Can you help me to fix this problem, please?
I want to try for ‘h.264 4Kx4K@30 encoder ‘ and ‘h.264 4Kx2K@60 encoder’ on Apollo Lake CRB(Oxbow hill rev B).
I download the file by Intel website.
https://software.intel.com/en-us/intel-media-server-studio/code-samples
Download Tutorial packages → Windows package → Download the “mediasdk-tutorials-0.03.zip”
I create a Visual Studio Community 2015 project and use sample code " simple_encode " to build this project.
- VS2015 show error ::
1> ------ Started construction: Project: simple_encode, Configuration: Debug Win32 ------
1> simple_encode.cpp
1> common_utils_windows.cpp
1: c: \ apollosample \ mediasdk-tutorials-0.0.3 \ mediasdk-tutorials-0.0.3 \ common \ common_utils_windows.cpp (25): error C2220: Treat warning as error - no 'object' file
1> c: \ apollosample \ mediasdk-tutorials-0.0.3 \ mediasdk-tutorials-0.0.3 \ common \ common_utils_windows.cpp (25): warning C4100: 'bCreateSharedHandles': Unreferenced Type Parameters
1> c: \ apollosample \ mediasdk-tutorials-0.0.3 \ mediasdk-tutorials-0.0.3 \ common \ common_utils_windows.cpp (25): warning C4100: 'pmfxAllocator': Unreferenced Type Parameters
1: c: \ apollosample \ mediasdk-tutorials-0.0.3 \ mediasdk-tutorials-0.0.3 \ common \ common_utils_windows.cpp (87): warning C4100: 'memId': Unreferenced Type Parameters
1: c: \ apollosample \ mediasdk-tutorials-0.0.3 \ mediasdk-tutorials-0.0.3 \ common \ common_utils_windows.cpp (94): warning C4100: 'memId': Unreferenced Type Parameters
1> common_utils.cpp
1> cmd_options.cpp
(84): error C2220: Treat warnings as error handling - no 'object' file is generated (1) c: \ apollosample \ mediasdk-tutorials-0.0.3 \ mediasdk-tutorials-0.0.3 \ common \ cmd_options.cpp
1> c: \ apollosample \ mediasdk-tutorials-0.0.3 \ mediasdk-tutorials-0.0.3 \ common \ cmd_options.cpp (84): warning C4996: 'sscanf': This function or variable may be unsafe. Consider using sscanf_s Instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
1> c: \ program files (x86) \ windows kits \ 10 \ include \ 10.0.10240.0 \ ucrt \ stdio.h (2254): note: See the declaration of 'sscanf'
1> c: \ apollosample \ mediasdk-tutorials-0.0.3 \ mediasdk-tutorials-0.0.3 \ common \ cmd_options.cpp (108): warning C4996: 'sscanf': This function or variable may be unsafe. Consider using sscanf_s Instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
1> c: \ apollosample \ mediasdk-tutorials-0.0.3 \ mediasdk-tutorials-0.0.3 \ common \ cmd_options.cpp (warning) C4996: 'strcpy': This function or variable may be unsafe. Consider using strcpy_s Instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
1> c: \ program files (x86) \ windows kits \ 10 \ include \ 10.0.10240.0 \ ucrt \ string.h (119): note: See the declaration of 'strcpy'
1> c: \ apollosample \ mediasdk-tutorials-0.0.3 \ mediasdk-tutorials-0.0.3 \ common \ cmd_options.cpp (warning): C4996: warning C4996: 'strcpy': This function or variable may be unsafe. Consider using strcpy_s Instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
1> Generating code ...
========== Build: 0 Success, 1 Failure, 0 Latest, 0 Skip ==========
※If I close the ” Treat Warning As Errors”.
(Debug → Property → C/C++ → Treat Warning As Errors → No /WX-)
②VS2015 show error ::
1> LINK: fatal error LNK1104: Cannot open file 'libmfx.lib'
========== Build: 0 success, 1 failure, 0 latest, 0 skip ==========
My platform:: win10
Microsoft Visual Studio Professional 2015
Version 14.0.25431.01 Update 3
Best Regards
Hi Joanne,
I think you have solved the first issue, for the second one, it is a link issue, can you check if the environment variable INTELMEDIASDKROOT is point to the directory where your Media SDK is installed. It looks like an environment issue.
Mark
Hello Mark,
Sorry, I did not see the message.
I am downloading everything and try to build up environment.
Can you teach me how to use this Sample code?
Or some user guide in detail?
Thank you very much =)
Hi Jonne,
Are you asking how to use simple_encode.exe?
You can try followings:
> simple_encode.exe -g WxH -b [bitrate] -f [frame rate] -hw [input file] [output file]
frame rate must be a format with "nominator/denominator".
the input file has the YUV format
the output file will be h.264 format
Run "simple_encode.exe --help" for the details
Note also the data file must be the elementary stream, it can't parse the media container (mp4 for example) for you.
Mark
