Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3058 Discussions
libva vaInitialize failed in new thread created by pthread_create
jerry_l_
hi,
    i'm using msdk for linux server 2013 , the os is ubuntu 12.04 lts ,and the samples are building and running ok.
    now, i write a h264 decoder for my mutithreading programm, the decoder will be initialized in a new thread, and when create hardware device (drm mod), i got this error:
libva info: VA-API version 0.34.0
libva info: va_getDriverName() returns 1
vaInitialize failed
 While, if the decoder is not created in new thread, it's inialized ok
is there any problem like this  ??
or give me some tips ,3ks!!
Jeffrey_M_Intel1
Do you also see this problem when running as root?
jerry_l_
yes,it's running as root,and the thread attribute is same as the main thread,
can different mfx sessions use one vaapidevice instance when sethandle ?if so i can initialize the hard device instance at the main thread,and then use it in all new threads
