I am trying to create a simple "hello world" sort of program with the Media SDK to encode a small H264 stream.
I have not been able to figure out why `MFXVideoENCODE_Init` returns MFX_ERR_INVALID_VIDEO_PARAM and I tried to use the mediasdk tracer to figure out the illegal parameter(s) but it only tells me the return value.
Source:
#include <malloc.h> #include <stdio.h> #include <string.h> #include <mfxvideo.h> #define null ((void*)0) #define WIDTH 640 #define HEIGHT 480 /* MFXVideoENCODE_QueryIOSurf(session, &init_param, &request); allocate_pool_of_frame_surfaces(request.NumFrameSuggested); MFXVideoENCODE_Init(session, &init_param); sts=MFX_ERR_MORE_DATA; for (;;) { if (sts==MFX_ERR_MORE_DATA && !end_of_stream()) { find_unlocked_surface_from_the_pool(&surface); fill_content_for_encoding(surface); } surface2=end_of_stream() ? NULL : surface; sts = MFXVideoENCODE_EncodeFrameAsync(session, NULL, surface2, bits, &syncp); if (end_of_stream() && sts == MFX_ERR_MORE_DATA) break; … // other error handling if (sts==MFX_ERR_NONE) { MFXVideoCORE_SyncOperation(session, syncp, INFINITE); do_something_with_encoded_bits(bits); } } MFXVideoENCODE_Close(); free_pool_of_frame_surfaces(); */ int main(){ mfxSession session; if (MFXInit( MFX_IMPL_AUTO, null, &session ) != MFX_ERR_NONE) { printf("Failed to init MFX\n"); return 1; } mfxVideoParam videoParam; mfxFrameAllocRequest frameAllocationRequest; memset(&videoParam, 0, sizeof(mfxVideoParam)); videoParam.AllocId = 1; videoParam.IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY | MFX_IOPATTERN_OUT_SYSTEM_MEMORY; videoParam.mfx.CodecId = MFX_CODEC_AVC; videoParam.mfx.TargetKbps = 6000; videoParam.mfx.EncodedOrder = 1; videoParam.mfx.FrameInfo.FourCC = MFX_FOURCC_RGB4; videoParam.mfx.FrameInfo.Width = WIDTH; videoParam.mfx.FrameInfo.Height = HEIGHT; videoParam.mfx.FrameInfo.CropX = 0; videoParam.mfx.FrameInfo.CropY = 0; videoParam.mfx.FrameInfo.CropW = WIDTH; videoParam.mfx.FrameInfo.CropH = HEIGHT; videoParam.mfx.FrameInfo.FrameRateExtN = 1; videoParam.mfx.FrameInfo.FrameRateExtD = 60; videoParam.mfx.FrameInfo.PicStruct = MFX_PICSTRUCT_PROGRESSIVE; videoParam.mfx.FrameInfo.ChromaFormat = MFX_CHROMAFORMAT_YUV420; if (MFXVideoENCODE_QueryIOSurf( session, &videoParam, &frameAllocationRequest ) != MFX_ERR_NONE) { printf("MFXVideoENCODE_QueryIOSurf failed\n"); MFXClose(session); return 1; } size_t frameSize = WIDTH * HEIGHT * 4; void** frameDataBuffer = malloc(sizeof(void*) * frameAllocationRequest.NumFrameSuggested); for (int i = 0; i < frameAllocationRequest.NumFrameSuggested; i++) { frameDataBuffer = malloc(frameSize); } if (MFXVideoENCODE_Init(session, &videoParam) != MFX_ERR_NONE) { printf("MFXVideoENCODE_Init failed\n"); MFXClose(session); return 1; } MFXClose(session); return 0; }
Here is the trace log:
11944 2018-6-3 17:43:35:905 function: DLLMain() DLL_PROCESS_ATTACH +
11944 2018-6-3 17:43:35:905 mfx_tracer: lib=none
11944 2018-6-3 17:43:35:905 function: DLLMain() DLL_PROCESS_ATTACH -
11944 2018-6-3 17:43:35:905 function: MFXInitEx(par.Implementation=MFX_IMPL_HARDWARE|MFX_IMPL_VIA_D3D9 par.Versin=000000BB134FDD64, mfxSession *session=00000252353FA2C0) +
11944 2018-6-3 17:43:35:905 LoadLibrary: none
11944 2018-6-3 17:43:35:906 MFXInitEx (impl=MFX_IMPL_HARDWARE|MFX_IMPL_VIA_D3D9, pVer=1.26, ExternalThreads=0 session=0x00000252353FA2C0
11944 2018-6-3 17:43:35:906 Required API version is 1.26
11944 2018-6-3 17:43:35:906 [WINREG]: Opening key "HKEY_CURRENT_USER\Software\Intel\MediaSDK\Dispatch" : RegOpenKeyExW()==0x2
11944 2018-6-3 17:43:35:906 Can't open HKEY_CURRENT_USER\Software\Intel\MediaSDK\Dispatch : RegOpenKeyExA()==0x0
11944 2018-6-3 17:43:35:929 Inspecting HKEY_LOCAL_MACHINE\Software\Intel\MediaSDK\Dispatch
11944 2018-6-3 17:43:35:929 found subkey: iIVB_0152
11944 2018-6-3 17:43:35:929 opened key: iIVB_0152
11944 2018-6-3 17:43:35:929 loaded VendorID : 0x8086
11944 2018-6-3 17:43:35:929 loaded DeviceID : 0x152
11944 2018-6-3 17:43:35:929 loaded Merit : 134217749
11944 2018-6-3 17:43:35:929 VendorID conflict, actual = 0x10de : required = 0x8086
11944 2018-6-3 17:43:35:929 found subkey: iIVB_0156
11944 2018-6-3 17:43:35:929 opened key: iIVB_0156
11944 2018-6-3 17:43:35:929 loaded DeviceID : 0x156
11944 2018-6-3 17:43:35:930 found subkey: iIVB_015A
11944 2018-6-3 17:43:35:930 opened key: iIVB_015A
11944 2018-6-3 17:43:35:930 loaded VendorID : 0x8086
11944 2018-6-3 17:43:35:930 loaded DeviceID : 0x15a
11944 2018-6-3 17:43:35:930 loaded Merit : 134217749
11944 2018-6-3 17:43:35:930 VendorID conflict, actual = 0x10de : required = 0x8086
11944 2018-6-3 17:43:35:930 found subkey: iIVB_0162
11944 2018-6-3 17:43:35:930 opened key: iIVB_0162
11944 2018-6-3 17:43:35:930 loaded DeviceID : 0x162
11944 2018-6-3 17:43:35:930 found subkey: iIVB_0166
11944 2018-6-3 17:43:35:930 opened key: iIVB_0166
11944 2018-6-3 17:43:35:930 loaded DeviceID : 0x166
11944 2018-6-3 17:43:35:930 found subkey: iIVB_016A
11944 2018-6-3 17:43:35:930 opened key: iIVB_016A
11944 2018-6-3 17:43:35:930 loaded DeviceID : 0x16a
11944 2018-6-3 17:43:35:930 found subkey: iVLV2_0F31
11944 2018-6-3 17:43:35:930 opened key: iVLV2_0F31
11944 2018-6-3 17:43:35:930 loaded DeviceID : 0xf31
11944 2018-6-3 17:43:35:930 found subkey: tracer
11944 2018-6-3 17:43:35:930 opened key: tracer
11944 2018-6-3 17:43:35:930 loaded VendorID : 0x10de
11944 2018-6-3 17:43:35:930 loaded DeviceID : 0x1401
11944 2018-6-3 17:43:35:930 loaded Merit : 2147483646
11944 2018-6-3 17:43:35:930 loaded Path : D:\Program Files (x86)\IntelSWTools\Intel(R) Media SDK 2018 R1\Software Development Kit\tools\mediasdk_tracer\mfx-tracer_64.dll
11944 2018-6-3 17:43:35:930 Library type is MFX_LIB_HARDWARE
11944 2018-6-3 17:43:35:931 [WINREG]: EnumKey with index=8: RegEnumKeyExW()==0x103
11944 2018-6-3 17:43:35:931 no more subkeys : RegEnumKeyExA()==0x0
11944 2018-6-3 17:43:35:931 loading library D:\Program Files (x86)\IntelSWTools\Intel(R) Media SDK 2018 R1\Software Development Kit\tools\mediasdk_tracer\mfx-tracer_64.dll
11944 2018-6-3 17:43:35:931 invoking LoadLibrary(D:\Program Files (x86)\IntelSWTools\Intel(R) Media SDK 2018 R1\Software Development Kit\tools\mediasdk_tracer\mfx-tracer_64.dll)
11944 2018-6-3 17:43:35:931 loaded module D:\Program Files (x86)\IntelSWTools\Intel(R) Media SDK 2018 R1\Software Development Kit\tools\mediasdk_tracer\mfx-tracer_64.dll
11944 2018-6-3 17:43:35:931 MFXInitEx(MFX_IMPL_HARDWARE|MFX_IMPL_VIA_D3D9,ver=1.26,ExtThreads=0,session=0x000002523540CD80)
11944 2018-6-3 17:43:35:931 library can't be load. MFXInit returned MFX_ERR_ABORTED
11944 2018-6-3 17:43:35:931 found subkey: iIVB_0152
11944 2018-6-3 17:43:35:931 opened key: iIVB_0152
11944 2018-6-3 17:43:35:931 loaded VendorID : 0x8086
11944 2018-6-3 17:43:35:931 loaded DeviceID : 0x152
11944 2018-6-3 17:43:35:931 loaded Merit : 134217749
