Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
gstreamer skylake error: failed to get surface available
vandanachadha
We have skylake and were able to reun the intel media sdk tests after installing that.
We then installed gstreamer using gst-build with enabled msdk.  However, this pipeline is not working ok:
gst-launch-1.0 --gst-debug=3 filesrc location=~/sample_videos/big_buck_bunny_720p_2mb.mp4 ! decodebin name=demux demux. ! queue ! audioresample ! audioconvert ! avenc_aac bitrate=192000 ! mux. mpegtsmux bitrate=5000000 alignment=7 name=mux ! filesink location=msdk_out_file_210308.ts demux. ! queue ! msdkh264enc hardware=true ! video/x-h264,stream-format=byte-stream,profile=high ! h264parse ! mux.
log:
libva info: VA-API version 1.11.0
libva info: User environment variable requested driver 'iHD'
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_11
libva info: va_openDriver() returns 0
Setting pipeline to PAUSED ...
0:00:00.227896923 27446 0x5643e8c48010 WARN basesrc gstbasesrc.c:3688:gst_base_src_start_complete:<filesrc0> pad not activated yet
Pipeline is PREROLLING ...
Got context from element 'msdkh264enc0': gst.msdk.Context=context, gst.msdk.Context=(GstMsdkContext)"\(GstMsdkContext\)\ msdkcontext1";
0:00:00.354057866 27446 0x7fa4a00a2d40 WARN qtdemux qtdemux.c:3101:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 1
0:00:00.354451483 27446 0x7fa4a00a2d40 WARN qtdemux qtdemux.c:3101:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 2
Redistribute latency...
0:00:00.568981810 27446 0x5643e8bfdd90 WARN videopool gstvideopool.c:194:video_buffer_pool_set_config:<msdkbufferpool0> allocation params alignment 31 is smaller than the max specified video stride alignment 127, fixing
0:00:00.569071750 27446 0x5643e8bfdd90 WARN videopool gstvideopool.c:194:video_buffer_pool_set_config:<msdkbufferpool1> allocation params alignment 31 is smaller than the max specified video stride alignment 127, fixing
0:00:00.569147623 27446 0x5643e8bfdd90 WARN videopool gstvideopool.c:194:video_buffer_pool_set_config:<msdkbufferpool2> allocation params alignment 31 is smaller than the max specified video stride alignment 127, fixing
0:00:00.569225629 27446 0x7fa480008a30 WARN videopool gstvideopool.c:194:video_buffer_pool_set_config:<msdkbufferpool2> allocation params alignment 31 is smaller than the max specified video stride alignment 127, fixing
0:00:00.569272319 27446 0x7fa480008a30 WARN videopool gstvideopool.c:194:video_buffer_pool_set_config:<msdkbufferpool2> allocation params alignment 31 is smaller than the max specified video stride alignment 127, fixing
0:00:00.569418132 27446 0x5643e8bfdd90 WARN videopool gstvideopool.c:194:video_buffer_pool_set_config:<msdkbufferpool3> allocation params alignment 31 is smaller than the max specified video stride alignment 127, fixing
0:00:00.569479894 27446 0x7fa480008a30 WARN videopool gstvideopool.c:194:video_buffer_pool_set_config:<msdkbufferpool3> allocation params alignment 31 is smaller than the max specified video stride alignment 127, fixing
0:00:00.569514182 27446 0x7fa480008a30 WARN videopool gstvideopool.c:194:video_buffer_pool_set_config:<msdkbufferpool3> allocation params alignment 31 is smaller than the max specified video stride alignment 127, fixing
0:00:00.636525141 27446 0x7fa480008a30 ERROR default gstmsdkvideomemory.c:77:gst_msdk_video_allocator_get_surface: failed to get surface available
0:00:00.636567653 27446 0x7fa480008a30 ERROR msdkbufferpool gstmsdkbufferpool.c:270:gst_msdk_buffer_pool_alloc_buffer:<msdkbufferpool3> failed to create new MSDK memory
0:00:00.636580229 27446 0x7fa480008a30 WARN bufferpool gstbufferpool.c:302:do_alloc_buffer:<msdkbufferpool3> alloc function failed
0:00:00.636597721 27446 0x7fa480008a30 WARN libav gstavviddec.c:955:gst_ffmpegviddec_get_buffer2:<avdec_h264-0> error: Unable to allocate memory
0:00:00.636608281 27446 0x7fa480008a30 WARN libav gstavviddec.c:955:gst_ffmpegviddec_get_buffer2:<avdec_h264-0> error: The downstream pool failed to allocated buffer.
ERROR: from element /GstPipeline:pipeline0/GstDecodeBin:demux/avdec_h264:avdec_h264-0: Unable to allocate memory
Additional debug info:
../subprojects/gst-libav/ext/libav/gstavviddec.c(955): gst_ffmpegviddec_get_buffer2 (): /GstPipeline:pipeline0/GstDecodeBin:demux/avdec_h264:avdec_h264-0:
ERROR: pipeline doesn't want to preroll.
0:00:00.636830303 27446 0x7fa480008a30 ERROR libav :0:: get_buffer() failed
Setting pipeline to NULL ...
0:00:00.636870620 27446 0x7fa480351d60 ERROR libav :0:: thread_get_buffer() failed
0:00:00.636919754 27446 0x7fa480351d60 ERROR libav :0:: decode_slice_header error
0:00:00.636935851 27446 0x7fa480351d60 ERROR libav :0:: no frame!
Freeing pipeline ...
