Where can I find documentation about lookahead rate control support on various platforms? It works fine on my Haswell HW 1.11 system but is apparently not supported on my Ivy Bridge HW 1.10 system. The reference doc says it should be supported from 1.7 or 1.8 I believe.
The failure is MFXVideoENCODE->Init() returns -15 MFX_ERR_INVALID_VIDEO_PARAM when I ask for lookahead. I'm running the same code on the two machines.
My Ivy Bridge system has:
Graphics Devices:
Name Version State
Intel(R) HD Graphics 4000 10.18.10.3621 Active
AMD Radeon R9 200 Series 14.100.0.0 08
System info:
CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
OS: Microsoft Windows 8.1 Pro
Arch: 64-bit
Installed Media SDK packages (be patient...processing takes some time):
Intel« Media SDK 2014 R2 for Clients (x64)
Hi Ryan,
The reason for not Look ahead mode not working on Ivy Bridge is because it is not supported. From the development guide :
There are some limitations to LA that need to be noted for the Intel Media SDK 2014 release:
- Look Ahead is only available on Intel® Iris™ Pro Graphics, Intel® Iris™ Graphics and Intel®
HD Graphics (4200+ Series)
-Surbhi