11944 2018-6-3 17:43:35:931 VendorID conflict, actual = 0x10de : required = 0x8086
11944 2018-6-3 17:43:35:931 found subkey: iIVB_0156
11944 2018-6-3 17:43:35:931 opened key: iIVB_0156
11944 2018-6-3 17:43:35:931 loaded DeviceID : 0x156
11944 2018-6-3 17:43:35:931 found subkey: iIVB_015A
11944 2018-6-3 17:43:35:931 opened key: iIVB_015A
11944 2018-6-3 17:43:35:931 loaded DeviceID : 0x15a
11944 2018-6-3 17:43:35:931 found subkey: iIVB_0162
11944 2018-6-3 17:43:35:931 opened key: iIVB_0162
11944 2018-6-3 17:43:35:931 loaded DeviceID : 0x162
11944 2018-6-3 17:43:35:931 found subkey: iIVB_0166
11944 2018-6-3 17:43:35:931 opened key: iIVB_0166
11944 2018-6-3 17:43:35:932 loaded DeviceID : 0x166
11944 2018-6-3 17:43:35:932 loaded Merit : 134217749
11944 2018-6-3 17:43:35:932 VendorID conflict, actual = 0x10de : required = 0x8086
11944 2018-6-3 17:43:35:932 found subkey: iIVB_016A
11944 2018-6-3 17:43:35:932 opened key: iIVB_016A
11944 2018-6-3 17:43:35:932 loaded VendorID : 0x8086
11944 2018-6-3 17:43:35:932 loaded DeviceID : 0x16a
11944 2018-6-3 17:43:35:932 found subkey: iVLV2_0F31
11944 2018-6-3 17:43:35:932 opened key: iVLV2_0F31
11944 2018-6-3 17:43:35:932 loaded DeviceID : 0xf31
11944 2018-6-3 17:43:35:932 found subkey: tracer
11944 2018-6-3 17:43:35:932 opened key: tracer
11944 2018-6-3 17:43:35:932 loaded VendorID : 0x10de
11944 2018-6-3 17:43:35:932 loaded DeviceID : 0x1401
11944 2018-6-3 17:43:35:932 loaded Merit : 2147483646
11944 2018-6-3 17:43:35:932 merit conflict: lastMerit = 0x7ffffffe, requiredMerit = 0x7ffffffe, libraryMerit = 0x0, lastindex = 7, index = 7
11944 2018-6-3 17:43:35:932 [WINREG]: EnumKey with index=8: RegEnumKeyExW()==0x103
11944 2018-6-3 17:43:35:932 no more subkeys : RegEnumKeyExA()==0x0
11944 2018-6-3 17:43:35:955 loading default library libmfxhw64.dll
11944 2018-6-3 17:43:35:979 ver.Major=1
11944 2018-6-3 17:43:35:979 ver.Minor=26
11944 2018-6-3 17:43:35:979 ver.Version=65562
11944 2018-6-3 17:43:35:988 mfxSession session=0000000000000000
11944 2018-6-3 17:43:35:988 status=MFX_ERR_NOT_FOUND
11944 2018-6-3 17:43:35:988 >> MFXInitEx called
11944 2018-6-3 17:43:35:988 par.Implementation=MFX_IMPL_HARDWARE|MFX_IMPL_VIA_D3D9
11944 2018-6-3 17:43:35:988 par.Version.Major=1
11944 2018-6-3 17:43:35:988 par.Version.Minor=26
11944 2018-6-3 17:43:35:988 par.Version.Version=65562
11944 2018-6-3 17:43:35:988 par.ExternalThreads=0
11944 2018-6-3 17:43:35:988 par.NumExtParam=0
11944 2018-6-3 17:43:35:988 par.ExtParam=0000000000000000
11944 2018-6-3 17:43:35:988 par.reserved2[]={ 0, 0, 0, 0, 0 }
11944 2018-6-3 17:43:35:988 par.GPUCopy=0
11944 2018-6-3 17:43:35:988 par.reserved[]={ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }11944 2018-6-3 17:43:35:988 mfxSession session=0000000000000000
11944 2018-6-3 17:43:35:988 function: MFXInitEx(82.71 msec, status=MFX_ERR_NOT_FOUND) -
11944 2018-6-3 17:43:35:988 function: MFXInitEx(par.Implementation=MFX_IMPL_SOFTWARE par.Versin=000000BB134FDD64, mfxSession *session=00000252353FA2C0) +
11944 2018-6-3 17:43:35:988 LoadLibrary: none
11944 2018-6-3 17:43:35:989 MFXInitEx (impl=MFX_IMPL_SOFTWARE, pVer=1.26, ExternalThreads=0 session=0x00000252353FA2C0
11944 2018-6-3 17:43:35:989 Required API version is 1.26
11944 2018-6-3 17:43:35:989 [WINREG]: Opening key "HKEY_CURRENT_USER\Software\Intel\MediaSDK\Dispatch" : RegOpenKeyExW()==0x2
11944 2018-6-3 17:43:35:989 Can't open HKEY_CURRENT_USER\Software\Intel\MediaSDK\Dispatch : RegOpenKeyExA()==0x0
11944 2018-6-3 17:43:35:989 Inspecting HKEY_LOCAL_MACHINE\Software\Intel\MediaSDK\Dispatch
11944 2018-6-3 17:43:35:989 found subkey: iIVB_0152
11944 2018-6-3 17:43:35:989 opened key: iIVB_0152
11944 2018-6-3 17:43:35:989 loaded VendorID : 0x8086
11944 2018-6-3 17:43:35:989 loaded DeviceID : 0x152
11944 2018-6-3 17:43:35:989 loaded Merit : 134217749
11944 2018-6-3 17:43:35:989 loaded Path : C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:35:989 Library type is MFX_LIB_HARDWARE
11944 2018-6-3 17:43:35:989 found subkey: iIVB_0156
11944 2018-6-3 17:43:35:989 opened key: iIVB_0156
11944 2018-6-3 17:43:35:989 loaded DeviceID : 0x156
11944 2018-6-3 17:43:35:989 merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 0, index = 1
11944 2018-6-3 17:43:35:989 found subkey: iIVB_015A
11944 2018-6-3 17:43:35:989 opened key: iIVB_015A
11944 2018-6-3 17:43:35:989 loaded DeviceID : 0x15a
11944 2018-6-3 17:43:35:989 merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 0, index = 2
11944 2018-6-3 17:43:35:989 found subkey: iIVB_0162
11944 2018-6-3 17:43:35:989 opened key: iIVB_0162
11944 2018-6-3 17:43:35:990 loaded VendorID : 0x8086
11944 2018-6-3 17:43:35:990 loaded DeviceID : 0x162
11944 2018-6-3 17:43:35:990 loaded Merit : 134217749
11944 2018-6-3 17:43:35:990 merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 0, index = 3
11944 2018-6-3 17:43:35:990 found subkey: iIVB_0166
11944 2018-6-3 17:43:35:990 opened key: iIVB_0166
11944 2018-6-3 17:43:35:990 loaded DeviceID : 0x166
11944 2018-6-3 17:43:35:990 merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 0, index = 4
11944 2018-6-3 17:43:35:990 found subkey: iIVB_016A
11944 2018-6-3 17:43:35:990 opened key: iIVB_016A
11944 2018-6-3 17:43:35:990 loaded DeviceID : 0x16a
11944 2018-6-3 17:43:35:990 merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 0, index = 5
11944 2018-6-3 17:43:35:990 found subkey: iVLV2_0F31
11944 2018-6-3 17:43:35:990 opened key: iVLV2_0F31
11944 2018-6-3 17:43:35:990 loaded DeviceID : 0xf31
11944 2018-6-3 17:43:35:990 merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 0, index = 6
11944 2018-6-3 17:43:35:990 found subkey: tracer
11944 2018-6-3 17:43:35:990 opened key: tracer
11944 2018-6-3 17:43:35:990 loaded VendorID : 0x10de
11944 2018-6-3 17:43:35:990 loaded DeviceID : 0x1401
11944 2018-6-3 17:43:35:990 loaded Merit : 2147483646
11944 2018-6-3 17:43:35:990 loaded Path : D:\Program Files (x86)\IntelSWTools\Intel(R) Media SDK 2018 R1\Software Development Kit\tools\mediasdk_tracer\mfx-tracer_64.dll
11944 2018-6-3 17:43:35:990 Library type is MFX_LIB_HARDWARE
11944 2018-6-3 17:43:35:991 [WINREG]: EnumKey with index=8: RegEnumKeyExW()==0x103
11944 2018-6-3 17:43:35:991 no more subkeys : RegEnumKeyExA()==0x0
11944 2018-6-3 17:43:35:991 loading library D:\Program Files (x86)\IntelSWTools\Intel(R) Media SDK 2018 R1\Software Development Kit\tools\mediasdk_tracer\mfx-tracer_64.dll
11944 2018-6-3 17:43:35:991 invoking LoadLibrary(D:\Program Files (x86)\IntelSWTools\Intel(R) Media SDK 2018 R1\Software Development Kit\tools\mediasdk_tracer\mfx-tracer_64.dll)
11944 2018-6-3 17:43:35:991 loaded module D:\Program Files (x86)\IntelSWTools\Intel(R) Media SDK 2018 R1\Software Development Kit\tools\mediasdk_tracer\mfx-tracer_64.dll
11944 2018-6-3 17:43:35:991 MFXInitEx(MFX_IMPL_SOFTWARE,ver=1.26,ExtThreads=0,session=0x00000252354AEFB0)
