Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
error code -3 sample decode error
KMedi
Hi Team,
I have installed Trail version of Intel Media SDK  on Linux Machine and tried sample decode example was throwing below error. i have shared all hardware and OS details. please let us know, what mistake iám doing and how overcome this issue.
Command:
./sample_encode h264 -i /home/bvittalprasad/ffmpeg_sources/ffmpeg_static/bb.yuv  -o out.yuv -w 1920 -h 1080
Error:
Return on error: error code -3, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_encode/src/pipeline_encode.cpp  1069
Return on error: error code -3, /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_encode/src/sample_encode.cpp    859
CPU architecture:
Architecture:          x86_64
CPU op-mode(s):        32-bit, 64-bit
Byte Order:            Little Endian
CPU(s):                8
On-line CPU(s) list:   0-7
Thread(s) per core:    1
Core(s) per socket:    1
Socket(s):             8
NUMA node(s):          1
Vendor ID:             GenuineIntel
CPU family:            6
Model:                 60
Model name:      Intel Core Processor (Haswell)
Stepping:              1
CPU MHz:               2394.230
BogoMIPS:              4788.46
Hypervisor vendor:     KVM
Virtualization type:   full
L1d cache:             32K
L1i cache:             32K
L2 cache:              4096K
NUMA node0 CPU(s):     0-7
OS: RHEL 6.4
RHEL Release: Red Hat Enterprise Linux Server release 6.4 (Santiago)
RHEL Kernel: Linux mediabuild 2.6.32-358.el6.x86_64 #1 SMP Tue Jan 29 11:47:41 EST 2013 x86_64 x86_64 x86_64 GNU/Linux
Jiandong_Z_Intel
Hi There,
You cpu Intel Core Processor (Haswell) is not in the release note:
https://software.intel.com/sites/default/files/managed/db/2e/media_server_studio_essentials_release_...
You may want to upgrade your HW to 5th or 6th CPU.
Zachary
