I written a small app. The app use the capture card grab video frames (yuy2,interlace,29.97fps) into the mem and use media sdk to encode it .
I want to sdk alter yuy2 to nv12 and deinterlace . alter yuy2 to nv12 is ok , but deinterlacing, i got the warning "MFX_WRN_INCOMPATIBLE_VIDEO_PARAM" ,the frames is still interlaced. the code like this:
m_mfxVppParams.IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY | MFX_IOPATTERN_OUT_SYSTEM_MEMORY;
m_mfxVppParams.vpp.In.FourCC=MFX_FOURCC_YUY2;
m_mfxVppParams.vpp.In.PicStruct = MFX_PICSTRUCT_FIELD_TFF;
ConvertFrameRate(30000.00/1001, &m_mfxVppParams.vpp.In.FrameRateExtN, &m_mfxVppParams.vpp.In.FrameRateExtD);
// width must be a multiple of 16
// height must be a multiple of 16 in case of frame picture and a multiple of 32 in case of field picture
m_mfxVppParams.vpp.In.Width = MSDK_ALIGN16(pInParams->nWidth);
m_mfxVppParams.vpp.In.Height = (MFX_PICSTRUCT_PROGRESSIVE == m_mfxVppParams.vpp.In.PicStruct)?
MSDK_ALIGN16(pInParams->nHeight) : MSDK_ALIGN32(pInParams->nHeight);
// set crops in input mfxFrameInfo for correct work of file reader
// VPP itself ignores crops at initialization
m_mfxVppParams.vpp.In.CropW = pInParams->nWidth;
m_mfxVppParams.vpp.In.CropH = pInParams->nHeight;
// fill output frame info
memcpy(&m_mfxVppParams.vpp.Out, &m_mfxVppParams.vpp.In, sizeof(mfxFrameInfo));
m_mfxVppParams.vpp.Out.FourCC=MFX_FOURCC_NV12;
m_mfxVppParams.vpp.Out.PicStruct=MFX_PICSTRUCT_PROGRESSIVE;
// only resizing is supported
m_mfxVppParams.vpp.Out.Width = MSDK_ALIGN16(pInParams->nDstWidth);
m_mfxVppParams.vpp.Out.Height = (MFX_PICSTRUCT_PROGRESSIVE == m_mfxVppParams.vpp.Out.PicStruct)?
MSDK_ALIGN16(pInParams->nDstHeight) : MSDK_ALIGN32(pInParams->nDstHeight);
// configure and attach external parameters
AllocAndInitVppDoNotUse();
m_VppExtParams.push_back((mfxExtBuffer *)&m_VppDoNotUse);
if (pInParams->bIsMVC)
m_VppExtParams.push_back((mfxExtBuffer *)&m_MVCSeqDesc);
m_mfxVppParams.ExtParam = &m_VppExtParams[0]; // vector is stored linearly in memory
m_mfxVppParams.NumExtParam = (mfxU16)m_VppExtParams.size();
return MFX_ERR_NONE;
debug mem info like this:
- In {reserved=0x002dd7ec FrameId={...} FourCC=844715353 ...} mfxFrameInfo
+ reserved 0x002dd7ec unsigned int [6]
+ FrameId {TemporalId=0 PriorityId=0 DependencyId=0 ...} mfxFrameId
FourCC 844715353 unsigned int
Width 1920 unsigned short
Height 1088 unsigned short
CropX 0 unsigned short
CropY 0 unsigned short
CropW 1920 unsigned short
CropH 1080 unsigned short
FrameRateExtN 30000 unsigned int
FrameRateExtD 1001 unsigned int
reserved3 0 unsigned short
AspectRatioW 0 unsigned short
AspectRatioH 0 unsigned short
PicStruct 2 unsigned short
ChromaFormat 0 unsigned short
reserved2 0 unsigned short
- Out {reserved=0x002dd830 FrameId={...} FourCC=842094158 ...} mfxFrameInfo
+ reserved 0x002dd830 unsigned int [6]
FourCC 842094158 unsigned int
PicStruct 1 unsigned short
Thanks for updating us on the status. It saved us tome time having to look into the issue.
Glad you got it to work.