11944 2018-6-3 17:43:35:991 library can't be load. MFXInit returned MFX_ERR_ABORTED
11944 2018-6-3 17:43:35:991 found subkey: iIVB_0152
11944 2018-6-3 17:43:35:991 opened key: iIVB_0152
11944 2018-6-3 17:43:35:991 loaded VendorID : 0x8086
11944 2018-6-3 17:43:35:991 loaded DeviceID : 0x152
11944 2018-6-3 17:43:35:991 loaded Merit : 134217749
11944 2018-6-3 17:43:35:991 loaded Path : C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:35:991 Library type is MFX_LIB_HARDWARE
11944 2018-6-3 17:43:35:991 found subkey: iIVB_0156
11944 2018-6-3 17:43:35:991 opened key: iIVB_0156
11944 2018-6-3 17:43:35:991 loaded DeviceID : 0x156
11944 2018-6-3 17:43:35:991 merit conflict: lastMerit = 0x7ffffffe, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 7, index = 1
11944 2018-6-3 17:43:35:991 found subkey: iIVB_015A
11944 2018-6-3 17:43:35:991 opened key: iIVB_015A
11944 2018-6-3 17:43:35:991 loaded DeviceID : 0x15a
11944 2018-6-3 17:43:35:991 merit conflict: lastMerit = 0x7ffffffe, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 7, index = 2
11944 2018-6-3 17:43:35:991 found subkey: iIVB_0162
11944 2018-6-3 17:43:35:991 opened key: iIVB_0162
11944 2018-6-3 17:43:35:991 loaded DeviceID : 0x162
11944 2018-6-3 17:43:35:991 merit conflict: lastMerit = 0x7ffffffe, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 7, index = 3
11944 2018-6-3 17:43:35:991 found subkey: iIVB_0166
11944 2018-6-3 17:43:35:992 opened key: iIVB_0166
11944 2018-6-3 17:43:35:992 loaded VendorID : 0x8086
11944 2018-6-3 17:43:35:992 loaded DeviceID : 0x166
11944 2018-6-3 17:43:35:992 loaded Merit : 134217749
11944 2018-6-3 17:43:35:992 merit conflict: lastMerit = 0x7ffffffe, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 7, index = 4
11944 2018-6-3 17:43:35:992 found subkey: iIVB_016A
11944 2018-6-3 17:43:35:992 opened key: iIVB_016A
11944 2018-6-3 17:43:35:992 loaded DeviceID : 0x16a
11944 2018-6-3 17:43:35:992 merit conflict: lastMerit = 0x7ffffffe, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 7, index = 5
11944 2018-6-3 17:43:35:992 found subkey: iVLV2_0F31
11944 2018-6-3 17:43:35:992 opened key: iVLV2_0F31
11944 2018-6-3 17:43:35:992 loaded DeviceID : 0xf31
11944 2018-6-3 17:43:35:992 merit conflict: lastMerit = 0x7ffffffe, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 7, index = 6
11944 2018-6-3 17:43:35:992 found subkey: tracer
11944 2018-6-3 17:43:35:992 opened key: tracer
11944 2018-6-3 17:43:35:992 loaded VendorID : 0x10de
11944 2018-6-3 17:43:35:992 loaded DeviceID : 0x1401
11944 2018-6-3 17:43:35:992 loaded Merit : 2147483646
11944 2018-6-3 17:43:35:992 merit conflict: lastMerit = 0x7ffffffe, requiredMerit = 0x7ffffffe, libraryMerit = 0x8000015, lastindex = 7, index = 7
11944 2018-6-3 17:43:35:992 [WINREG]: EnumKey with index=8: RegEnumKeyExW()==0x103
11944 2018-6-3 17:43:35:992 no more subkeys : RegEnumKeyExA()==0x0
11944 2018-6-3 17:43:35:992 loading library C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:35:992 invoking LoadLibrary(C:\Program Files\Intel\Media SDK\libmfxhw64.dll)
11944 2018-6-3 17:43:35:995 loaded module C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:35:995 Can't find API function "MFXInitEx"
11944 2018-6-3 17:43:35:995 Can't find API function "MFXVideoPAK_Query"
11944 2018-6-3 17:43:35:995 "MFXVideoPAK_Query" is required for API 1.26
11944 2018-6-3 17:43:35:995 found subkey: iIVB_0152
11944 2018-6-3 17:43:35:995 opened key: iIVB_0152
11944 2018-6-3 17:43:35:995 loaded VendorID : 0x8086
11944 2018-6-3 17:43:35:995 loaded DeviceID : 0x152
11944 2018-6-3 17:43:35:995 loaded Merit : 134217749
11944 2018-6-3 17:43:35:995 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 0, index = 0
11944 2018-6-3 17:43:35:995 found subkey: iIVB_0156
11944 2018-6-3 17:43:35:995 opened key: iIVB_0156
11944 2018-6-3 17:43:35:996 loaded VendorID : 0x8086
11944 2018-6-3 17:43:35:996 loaded DeviceID : 0x156
11944 2018-6-3 17:43:35:996 loaded Merit : 134217749
11944 2018-6-3 17:43:35:996 loaded Path : C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:35:996 Library type is MFX_LIB_HARDWARE
11944 2018-6-3 17:43:35:996 found subkey: iIVB_015A
11944 2018-6-3 17:43:35:996 opened key: iIVB_015A
11944 2018-6-3 17:43:35:996 loaded DeviceID : 0x15a
11944 2018-6-3 17:43:35:996 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 0, index = 2
11944 2018-6-3 17:43:35:996 found subkey: iIVB_0162
11944 2018-6-3 17:43:35:996 opened key: iIVB_0162
11944 2018-6-3 17:43:35:996 loaded DeviceID : 0x162
11944 2018-6-3 17:43:35:996 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 0, index = 3
11944 2018-6-3 17:43:35:996 found subkey: iIVB_0166
11944 2018-6-3 17:43:35:996 opened key: iIVB_0166
11944 2018-6-3 17:43:35:996 loaded DeviceID : 0x166
11944 2018-6-3 17:43:35:996 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 0, index = 4
11944 2018-6-3 17:43:35:996 found subkey: iIVB_016A
11944 2018-6-3 17:43:35:996 opened key: iIVB_016A
11944 2018-6-3 17:43:35:996 loaded DeviceID : 0x16a
11944 2018-6-3 17:43:35:996 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 0, index = 5
11944 2018-6-3 17:43:35:996 found subkey: iVLV2_0F31
11944 2018-6-3 17:43:35:996 opened key: iVLV2_0F31
11944 2018-6-3 17:43:35:996 loaded DeviceID : 0xf31
11944 2018-6-3 17:43:35:996 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 0, index = 6
11944 2018-6-3 17:43:35:996 found subkey: tracer
11944 2018-6-3 17:43:35:996 opened key: tracer
11944 2018-6-3 17:43:35:997 loaded VendorID : 0x10de
11944 2018-6-3 17:43:35:997 loaded DeviceID : 0x1401
11944 2018-6-3 17:43:35:997 loaded Merit : 2147483646
11944 2018-6-3 17:43:35:997 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x7ffffffe, libraryMerit = 0x8000015, lastindex = 0, index = 7
11944 2018-6-3 17:43:35:997 [WINREG]: EnumKey with index=8: RegEnumKeyExW()==0x103
11944 2018-6-3 17:43:35:997 no more subkeys : RegEnumKeyExA()==0x0
11944 2018-6-3 17:43:35:997 loading library C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:35:997 invoking LoadLibrary(C:\Program Files\Intel\Media SDK\libmfxhw64.dll)
11944 2018-6-3 17:43:35:999 loaded module C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:35:999 Can't find API function "MFXInitEx"
11944 2018-6-3 17:43:35:999 Can't find API function "MFXVideoPAK_Query"
11944 2018-6-3 17:43:35:999 "MFXVideoPAK_Query" is required for API 1.26
11944 2018-6-3 17:43:35:999 found subkey: iIVB_0152
11944 2018-6-3 17:43:35:999 opened key: iIVB_0152
11944 2018-6-3 17:43:35:999 loaded VendorID : 0x8086
11944 2018-6-3 17:43:35:999 loaded DeviceID : 0x152
11944 2018-6-3 17:43:35:999 loaded Merit : 134217749
11944 2018-6-3 17:43:35:999 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 1, index = 0
11944 2018-6-3 17:43:35:999 found subkey: iIVB_0156
11944 2018-6-3 17:43:35:999 opened key: iIVB_0156
11944 2018-6-3 17:43:35:999 loaded DeviceID : 0x156
