Media (Intel® oneAPI Video Processing Library, Intel Media SDK)
Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
Intel Customer Support will be observing the Martin Luther King holiday on Monday, Jan. 17, and will return on Tues. Jan. 18.
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
gstreamer-vaapi broken ? problem connecting vaapidecode to vaapiencode_h264 ?
tapas_k_
I installed latest intel graphics for linux by following wiki on ubuntu 15.04/intel baytrail (lenevo B50 touch laptop).:
https://01.org/linuxgraphics/downloads/intel-graphics-installer-linux-1.2.0
I am trying to execute following pipeline : (It seems that vaapidecode is unable to connect with vaapiencode_h264 .  Can anyone tell me why it is failing  ? )
GST_DEBUG=3 gst-launch-1.0 flvmux name=mux streamable=true ! rtmpsink sync=true location="rtmp://xxxxxxx" rtspsrc location="rtsp://admin:admin@192.168.0.162:554/cam/realmonitor?channel=1&subtype=0"   ! rtph264depay ! queue ! h264parse ! vaapidecode ! queue ! vaapiencode_h264 rate-control=cbr tune=high-compression ! mux.
libva info: VA-API version 0.38.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_0_38
libva info: va_openDriver() returns 0
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Got context from element 'vaapidecode0': gst.vaapi.Display=context, display=(GstVaapiDisplay)NULL;
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://admin:admin@192.168.0.162:554/cam/realmonitor?channel=1&subtype=0
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending PLAY request
0:00:00.304117302  3863 0x7fef1c03f800 FIXME                default gstutils.c:3766:gst_pad_create_stream_id_internal:<fakesrc0:src> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
Progress: (request) Sent PLAY request
Redistribute latency...
0:00:00.709249061  3863      0x1608450 WARN                GST_PADS gstpad.c:3989:gst_pad_peer_query:<vaapidecode0:src> could not send sticky events
0:00:00.832054174  3863 0x7fef1c03f8f0 WARN                 basesrc gstbasesrc.c:2943:gst_base_src_loop:<udpsrc1> error: Internal data flow error.
0:00:00.832118375  3863 0x7fef1c03f8f0 WARN                 basesrc gstbasesrc.c:2943:gst_base_src_loop:<udpsrc1> error: streaming task paused, reason not-negotiated (-4)
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1: Internal data flow error.
Additional debug info:
gstbasesrc.c(2943): gst_base_src_loop (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1:
Execution ended after 0:00:00.528707555
Setting pipeline to READY ...
0:00:00.842904885  3863      0x16082d0 WARN                 rtspsrc gstrtspsrc.c:6051:gst_rtspsrc_send:<rtspsrc0> error: Got error response: 455 (Method Not Valid in This State).
0:00:00.843011339  3863      0x16082d0 WARN                 rtspsrc gstrtspsrc.c:8011:gst_rtspsrc_pause:<rtspsrc0> error: Could not send message. (Generic error)
Setting pipeline to NULL ...
Freeing pipeline ...
janardana@janardana-Lenovo-B50-30-Touch:~/src/gstreamer/head$
Jiandong_Z_Intel
Hi There,
Because you are using graphic driver from 01.org, it is OTC driver. Maybe following URL can help you :
https://01.org/linuxgraphics/forum
https://01.org/linuxgraphics/forum/graphics-installer-discussions
Zachary
