how to adjust VPP algorithm parameters dynamically?
jackhong
I'm trying to reset the vpp for allowing dynamic algorithm parameters, such as Detail Factor、Denoise Factor;
 MFXVideoVPP_Reset returns MFX_ERR_NONE, but  has no effect.
Sheng_G_Intel1
for some algorithm, MFXVideoVPP_Reset  is not supported, and it will return MFX_ERR_NONE but no effect.
you can try replace MFXVideoVPP_Reset with MFXVideoVPP_Close & MFXVideoVPP_Init to make it work.
jackhong
system and software info:
Graphics Devices:
        Name                                         Version             State
        Intel(R) HD Graphics            10.18.10.4226       Active
System info:
        CPU:    Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
        OS:     Microsoft Windows 7
software info:
        INDE 2015  SDK API 1.11
Jiandong_Z_Intel
Hi There,
You can refer to "4.11.1  DoNotUse and DoUse lists" in page 44  in Intel® Media SDK Dev Guide,
Help this can help you.
Zachary
Sheng_G_Intel1