11944 2018-6-3 17:43:35:999 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 1, index = 1
11944 2018-6-3 17:43:36:0 found subkey: iIVB_015A
11944 2018-6-3 17:43:36:0 opened key: iIVB_015A
11944 2018-6-3 17:43:36:0 loaded VendorID : 0x8086
11944 2018-6-3 17:43:36:0 loaded DeviceID : 0x15a
11944 2018-6-3 17:43:36:0 loaded Merit : 134217749
11944 2018-6-3 17:43:36:0 loaded Path : C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:36:0 Library type is MFX_LIB_HARDWARE
11944 2018-6-3 17:43:36:0 found subkey: iIVB_0162
11944 2018-6-3 17:43:36:0 opened key: iIVB_0162
11944 2018-6-3 17:43:36:0 loaded DeviceID : 0x162
11944 2018-6-3 17:43:36:0 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 1, index = 3
11944 2018-6-3 17:43:36:0 found subkey: iIVB_0166
11944 2018-6-3 17:43:36:0 opened key: iIVB_0166
11944 2018-6-3 17:43:36:0 loaded DeviceID : 0x166
11944 2018-6-3 17:43:36:0 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 1, index = 4
11944 2018-6-3 17:43:36:0 found subkey: iIVB_016A
11944 2018-6-3 17:43:36:0 opened key: iIVB_016A
11944 2018-6-3 17:43:36:0 loaded DeviceID : 0x16a
11944 2018-6-3 17:43:36:0 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 1, index = 5
11944 2018-6-3 17:43:36:0 found subkey: iVLV2_0F31
11944 2018-6-3 17:43:36:0 opened key: iVLV2_0F31
11944 2018-6-3 17:43:36:0 loaded DeviceID : 0xf31
11944 2018-6-3 17:43:36:0 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 1, index = 6
11944 2018-6-3 17:43:36:0 found subkey: tracer
11944 2018-6-3 17:43:36:0 opened key: tracer
11944 2018-6-3 17:43:36:0 loaded VendorID : 0x10de
11944 2018-6-3 17:43:36:0 loaded DeviceID : 0x1401
11944 2018-6-3 17:43:36:0 loaded Merit : 2147483646
11944 2018-6-3 17:43:36:0 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x7ffffffe, libraryMerit = 0x8000015, lastindex = 1, index = 7
11944 2018-6-3 17:43:36:1 [WINREG]: EnumKey with index=8: RegEnumKeyExW()==0x103
11944 2018-6-3 17:43:36:1 no more subkeys : RegEnumKeyExA()==0x0
11944 2018-6-3 17:43:36:1 loading library C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:36:1 invoking LoadLibrary(C:\Program Files\Intel\Media SDK\libmfxhw64.dll)
11944 2018-6-3 17:43:36:3 loaded module C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:36:3 Can't find API function "MFXInitEx"
11944 2018-6-3 17:43:36:3 Can't find API function "MFXVideoPAK_Query"
11944 2018-6-3 17:43:36:3 "MFXVideoPAK_Query" is required for API 1.26
11944 2018-6-3 17:43:36:3 found subkey: iIVB_0152
11944 2018-6-3 17:43:36:3 opened key: iIVB_0152
11944 2018-6-3 17:43:36:3 loaded VendorID : 0x8086
11944 2018-6-3 17:43:36:3 loaded DeviceID : 0x152
11944 2018-6-3 17:43:36:3 loaded Merit : 134217749
11944 2018-6-3 17:43:36:3 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 2, index = 0
11944 2018-6-3 17:43:36:3 found subkey: iIVB_0156
11944 2018-6-3 17:43:36:3 opened key: iIVB_0156
11944 2018-6-3 17:43:36:3 loaded DeviceID : 0x156
11944 2018-6-3 17:43:36:3 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 2, index = 1
11944 2018-6-3 17:43:36:3 found subkey: iIVB_015A
11944 2018-6-3 17:43:36:3 opened key: iIVB_015A
11944 2018-6-3 17:43:36:3 loaded DeviceID : 0x15a
11944 2018-6-3 17:43:36:3 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 2, index = 2
11944 2018-6-3 17:43:36:4 found subkey: iIVB_0162
11944 2018-6-3 17:43:36:4 opened key: iIVB_0162
11944 2018-6-3 17:43:36:4 loaded VendorID : 0x8086
11944 2018-6-3 17:43:36:4 loaded DeviceID : 0x162
11944 2018-6-3 17:43:36:4 loaded Merit : 134217749
11944 2018-6-3 17:43:36:4 loaded Path : C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:36:4 Library type is MFX_LIB_HARDWARE
11944 2018-6-3 17:43:36:4 found subkey: iIVB_0166
11944 2018-6-3 17:43:36:4 opened key: iIVB_0166
11944 2018-6-3 17:43:36:4 loaded DeviceID : 0x166
11944 2018-6-3 17:43:36:4 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 2, index = 4
11944 2018-6-3 17:43:36:4 found subkey: iIVB_016A
11944 2018-6-3 17:43:36:4 opened key: iIVB_016A
11944 2018-6-3 17:43:36:4 loaded DeviceID : 0x16a
11944 2018-6-3 17:43:36:4 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 2, index = 5
11944 2018-6-3 17:43:36:4 found subkey: iVLV2_0F31
11944 2018-6-3 17:43:36:4 opened key: iVLV2_0F31
11944 2018-6-3 17:43:36:4 loaded DeviceID : 0xf31
11944 2018-6-3 17:43:36:4 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 2, index = 6
11944 2018-6-3 17:43:36:4 found subkey: tracer
11944 2018-6-3 17:43:36:4 opened key: tracer
11944 2018-6-3 17:43:36:4 loaded VendorID : 0x10de
11944 2018-6-3 17:43:36:4 loaded DeviceID : 0x1401
11944 2018-6-3 17:43:36:4 loaded Merit : 2147483646
11944 2018-6-3 17:43:36:4 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x7ffffffe, libraryMerit = 0x8000015, lastindex = 2, index = 7
11944 2018-6-3 17:43:36:4 [WINREG]: EnumKey with index=8: RegEnumKeyExW()==0x103
11944 2018-6-3 17:43:36:4 no more subkeys : RegEnumKeyExA()==0x0
11944 2018-6-3 17:43:36:4 loading library C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:36:4 invoking LoadLibrary(C:\Program Files\Intel\Media SDK\libmfxhw64.dll)
11944 2018-6-3 17:43:36:6 loaded module C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:36:6 Can't find API function "MFXInitEx"
11944 2018-6-3 17:43:36:6 Can't find API function "MFXVideoPAK_Query"
11944 2018-6-3 17:43:36:6 "MFXVideoPAK_Query" is required for API 1.26
11944 2018-6-3 17:43:36:7 found subkey: iIVB_0152
11944 2018-6-3 17:43:36:7 opened key: iIVB_0152
11944 2018-6-3 17:43:36:7 loaded VendorID : 0x8086
11944 2018-6-3 17:43:36:7 loaded DeviceID : 0x152
11944 2018-6-3 17:43:36:7 loaded Merit : 134217749
11944 2018-6-3 17:43:36:7 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 3, index = 0
11944 2018-6-3 17:43:36:7 found subkey: iIVB_0156
11944 2018-6-3 17:43:36:7 opened key: iIVB_0156
11944 2018-6-3 17:43:36:7 loaded DeviceID : 0x156
11944 2018-6-3 17:43:36:7 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 3, index = 1
11944 2018-6-3 17:43:36:7 found subkey: iIVB_015A
11944 2018-6-3 17:43:36:7 opened key: iIVB_015A
11944 2018-6-3 17:43:36:7 loaded DeviceID : 0x15a
11944 2018-6-3 17:43:36:7 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 3, index = 2
11944 2018-6-3 17:43:36:7 found subkey: iIVB_0162
11944 2018-6-3 17:43:36:7 opened key: iIVB_0162
11944 2018-6-3 17:43:36:7 loaded DeviceID : 0x162
11944 2018-6-3 17:43:36:7 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 3, index = 3
11944 2018-6-3 17:43:36:7 found subkey: iIVB_0166
11944 2018-6-3 17:43:36:8 opened key: iIVB_0166
11944 2018-6-3 17:43:36:8 loaded VendorID : 0x8086
11944 2018-6-3 17:43:36:8 loaded DeviceID : 0x166
11944 2018-6-3 17:43:36:8 loaded Merit : 134217749
11944 2018-6-3 17:43:36:8 loaded Path : C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:36:8 Library type is MFX_LIB_HARDWARE
11944 2018-6-3 17:43:36:8 found subkey: iIVB_016A
