when encoding H264 video, the lookahead rate control method can improve the encoding quality . So I want to encode h265 video file in lookahead mode too.
I don't know how to use the LA mode for h265 encoding. I think the la_ext is the implementation for h265 LA mode., so my command line is :
./sample_multi_transcode -i::h265 input.265 -o::h265 out.hevc -b 3000 -w 1920 -h 1080 -u 4 -lad 100 -la_ext
The result is:
Multi Transcoding Sample Version 8.4.27.
libva info: VA-API version 1.0.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_0
libva info: va_openDriver() returns 0
Session 0:
plugin_loader.h :185 [INFO] Plugin was loaded from GUID: { 0x58, 0x8f, 0x11, 0x85, 0xd4, 0x7b, 0x42, 0x96, 0x8d, 0xea, 0x37, 0x7b, 0xb5, 0xd0, 0xdc, 0xb4 } (Intel (R) Media SDK plugin for LA ENC)
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), EncodePreInit, m_pmfxENC->Query failed at /home/lpb/git_hub/MediaSDK/samples/sample_multi_transcode/src/pipeline_transcode.cpp:461
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), Init, EncodePreInit failed at /home/lpb/git_hub/MediaSDK/samples/sample_multi_transcode/src/pipeline_transcode.cpp:3721
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), Init, pThreadPipeline->pPipeline->Init failed at /home/lpb/git_hub/MediaSDK/samples/sample_multi_transcode/src/sample_multi_transcode.cpp:442
plugin_loader.h :211 [INFO] MFXBaseUSER_UnLoad(session=0x0x56331c850c50), sts=0
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), main, transcode.Init failed at /home/lpb/git_hub/MediaSDK/samples/sample_multi_transcode/src/sample_multi_transcode.cpp:1169
My CPU is i7-6700HQ. API version is 1.28. Libva version is 1.0
So how to encode h265 in lookahead mode? And whether my CPU and the driver version support the h265 LA mode?
- Tags:
- Development Tools
- Graphics
- Intel® Media SDK
- Intel® Media Server Studio
- Media Processing
- Optimization
Hi XueLou,
It looks like you were failed on the plugin loading. Are you trying to use external LA or the default LA?
This error line explained:
/home/lpb/git_hub/MediaSDK/samples/sample_multi_transcode/src/sample_multi_transcode.cpp:442 plugin_loader.h :211 [INFO] MFXBaseUSER_UnLoad(session=0x0x56331c850c50), sts=0
This is the actual code:
The document didn't say support HEVC by default but I believe you could pass this error if you use H.264 and without "-la_ext" argument, then try to use HEVC without "-la_ext"
If still not working, please use command "strace ./sample_multi_transcode -i::h265 input.265 -o::h265 out.hevc -b 3000 -w 1920 -h 1080 -u 4 -lad 100 -la_ext" to check why the plugin can not being loaded.
Mark
