsed_overlay_qsv_1 @ 0x55d29768aa40] Inputs with different underlying QSV devices are forbidden. [Parsed_overlay_qsv_1 @ 0x55d29768aa40] Failed to configure output pad on Parsed_overlay_qsv_1 Error reinitializing filters! Failed to inject frame into filter network: Invalid argument
any idea?
SebGreen
ffmpeg -init_hw_device qsv -hwaccel qsv -hwaccel_output_format qsv -c:v h264_qsv -re -i input.mp4 -loop 1 -r 30 -i overlay.png -filter_complex '[1:v]hwupload=extra_hw_frames=10[ov];[0:v][ov]overlay_qsv' -c:v h264_qsv -y output.mp4