11944 2018-6-3 17:43:36:8 opened key: iIVB_016A
11944 2018-6-3 17:43:36:8 loaded DeviceID : 0x16a
11944 2018-6-3 17:43:36:8 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 3, index = 5
11944 2018-6-3 17:43:36:8 found subkey: iVLV2_0F31
11944 2018-6-3 17:43:36:8 opened key: iVLV2_0F31
11944 2018-6-3 17:43:36:8 loaded DeviceID : 0xf31
11944 2018-6-3 17:43:36:8 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 3, index = 6
11944 2018-6-3 17:43:36:8 found subkey: tracer
11944 2018-6-3 17:43:36:8 opened key: tracer
11944 2018-6-3 17:43:36:8 loaded VendorID : 0x10de
11944 2018-6-3 17:43:36:8 loaded DeviceID : 0x1401
11944 2018-6-3 17:43:36:8 loaded Merit : 2147483646
11944 2018-6-3 17:43:36:8 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x7ffffffe, libraryMerit = 0x8000015, lastindex = 3, index = 7
11944 2018-6-3 17:43:36:8 [WINREG]: EnumKey with index=8: RegEnumKeyExW()==0x103
11944 2018-6-3 17:43:36:8 no more subkeys : RegEnumKeyExA()==0x0
11944 2018-6-3 17:43:36:8 loading library C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:36:8 invoking LoadLibrary(C:\Program Files\Intel\Media SDK\libmfxhw64.dll)
11944 2018-6-3 17:43:36:11 loaded module C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:36:11 Can't find API function "MFXInitEx"
11944 2018-6-3 17:43:36:11 Can't find API function "MFXVideoPAK_Query"
11944 2018-6-3 17:43:36:11 "MFXVideoPAK_Query" is required for API 1.26
11944 2018-6-3 17:43:36:11 found subkey: iIVB_0152
11944 2018-6-3 17:43:36:11 opened key: iIVB_0152
11944 2018-6-3 17:43:36:11 loaded VendorID : 0x8086
11944 2018-6-3 17:43:36:11 loaded DeviceID : 0x152
11944 2018-6-3 17:43:36:11 loaded Merit : 134217749
11944 2018-6-3 17:43:36:11 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 4, index = 0
11944 2018-6-3 17:43:36:11 found subkey: iIVB_0156
11944 2018-6-3 17:43:36:11 opened key: iIVB_0156
11944 2018-6-3 17:43:36:11 loaded DeviceID : 0x156
11944 2018-6-3 17:43:36:11 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 4, index = 1
11944 2018-6-3 17:43:36:11 found subkey: iIVB_015A
11944 2018-6-3 17:43:36:12 opened key: iIVB_015A
11944 2018-6-3 17:43:36:12 loaded VendorID : 0x8086
11944 2018-6-3 17:43:36:12 loaded DeviceID : 0x15a
11944 2018-6-3 17:43:36:12 loaded Merit : 134217749
11944 2018-6-3 17:43:36:12 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 4, index = 2
11944 2018-6-3 17:43:36:12 found subkey: iIVB_0162
11944 2018-6-3 17:43:36:12 opened key: iIVB_0162
11944 2018-6-3 17:43:36:12 loaded DeviceID : 0x162
11944 2018-6-3 17:43:36:12 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 4, index = 3
11944 2018-6-3 17:43:36:12 found subkey: iIVB_0166
11944 2018-6-3 17:43:36:12 opened key: iIVB_0166
11944 2018-6-3 17:43:36:12 loaded DeviceID : 0x166
11944 2018-6-3 17:43:36:12 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 4, index = 4
11944 2018-6-3 17:43:36:12 found subkey: iIVB_016A
11944 2018-6-3 17:43:36:12 opened key: iIVB_016A
11944 2018-6-3 17:43:36:12 loaded DeviceID : 0x16a
11944 2018-6-3 17:43:36:12 loaded Path : C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:36:12 Library type is MFX_LIB_HARDWARE
11944 2018-6-3 17:43:36:12 found subkey: iVLV2_0F31
11944 2018-6-3 17:43:36:12 opened key: iVLV2_0F31
11944 2018-6-3 17:43:36:12 loaded DeviceID : 0xf31
11944 2018-6-3 17:43:36:12 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x8000015, lastindex = 4, index = 6
11944 2018-6-3 17:43:36:12 found subkey: tracer
11944 2018-6-3 17:43:36:12 opened key: tracer
11944 2018-6-3 17:43:36:12 loaded VendorID : 0x10de
11944 2018-6-3 17:43:36:12 loaded DeviceID : 0x1401
11944 2018-6-3 17:43:36:12 loaded Merit : 2147483646
11944 2018-6-3 17:43:36:12 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x7ffffffe, libraryMerit = 0x8000015, lastindex = 4, index = 7
11944 2018-6-3 17:43:36:13 [WINREG]: EnumKey with index=8: RegEnumKeyExW()==0x103
11944 2018-6-3 17:43:36:13 no more subkeys : RegEnumKeyExA()==0x0
11944 2018-6-3 17:43:36:13 loading library C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:36:13 invoking LoadLibrary(C:\Program Files\Intel\Media SDK\libmfxhw64.dll)
11944 2018-6-3 17:43:36:15 loaded module C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:36:15 Can't find API function "MFXInitEx"
11944 2018-6-3 17:43:36:15 Can't find API function "MFXVideoPAK_Query"
11944 2018-6-3 17:43:36:15 "MFXVideoPAK_Query" is required for API 1.26
11944 2018-6-3 17:43:36:15 found subkey: iIVB_0152
11944 2018-6-3 17:43:36:15 opened key: iIVB_0152
11944 2018-6-3 17:43:36:15 loaded VendorID : 0x8086
11944 2018-6-3 17:43:36:16 loaded DeviceID : 0x152
11944 2018-6-3 17:43:36:16 loaded Merit : 134217749
11944 2018-6-3 17:43:36:16 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 5, index = 0
11944 2018-6-3 17:43:36:16 found subkey: iIVB_0156
11944 2018-6-3 17:43:36:16 opened key: iIVB_0156
11944 2018-6-3 17:43:36:16 loaded VendorID : 0x8086
11944 2018-6-3 17:43:36:16 loaded DeviceID : 0x156
11944 2018-6-3 17:43:36:16 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 5, index = 1
11944 2018-6-3 17:43:36:16 found subkey: iIVB_015A
11944 2018-6-3 17:43:36:16 opened key: iIVB_015A
11944 2018-6-3 17:43:36:16 loaded DeviceID : 0x15a
11944 2018-6-3 17:43:36:16 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 5, index = 2
11944 2018-6-3 17:43:36:16 found subkey: iIVB_0162
11944 2018-6-3 17:43:36:16 opened key: iIVB_0162
11944 2018-6-3 17:43:36:16 loaded DeviceID : 0x162
11944 2018-6-3 17:43:36:16 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 5, index = 3
11944 2018-6-3 17:43:36:16 found subkey: iIVB_0166
11944 2018-6-3 17:43:36:16 opened key: iIVB_0166
11944 2018-6-3 17:43:36:16 loaded DeviceID : 0x166
11944 2018-6-3 17:43:36:16 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 5, index = 4
11944 2018-6-3 17:43:36:16 found subkey: iIVB_016A
11944 2018-6-3 17:43:36:16 opened key: iIVB_016A
11944 2018-6-3 17:43:36:16 loaded DeviceID : 0x16a
11944 2018-6-3 17:43:36:16 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 5, index = 5
11944 2018-6-3 17:43:36:16 found subkey: iVLV2_0F31
11944 2018-6-3 17:43:36:16 opened key: iVLV2_0F31
11944 2018-6-3 17:43:36:16 loaded DeviceID : 0xf31
11944 2018-6-3 17:43:36:17 loaded Merit : 134217749
11944 2018-6-3 17:43:36:17 loaded Path : C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:36:17 Library type is MFX_LIB_HARDWARE
11944 2018-6-3 17:43:36:17 found subkey: tracer
11944 2018-6-3 17:43:36:17 opened key: tracer
11944 2018-6-3 17:43:36:17 loaded VendorID : 0x10de
11944 2018-6-3 17:43:36:17 loaded DeviceID : 0x1401
11944 2018-6-3 17:43:36:17 loaded Merit : 2147483646
11944 2018-6-3 17:43:36:17 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x7ffffffe, libraryMerit = 0x8000015, lastindex = 5, index = 7
11944 2018-6-3 17:43:36:17 [WINREG]: EnumKey with index=8: RegEnumKeyExW()==0x103
