3058 Discussions
how to deinterlacing use vpp?i got a warning "MFX_WRN_INCOMPATIBLE_VIDEO_PARAM"
Jin_Shuyang
I written a small app. The app use the capture card grab video frames (yuy2,interlace,29.97fps) into the mem and use media sdk to encode it .
I want to sdk alter yuy2 to nv12 and deinterlace . alter yuy2 to nv12 is ok , but deinterlacing, i got the warning "MFX_WRN_INCOMPATIBLE_VIDEO_PARAM" ,the frames is still interlaced. the code like this:
m_mfxVppParams.IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY | MFX_IOPATTERN_OUT_SYSTEM_MEMORY;
m_mfxVppParams.vpp.In.FourCC=MFX_FOURCC_YUY2;
m_mfxVppParams.vpp.In.PicStruct = MFX_PICSTRUCT_FIELD_TFF;
ConvertFrameRate(30000.00/1001, &m_mfxVppParams.vpp.In.FrameRateExtN, &m_mfxVppParams.vpp.In.FrameRateExtD);
// width must be a multiple of 16
// height must be a multiple of 16 in case of frame picture and a multiple of 32 in case of field picture
m_mfxVppParams.vpp.In.Width = MSDK_ALIGN16(pInParams->nWidth);
m_mfxVppParams.vpp.In.Height = (MFX_PICSTRUCT_PROGRESSIVE == m_mfxVppParams.vpp.In.PicStruct)?
MSDK_ALIGN16(pInParams->nHeight) : MSDK_ALIGN32(pInParams->nHeight);
// set crops in input mfxFrameInfo for correct work of file reader
// VPP itself ignores crops at initialization
m_mfxVppParams.vpp.In.CropW = pInParams->nWidth;
m_mfxVppParams.vpp.In.CropH = pInParams->nHeight;
// fill output frame info
memcpy(&m_mfxVppParams.vpp.Out, &m_mfxVppParams.vpp.In, sizeof(mfxFrameInfo));
m_mfxVppParams.vpp.Out.FourCC=MFX_FOURCC_NV12;
m_mfxVppParams.vpp.Out.PicStruct=MFX_PICSTRUCT_PROGRESSIVE;
// only resizing is supported
m_mfxVppParams.vpp.Out.Width = MSDK_ALIGN16(pInParams->nDstWidth);
m_mfxVppParams.vpp.Out.Height = (MFX_PICSTRUCT_PROGRESSIVE == m_mfxVppParams.vpp.Out.PicStruct)?
MSDK_ALIGN16(pInParams->nDstHeight) : MSDK_ALIGN32(pInParams->nDstHeight);
// configure and attach external parameters
AllocAndInitVppDoNotUse();
m_VppExtParams.push_back((mfxExtBuffer *)&m_VppDoNotUse);
if (pInParams->bIsMVC)
m_VppExtParams.push_back((mfxExtBuffer *)&m_MVCSeqDesc);
m_mfxVppParams.ExtParam = &m_VppExtParams[0]; // vector is stored linearly in memory
m_mfxVppParams.NumExtParam = (mfxU16)m_VppExtParams.size();
return MFX_ERR_NONE;
debug mem info like this:
- In {reserved=0x002dd7ec FrameId={...} FourCC=844715353 ...} mfxFrameInfo
+ reserved 0x002dd7ec unsigned int [6]
+ FrameId {TemporalId=0 PriorityId=0 DependencyId=0 ...} mfxFrameId
FourCC 844715353 unsigned int
Width 1920 unsigned short
Height 1088 unsigned short
CropX 0 unsigned short
CropY 0 unsigned short
CropW 1920 unsigned short
CropH 1080 unsigned short
FrameRateExtN 30000 unsigned int
FrameRateExtD 1001 unsigned int
reserved3 0 unsigned short
AspectRatioW 0 unsigned short
AspectRatioH 0 unsigned short
PicStruct 2 unsigned short
ChromaFormat 0 unsigned short
reserved2 0 unsigned short
- Out {reserved=0x002dd830 FrameId={...} FourCC=842094158 ...} mfxFrameInfo
+ reserved 0x002dd830 unsigned int [6]
FourCC 842094158 unsigned int
PicStruct 1 unsigned short
Jin_Shuyang
the error has been resolved . because of m_mfxEncParams.mfx.FrameInfo.PicStruct is set to interlaced . So, interlace->vpp->PROGRESSIVE -> encoder->interlace .
Petter_L_Intel
Hi Jin,
Thanks for updating us on the status. It saved us tome time having to look into the issue.
Glad you got it to work.
Petter
zhengbinham
Hi, Jin Shuyang, I have been writing an app for converting rgb4 to nv12, but error occurs, could you give me your app code? I will use it as a reference.Thank you .I am looking forward to your reply, my email address is zb_adventure@yahoo.com.cn.
