Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3058 Discussions
how to use HW MFX Video Encoder when intel is not a primary GPU device
jachu19
My setup is:
- intel core i5 2300
- nVidia GF 9500GT
- windows 7 64bit
setup 1: when intel GPU is a primary device, MFX Video Encoder uses Intel Quick Sync Video technology, but games works on intel instead of stronger nVidia. I have to restart PC to switch GPU in BIOS.
setup 2: when nVidia GPU is a primary device, games perfoms fine, but MFX does not init.
Function MFXInit(MFX_IMPL_HARDWARE, ver. 1.1, session) returns MFX_ERR_UNSUPPORTED. Have to switch in BIOS again.
My question is:
is there a setup allowing to use Hardware Accelerated MFX Video Encoder when nVidia is a primary GPU?
What should be system configuration. What should be done in software before calling MFX API (I'm a developer) to make MFXInit work. MFXInit does not take d3ddevice handle, so I can not do much.
Please note, that when intel is a primary GPU nvidia HW encoder based on CUDA works just fine. So I suppose there should be a way to make MFX working.
regards,
MJ
Nina_K_Intel
Hi MJ,
Please try MFXInit(MFX_IMPL_HARDWARE_ANY, ver, session) - with MFX_IMPL_HARDWARE_ANYimplementation type the function will search for a HW Media SDK implementation on all available graphic adapters including the default one.
Please check mediasdk_man.pdf "mfxIMPL" enumerator description for other possible initialization instructions.
Nina
Nina_K_Intel
Hi MJ,
Nina
jachu19
MFX_IMPL_HARDWARE_ANY solves the problem, thanks