11944 2018-6-3 17:43:36:17 no more subkeys : RegEnumKeyExA()==0x0
11944 2018-6-3 17:43:36:17 loading library C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:36:17 invoking LoadLibrary(C:\Program Files\Intel\Media SDK\libmfxhw64.dll)
11944 2018-6-3 17:43:36:19 loaded module C:\Program Files\Intel\Media SDK\libmfxhw64.dll
11944 2018-6-3 17:43:36:19 Can't find API function "MFXInitEx"
11944 2018-6-3 17:43:36:19 Can't find API function "MFXVideoPAK_Query"
11944 2018-6-3 17:43:36:19 "MFXVideoPAK_Query" is required for API 1.26
11944 2018-6-3 17:43:36:19 found subkey: iIVB_0152
11944 2018-6-3 17:43:36:19 opened key: iIVB_0152
11944 2018-6-3 17:43:36:19 loaded VendorID : 0x8086
11944 2018-6-3 17:43:36:19 loaded DeviceID : 0x152
11944 2018-6-3 17:43:36:19 loaded Merit : 134217749
11944 2018-6-3 17:43:36:20 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 6, index = 0
11944 2018-6-3 17:43:36:20 found subkey: iIVB_0156
11944 2018-6-3 17:43:36:20 opened key: iIVB_0156
11944 2018-6-3 17:43:36:20 loaded VendorID : 0x8086
11944 2018-6-3 17:43:36:20 loaded DeviceID : 0x156
11944 2018-6-3 17:43:36:20 loaded Merit : 134217749
11944 2018-6-3 17:43:36:20 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 6, index = 1
11944 2018-6-3 17:43:36:20 found subkey: iIVB_015A
11944 2018-6-3 17:43:36:20 opened key: iIVB_015A
11944 2018-6-3 17:43:36:20 loaded DeviceID : 0x15a
11944 2018-6-3 17:43:36:20 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 6, index = 2
11944 2018-6-3 17:43:36:20 found subkey: iIVB_0162
11944 2018-6-3 17:43:36:20 opened key: iIVB_0162
11944 2018-6-3 17:43:36:20 loaded DeviceID : 0x162
11944 2018-6-3 17:43:36:20 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 6, index = 3
11944 2018-6-3 17:43:36:20 found subkey: iIVB_0166
11944 2018-6-3 17:43:36:20 opened key: iIVB_0166
11944 2018-6-3 17:43:36:20 loaded DeviceID : 0x166
11944 2018-6-3 17:43:36:20 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 6, index = 4
11944 2018-6-3 17:43:36:20 found subkey: iIVB_016A
11944 2018-6-3 17:43:36:20 opened key: iIVB_016A
11944 2018-6-3 17:43:36:20 loaded DeviceID : 0x16a
11944 2018-6-3 17:43:36:20 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 6, index = 5
11944 2018-6-3 17:43:36:20 found subkey: iVLV2_0F31
11944 2018-6-3 17:43:36:20 opened key: iVLV2_0F31
11944 2018-6-3 17:43:36:20 loaded DeviceID : 0xf31
11944 2018-6-3 17:43:36:20 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x8000015, libraryMerit = 0x0, lastindex = 6, index = 6
11944 2018-6-3 17:43:36:21 found subkey: tracer
11944 2018-6-3 17:43:36:21 opened key: tracer
11944 2018-6-3 17:43:36:21 loaded VendorID : 0x10de
11944 2018-6-3 17:43:36:21 loaded DeviceID : 0x1401
11944 2018-6-3 17:43:36:21 loaded Merit : 2147483646
11944 2018-6-3 17:43:36:21 merit conflict: lastMerit = 0x8000015, requiredMerit = 0x7ffffffe, libraryMerit = 0x0, lastindex = 6, index = 7
11944 2018-6-3 17:43:36:21 [WINREG]: EnumKey with index=8: RegEnumKeyExW()==0x103
11944 2018-6-3 17:43:36:21 no more subkeys : RegEnumKeyExA()==0x0
11944 2018-6-3 17:43:36:21 loading default library libmfxsw64.dll
11944 2018-6-3 17:43:36:21 invoking LoadLibrary(libmfxsw64.dll)
11944 2018-6-3 17:43:36:23 loaded module D:\Program Files (x86)\IntelSWTools\Intel(R) Media SDK 2018 R1\Software Development Kit\bin\x64\libmfxsw64.dll
11944 2018-6-3 17:43:36:23 MFXInitEx(MFX_IMPL_SOFTWARE,ver=1.26,ExtThreads=0,session=0x00000252354AEFB0)
11944 2018-6-3 17:43:36:23 MFXQueryVersion returned API: 1.26
11944 2018-6-3 17:43:36:23 library loaded succesfully
11944 2018-6-3 17:43:36:23 [HIVE]: GetFileAttributesW() unable to locate default plugin dll named D:\Program Files (x86)\IntelSWTools\Intel(R) Media SDK 2018 R1\Software Development Kit\bin\x64\mfxplugin64_sw.dll
11944 2018-6-3 17:43:36:23 [WINREG]: Opening key "HKEY_CURRENT_USER\Software\Intel\MediaSDK\Plugin" : RegOpenKeyExW()==0x2
11944 2018-6-3 17:43:36:24 [HIVE]: Found Plugin: HKEY_LOCAL_MACHINE\Software\Intel\MediaSDK\Plugin\{15DD9368-25AD-475E-A34E-35F3F54217A6}
11944 2018-6-3 17:43:36:24 [HIVE]: Type : 1
11944 2018-6-3 17:43:36:24 [HIVE]: CodecID : HEVC
11944 2018-6-3 17:43:36:24 [HIVE]: GUID : 15-DD-93-68-25-AD-47-5E-A3-4E-35-F3-F5-42-17-A6
11944 2018-6-3 17:43:36:24 [HIVE]: Path : D:\Program Files (x86)\IntelSWTools\Intel(R) Media SDK 2018 R1\HEVC Decoder & Encoder\Plugin\15DD936825AD475EA34E35F3F54217A6\mfxplugin64_hevcd_sw.dll
11944 2018-6-3 17:43:36:24 [HIVE]: Default : false
11944 2018-6-3 17:43:36:24 [HIVE]: PluginVersion : 1
11944 2018-6-3 17:43:36:24 [HIVE]: APIVersion : 1.26
11944 2018-6-3 17:43:36:24 [HIVE]: Found Plugin: HKEY_LOCAL_MACHINE\Software\Intel\MediaSDK\Plugin\{2fca9974-9fdb-49ae-b121-a5b63ef568f7}
11944 2018-6-3 17:43:36:24 [HIVE]: Type : 2
11944 2018-6-3 17:43:36:24 [HIVE]: GUID : 2F-CA-99-74-9F-DB-49-AE-B1-21-A5-B6-3E-F5-68-F7
11944 2018-6-3 17:43:36:24 [HIVE]: Path : D:\Program Files (x86)\IntelSWTools\Intel(R) Media SDK 2018 R1\HEVC Decoder & Encoder\Plugin\2fca99749fdb49aeb121a5b63ef568f7\mfxplugin64_hevce_sw.dll
11944 2018-6-3 17:43:36:24 [HIVE]: Found Plugin: HKEY_LOCAL_MACHINE\Software\Intel\MediaSDK\Plugin\{e5400a06-c74d-41f5-b12d-430bbaa23d0b}
11944 2018-6-3 17:43:36:24 [HIVE]: GUID : E5-40-A-6-C7-4D-41-F5-B1-2D-43-B-BA-A2-3D-B
11944 2018-6-3 17:43:36:24 [HIVE]: Path : D:\Program Files (x86)\IntelSWTools\Intel(R) Media SDK 2018 R1\HEVC Decoder & Encoder\Plugin\e5400a06c74d41f5b12d430bbaa23d0b\mfxplugin64_hevce_gacc.dll
11944 2018-6-3 17:43:36:24 [WINREG]: EnumKey with index=3: RegEnumKeyExW()==0x103
11944 2018-6-3 17:43:36:25 >> MFXInitEx called
11944 2018-6-3 17:43:36:25 par.Implementation=MFX_IMPL_SOFTWARE
11944 2018-6-3 17:43:36:25 par.Version.Major=1
11944 2018-6-3 17:43:36:25 par.Version.Minor=26
11944 2018-6-3 17:43:36:25 par.Version.Version=65562
11944 2018-6-3 17:43:36:25 par.ExternalThreads=0
11944 2018-6-3 17:43:36:25 par.NumExtParam=0
11944 2018-6-3 17:43:36:25 par.ExtParam=0000000000000000
11944 2018-6-3 17:43:36:25 par.reserved2[]={ 0, 0, 0, 0, 0 }
11944 2018-6-3 17:43:36:25 par.GPUCopy=0
11944 2018-6-3 17:43:36:25 par.reserved[]={ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }11944 2018-6-3 17:43:36:25 mfxSession session=0000025236C9DCA0
11944 2018-6-3 17:43:36:25 function: MFXInitEx(36.2325 msec, status=MFX_ERR_NONE) -
11944 2018-6-3 17:43:36:25 function: MFXQueryVersion(mfxSession session=0000025236C9DCA0, mfxVersion *version=00000252353FA5E0) +
11944 2018-6-3 17:43:36:25 mfxSession session=0000025236C9D4C8
11944 2018-6-3 17:43:36:25 version.Major=0
11944 2018-6-3 17:43:36:25 version.Minor=0
11944 2018-6-3 17:43:36:25 version.Version=0
11944 2018-6-3 17:43:36:25 >> MFXQueryVersion called
11944 2018-6-3 17:43:36:25 version.Major=1
11944 2018-6-3 17:43:36:25 version.Minor=26
11944 2018-6-3 17:43:36:25 version.Version=65562
