OS: Ubuntu Linux 14.04 with kernel 3.14.5-MSSr6 #1 SMP.
- https://software.intel.com/en-
- All sample_encode works with the media sdk
https://ffmpeg.org/pipermail/
>> /opt/ffmpeg_qsv/bin/ffmpeg -f v4l2 -framerate 30 -video_size 640x480 -i /dev/video0 -c:v h264_qsv -b:v 2000k out.mp4 -loglevel 1000000
[h264_qsv @ 0x2e327e0] Error initializing an internal MFX session
Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
/etc/ld.so.conf.d/intel-
5) ldconfig -p -N | grep intel.mediasdk
libmfxsw64.so (libc6,x86-64) => /opt/intel/mediasdk/lib64/
libmfxhw64.so (libc6,x86-64) => /opt/intel/mediasdk/lib64/
6) Testing with a sample yuv file instead of camera feed got the same error
Please see the detailed log attached.
Hi Jay,
We have recently created a white paper on this topic i.e. configuring QSV in ffmpeg on Intel hardware which is what you are trying to set up. Your hardware seems to be supported Intel Media Server Studio and you have verified using samples, coming to set up ffmpeg and test, will recommend you to go through this paper - http://www.intel.com/content/dam/www/public/us/en/documents/white-papers/quicksync-video-ffmpeg-install-valid.pdf
Also, it's better to start your test with a local file than a stream captured from camera, if it's work fine, move to stream captured from camera.
Let us know if after following the white paper you still come across any issue.
Surbhi
Hi Surbhi,
Thanks for the link to the paper. The instruction that I followed is pretty much similar. Also, I tested with a local file and it generated the same error.
Here is the command:
/opt/ffmpeg_qsv/bin/ffmpeg -y -i ~/software/MediaServerStudioEssentials2016/MediaSamples_Linux_2016_bin/content/test_stream.264 -vcodec h264_qsv -acodec copy -b:v 8000k ~/out.mp4
The stdout from the run is shown below:
ffmpeg version n3.0-3-gb80083a Copyright (c) 2000-2016 the FFmpeg developers
built with gcc 4.8 (Ubuntu 4.8.4-2ubuntu1~14.04.1)
configuration: --disable-shared --enable-static --enable-gpl --enable-nonfree --enable-fontconfig --enable-libfaac --enable-libfreetype --enable-libmp3lame --enable-librtmp --enable-libx264 --enable-version3 --enable-ffplay --disable-doc --disable-ffserver --enable-pthreads --enable-filters --enable-libvorbis --enable-libtheora --enable-runtime-cpudetect --enable-libass --enable-bzlib --enable-zlib --prefix=/opt/ffmpeg_qsv/ --enable-libmfx
libavutil 55. 17.103 / 55. 17.103
libavcodec 57. 24.102 / 57. 24.102
libavformat 57. 25.100 / 57. 25.100
libavdevice 57. 0.101 / 57. 0.101
libavfilter 6. 31.100 / 6. 31.100
libswscale 4. 0.100 / 4. 0.100
libswresample 2. 0.101 / 2. 0.101
libpostproc 54. 0.100 / 54. 0.100
[h264 @ 0x3bb1540] Increasing reorder buffer to 1
Input #0, h264, from '/home/jayram/software/MediaServerStudioEssentials2016/MediaSamples_Linux_2016_bin/content/test_stream.264':
Duration: N/A, bitrate: N/A
Stream #0:0: Video: h264 (High), yuv420p, 176x96 [SAR 1:1 DAR 11:6], 30 fps, 30 tbr, 1200k tbn, 60 tbc
[h264_qsv @ 0x3bedf60] Error initializing an internal MFX session
Output #0, mp4, to '/home/jayram/out.mp4':
Stream #0:0: Video: h264, none, q=2-31, 128 kb/s, SAR 1:1 DAR 0:0, 30 fps
Metadata:
encoder : Lavc57.24.102 h264_qsv
Stream mapping:
Stream #0:0 -> #0:0 (h264 (native) -> h264 (h264_qsv))
Like before, I got the same error "Error initializing an internal MFX session".
I followed the instruction given in https://software.intel.com/en-us/articles/how-to-setup-media-server-studio-on-secondary-os-of-linux for installing the libva, libdrm and libmfx from the mediasdk/opensource folder. This process is not described in the document that you shared.
Regards, Jay
