recently, I use intel media sdk 2014, test decode performance,
I use sample_decode_drm to test i3-3110M and i7-3615QE's performance
os:ubuntu12.04 kernal 3.2
but, on the cpu i3-3110M sample_decode_drm can decode 18 way real-time decode
on the cpu i7-3615QE it can only decode 15 way real-time decode
what it's the matter?
Hi there,
This could be of multiple reasons, so few things to check here -
There could be an installation issue, if the i7 is not using Intel's implementation then there is a possibility to see the performance difference. However there is no easy way to find this on IVB. Can you re-install Media Server Studio 2014 on i7?
What is the input resolution of your videos? How are you measuring multiple decode performance?
Are you writing the o/p to disk? If yes, can you please please change the code to not write the o/p and measure the performance then. The writing speed to disk could be different.
-Surbhi
P.S. We generally don't recommend using the decode sample for bench marking.