11944 2018-6-3 17:43:36:25 function: MFXQueryVersion(0.000602349 msec, status=MFX_ERR_NONE) -
11944 2018-6-3 17:43:36:68 function: MFXQueryVersion(mfxSession session=0000025236C9DCA0, mfxVersion *version=000000BB134FDFE0) +
11944 2018-6-3 17:43:36:68 mfxSession session=0000025236C9D4C8
11944 2018-6-3 17:43:36:68 version.Major=0
11944 2018-6-3 17:43:36:68 version.Minor=0
11944 2018-6-3 17:43:36:68 version.Version=0
11944 2018-6-3 17:43:36:69 >> MFXQueryVersion called
11944 2018-6-3 17:43:36:69 mfxSession session=0000025236C9D4C8
11944 2018-6-3 17:43:36:69 version.Major=1
11944 2018-6-3 17:43:36:69 version.Minor=26
11944 2018-6-3 17:43:36:69 version.Version=65562
11944 2018-6-3 17:43:36:69 function: MFXQueryVersion(0.000903523 msec, status=MFX_ERR_NONE) -
11944 2018-6-3 17:43:36:69 function: MFXVideoENCODE_QueryIOSurf(mfxSession session=0000025236C9DCA0, mfxVideoParam *par=000000BB134FF440, mfxFrameAllocRequest *request=000000BB134FF530) +
11944 2018-6-3 17:43:36:70 par.AllocId=1
11944 2018-6-3 17:43:36:70 par.reserved[]={ 0, 0 }
11944 2018-6-3 17:43:36:70 par.AsyncDepth=0
11944 2018-6-3 17:43:36:70 par.mfx.reserved[]={ 0, 0, 0, 0, 0, 0, 0 }
11944 2018-6-3 17:43:36:70 par.mfx.LowPower=0
11944 2018-6-3 17:43:36:70 par.mfx.BRCParamMultiplier=0
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.reserved[]={ 0, 0, 0, 0 }
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.reserved4=0
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.BitDepthLuma=0
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.BitDepthChroma=0
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.Shift=0
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.mfxFrameId.TemporalId=0
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.mfxFrameId.PriorityId=0
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.mfxFrameId.DependencyId=0
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.mfxFrameId.QualityId=0
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.mfxFrameId.ViewId=0
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.FourCC=RGB4
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.Width=640
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.Height=480
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.CropX=0
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.CropY=0
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.CropW=640
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.CropH=480
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.BufferSize=31457920
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.reserved5=31457920
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.FrameRateExtN=1
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.FrameRateExtD=60
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.reserved3=0
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.AspectRatioW=0
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.AspectRatioH=0
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.PicStruct=1
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.ChromaFormat=1
11944 2018-6-3 17:43:36:70 par.mfx.FrameInfo.reserved2=0
11944 2018-6-3 17:43:36:70 par.mfx.CodecId=MFX_CODEC_AVC
11944 2018-6-3 17:43:36:70 par.mfx.CodecProfile=0
11944 2018-6-3 17:43:36:70 par.mfx.CodecLevel=0
11944 2018-6-3 17:43:36:70 par.mfx.NumThread=0
11944 2018-6-3 17:43:36:70 par.mfx.TargetUsage=0
11944 2018-6-3 17:43:36:70 par.mfx.GopPicSize=0
11944 2018-6-3 17:43:36:70 par.mfx.GopRefDist=0
11944 2018-6-3 17:43:36:70 par.mfx.GopOptFlag=0
11944 2018-6-3 17:43:36:70 par.mfx.IdrInterval=0
11944 2018-6-3 17:43:36:70 par.mfx.RateControlMethod=0
11944 2018-6-3 17:43:36:70 par.mfx.InitialDelayInKB=0
11944 2018-6-3 17:43:36:70 par.mfx.QPI=0
11944 2018-6-3 17:43:36:70 par.mfx.Accuracy=0
11944 2018-6-3 17:43:36:70 par.mfx.BufferSizeInKB=0
11944 2018-6-3 17:43:36:70 par.mfx.TargetKbps=6000
11944 2018-6-3 17:43:36:70 par.mfx.QPP=6000
11944 2018-6-3 17:43:36:70 par.mfx.ICQQuality=6000
11944 2018-6-3 17:43:36:70 par.mfx.MaxKbps=0
11944 2018-6-3 17:43:36:70 par.mfx.QPB=0
11944 2018-6-3 17:43:36:70 par.mfx.Convergence=0
11944 2018-6-3 17:43:36:70 par.mfx.NumSlice=0
11944 2018-6-3 17:43:36:70 par.mfx.NumRefFrame=0
11944 2018-6-3 17:43:36:70 par.mfx.EncodedOrder=1
11944 2018-6-3 17:43:36:70 par.mfx.DecodedOrder=0
11944 2018-6-3 17:43:36:70 par.mfx.ExtendedPicStruct=0
11944 2018-6-3 17:43:36:70 par.mfx.TimeStampCalc=0
11944 2018-6-3 17:43:36:70 par.mfx.SliceGroupsPresent=0
11944 2018-6-3 17:43:36:70 par.mfx.MaxDecFrameBuffering=0
11944 2018-6-3 17:43:36:70 par.mfx.EnableReallocRequest=0
11944 2018-6-3 17:43:36:70 par.mfx.reserved2[]={ 0, 0, 6000, 0, 0, 0, 1 }
11944 2018-6-3 17:43:36:70 par.mfx.JPEGChromaFormat=0
11944 2018-6-3 17:43:36:70 par.mfx.Rotation=0
11944 2018-6-3 17:43:36:70 par.mfx.JPEGColorFormat=0
11944 2018-6-3 17:43:36:70 par.mfx.InterleavedDec=0
11944 2018-6-3 17:43:36:70 par.mfx.reserved3[]={ 6000, 0, 0, 0, 1 }
11944 2018-6-3 17:43:36:70 par.mfx.Interleaved=0
11944 2018-6-3 17:43:36:70 par.mfx.Quality=0
11944 2018-6-3 17:43:36:70 par.mfx.RestartInterval=0
11944 2018-6-3 17:43:36:70 par.mfx.reserved5[]={ 0, 0, 0, 0, 0, 6000, 0, 0, 0, 1 }11944 2018-6-3 17:43:36:70 par.Protected=0
11944 2018-6-3 17:43:36:70 par.IOPattern=MFX_IOPATTERN_IN_SYSTEM_MEMORY; MFX_IOPATTERN_OUT_SYSTEM_MEMORY;
11944 2018-6-3 17:43:36:71 par.NumExtParam=0
11944 2018-6-3 17:43:36:71 par.ExtParam=000000000000000011944 2018-6-3 17:43:36:71 par.reserved2=0
11944 2018-6-3 17:43:36:71 request.AllocId=3435973836
11944 2018-6-3 17:43:36:71 request.reserved[]={ 3435973836 }
11944 2018-6-3 17:43:36:71 request.reserved3[]={ 3435973836, 3435973836, 3435973836 }
11944 2018-6-3 17:43:36:71 request.Info.reserved[]={ 3435973836, 3435973836, 3435973836, 3435973836 }
11944 2018-6-3 17:43:36:71 request.Info.reserved4=52428
11944 2018-6-3 17:43:36:71 request.Info.BitDepthLuma=52428
11944 2018-6-3 17:43:36:71 request.Info.BitDepthChroma=52428
11944 2018-6-3 17:43:36:71 request.Info.Shift=52428
11944 2018-6-3 17:43:36:71 request.Info.mfxFrameId.TemporalId=52428
11944 2018-6-3 17:43:36:71 request.Info.mfxFrameId.PriorityId=52428
11944 2018-6-3 17:43:36:71 request.Info.mfxFrameId.DependencyId=52428
11944 2018-6-3 17:43:36:71 request.Info.mfxFrameId.QualityId=52428
11944 2018-6-3 17:43:36:71 request.Info.mfxFrameId.ViewId=52428
11944 2018-6-3 17:43:36:71 request.Info.FourCC=UNKNOWN
11944 2018-6-3 17:43:36:71 request.Info.Width=52428
11944 2018-6-3 17:43:36:71 request.Info.Height=52428
11944 2018-6-3 17:43:36:71 request.Info.CropX=52428
11944 2018-6-3 17:43:36:71 request.Info.CropY=52428
11944 2018-6-3 17:43:36:71 request.Info.CropW=52428
11944 2018-6-3 17:43:36:71 request.Info.CropH=52428
11944 2018-6-3 17:43:36:71 request.Info.BufferSize=14757395258967641292
11944 2018-6-3 17:43:36:71 request.Info.reserved5=3435973836
11944 2018-6-3 17:43:36:71 request.Info.FrameRateExtN=3435973836
