link libmfx.a: unrecognized relocation (0x2a) in section `.text`
blackjack__blackjack
version: MSS Community Edition 2018 R2
system:  Centos 7.4.1078(Core version 3.10.0-693.el7.x86_64)(cmake2.8.12)(binutils 2.25)(gcc 4.8.5)
double check installation:
run `vainfo | grep -v unknown` is OK
run `./sample_multi_transcode -i::h264 ../content/test_stream.h264 -o::h264 test_out.h264 -hw -la` from MediaSamples_Linux_bin*.tar.gz is OK
Mark_L_Intel1
Hi there,
Sorry for the late response, I wanted to help you but got busy with other project.
The error you report seems not related to Media SDK but the environment of your system, see the following post:
https://stackoverflow.com/questions/46058050/unable-to-compile-unrecognized-relocation
Did you do more investigation after you post?
Here is your original post since it missed here:
when build the samples of  Media Server Studio 2018 R2 on Centos 7.4.1078(Core version 3.10.0-693.el7.x86_64)(cmake2.8.12)(binutils 2.25)(gcc 4.8.5), it occurs  error:
/usr/bin/ld: /opt/intel/mediasdk/lib/lin_x64/libmfx.a(main.cpp.o): unrecognized relocation (0x2a) in section '.text'
Mark
Li__Chance
Hi Liu, Mark:
I encountered the exactly same problem on Centos 7.4.1078.
Can you share the environment libmfx.a is built from INTEL,
Maybe the versions of the build tools in Centos 7.4 is not compatible to INTEL's.
Thank you.
