Is there any sample which show capturing video packets from device (ethernet, pcie, other port) ?
Is it using dpdk ? or v4l ?
What is the recommendation ?
Ran
At this time the samples, tutorials, and documentation focus on file input as the simplest, most universal starting point. It's relatively straightforward to plug in other data sources though. You can start with simple_2_decode in the tutorials, or sample_decode from the samples package.
If you're looking for a more complete starting point, another alternative is FFmpeg. Performance isn't quite as good as with an application custom designed for optimal performance, but it does give you immediate access to the wide variety of I/O supported by that framework.
Thanks you very much,
Ran