11944 2018-6-3 17:43:36:71 request.Info.FrameRateExtD=3435973836
11944 2018-6-3 17:43:36:71 request.Info.reserved3=52428
11944 2018-6-3 17:43:36:71 request.Info.AspectRatioW=52428
11944 2018-6-3 17:43:36:71 request.Info.AspectRatioH=52428
11944 2018-6-3 17:43:36:71 request.Info.PicStruct=52428
11944 2018-6-3 17:43:36:71 request.Info.ChromaFormat=52428
11944 2018-6-3 17:43:36:71 request.Info.reserved2=52428
11944 2018-6-3 17:43:36:71 request.Type=52428
11944 2018-6-3 17:43:36:71 request.NumFrameMin=52428
11944 2018-6-3 17:43:36:71 request.NumFrameSuggested=52428
11944 2018-6-3 17:43:36:71 request.reserved2=52428
11944 2018-6-3 17:43:36:71 >> MFXVideoENCODE_QueryIOSurf called
11944 2018-6-3 17:43:36:71 mfxSession session=0000025236C9D4C8
11944 2018-6-3 17:43:36:71 par.AllocId=1
11944 2018-6-3 17:43:36:71 par.reserved[]={ 0, 0 }
11944 2018-6-3 17:43:36:71 par.AsyncDepth=0
11944 2018-6-3 17:43:36:71 par.mfx.reserved[]={ 0, 0, 0, 0, 0, 0, 0 }
11944 2018-6-3 17:43:36:71 par.mfx.LowPower=0
11944 2018-6-3 17:43:36:71 par.mfx.BRCParamMultiplier=0
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.reserved[]={ 0, 0, 0, 0 }
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.reserved4=0
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.BitDepthLuma=0
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.BitDepthChroma=0
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.Shift=0
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.mfxFrameId.TemporalId=0
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.mfxFrameId.PriorityId=0
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.mfxFrameId.DependencyId=0
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.mfxFrameId.QualityId=0
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.mfxFrameId.ViewId=0
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.FourCC=RGB4
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.Width=640
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.Height=480
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.CropX=0
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.CropY=0
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.CropW=640
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.CropH=480
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.BufferSize=31457920
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.reserved5=31457920
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.FrameRateExtN=1
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.FrameRateExtD=60
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.reserved3=0
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.AspectRatioW=0
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.AspectRatioH=0
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.PicStruct=1
11944 2018-6-3 17:43:36:71 par.mfx.FrameInfo.ChromaFormat=1
11944 2018-6-3 17:43:36:72 par.mfx.FrameInfo.reserved2=0
11944 2018-6-3 17:43:36:72 par.mfx.CodecId=MFX_CODEC_AVC
11944 2018-6-3 17:43:36:72 par.mfx.CodecProfile=0
11944 2018-6-3 17:43:36:72 par.mfx.CodecLevel=0
11944 2018-6-3 17:43:36:72 par.mfx.NumThread=0
11944 2018-6-3 17:43:36:72 par.mfx.TargetUsage=0
11944 2018-6-3 17:43:36:72 par.mfx.GopPicSize=0
11944 2018-6-3 17:43:36:72 par.mfx.GopRefDist=0
11944 2018-6-3 17:43:36:72 par.mfx.GopOptFlag=0
11944 2018-6-3 17:43:36:72 par.mfx.IdrInterval=0
11944 2018-6-3 17:43:36:72 par.mfx.RateControlMethod=0
11944 2018-6-3 17:43:36:72 par.mfx.InitialDelayInKB=0
11944 2018-6-3 17:43:36:72 par.mfx.QPI=0
11944 2018-6-3 17:43:36:72 par.mfx.Accuracy=0
11944 2018-6-3 17:43:36:72 par.mfx.BufferSizeInKB=0
11944 2018-6-3 17:43:36:72 par.mfx.TargetKbps=6000
11944 2018-6-3 17:43:36:72 par.mfx.QPP=6000
11944 2018-6-3 17:43:36:72 par.mfx.ICQQuality=6000
11944 2018-6-3 17:43:36:72 par.mfx.MaxKbps=0
11944 2018-6-3 17:43:36:72 par.mfx.QPB=0
11944 2018-6-3 17:43:36:72 par.mfx.Convergence=0
11944 2018-6-3 17:43:36:72 par.mfx.NumSlice=0
11944 2018-6-3 17:43:36:72 par.mfx.NumRefFrame=0
11944 2018-6-3 17:43:36:72 par.mfx.EncodedOrder=1
11944 2018-6-3 17:43:36:72 par.mfx.DecodedOrder=0
11944 2018-6-3 17:43:36:72 par.mfx.ExtendedPicStruct=0
11944 2018-6-3 17:43:36:72 par.mfx.TimeStampCalc=0
11944 2018-6-3 17:43:36:72 par.mfx.SliceGroupsPresent=0
11944 2018-6-3 17:43:36:72 par.mfx.MaxDecFrameBuffering=0
11944 2018-6-3 17:43:36:72 par.mfx.EnableReallocRequest=0
11944 2018-6-3 17:43:36:72 par.mfx.reserved2[]={ 0, 0, 6000, 0, 0, 0, 1 }
11944 2018-6-3 17:43:36:72 par.mfx.JPEGChromaFormat=0
11944 2018-6-3 17:43:36:72 par.mfx.Rotation=0
11944 2018-6-3 17:43:36:72 par.mfx.JPEGColorFormat=0
11944 2018-6-3 17:43:36:72 par.mfx.InterleavedDec=0
11944 2018-6-3 17:43:36:72 par.mfx.reserved3[]={ 6000, 0, 0, 0, 1 }
11944 2018-6-3 17:43:36:72 par.mfx.Interleaved=0
11944 2018-6-3 17:43:36:72 par.mfx.Quality=0
11944 2018-6-3 17:43:36:72 par.mfx.RestartInterval=0
11944 2018-6-3 17:43:36:72 par.mfx.reserved5[]={ 0, 0, 0, 0, 0, 6000, 0, 0, 0, 1 }11944 2018-6-3 17:43:36:72 par.Protected=0
11944 2018-6-3 17:43:36:72 par.IOPattern=MFX_IOPATTERN_IN_SYSTEM_MEMORY; MFX_IOPATTERN_OUT_SYSTEM_MEMORY;
11944 2018-6-3 17:43:36:72 par.NumExtParam=0
11944 2018-6-3 17:43:36:72 par.ExtParam=000000000000000011944 2018-6-3 17:43:36:72 par.reserved2=0
11944 2018-6-3 17:43:36:72 request.AllocId=3435973836
11944 2018-6-3 17:43:36:72 request.reserved[]={ 3435973836 }
11944 2018-6-3 17:43:36:72 request.reserved3[]={ 3435973836, 3435973836, 3435973836 }
11944 2018-6-3 17:43:36:72 request.Info.reserved[]={ 0, 0, 0, 0 }
11944 2018-6-3 17:43:36:72 request.Info.reserved4=0
11944 2018-6-3 17:43:36:72 request.Info.BitDepthLuma=0
11944 2018-6-3 17:43:36:72 request.Info.BitDepthChroma=0
11944 2018-6-3 17:43:36:72 request.Info.Shift=0
11944 2018-6-3 17:43:36:72 request.Info.mfxFrameId.TemporalId=0
11944 2018-6-3 17:43:36:72 request.Info.mfxFrameId.PriorityId=0
11944 2018-6-3 17:43:36:72 request.Info.mfxFrameId.DependencyId=0
11944 2018-6-3 17:43:36:72 request.Info.mfxFrameId.QualityId=0
11944 2018-6-3 17:43:36:72 request.Info.mfxFrameId.ViewId=0
11944 2018-6-3 17:43:36:72 request.Info.FourCC=RGB4
11944 2018-6-3 17:43:36:72 request.Info.Width=640
11944 2018-6-3 17:43:36:72 request.Info.Height=480
11944 2018-6-3 17:43:36:72 request.Info.CropX=0
11944 2018-6-3 17:43:36:72 request.Info.CropY=0
11944 2018-6-3 17:43:36:72 request.Info.CropW=640
11944 2018-6-3 17:43:36:72 request.Info.CropH=480
11944 2018-6-3 17:43:36:72 request.Info.BufferSize=31457920
11944 2018-6-3 17:43:36:72 request.Info.reserved5=31457920
11944 2018-6-3 17:43:36:72 request.Info.FrameRateExtN=1
11944 2018-6-3 17:43:36:72 request.Info.FrameRateExtD=60
11944 2018-6-3 17:43:36:72 request.Info.reserved3=0
11944 2018-6-3 17:43:36:72 request.Info.AspectRatioW=0
11944 2018-6-3 17:43:36:72 request.Info.AspectRatioH=0
11944 2018-6-3 17:43:36:72 request.Info.PicStruct=1
11944 2018-6-3 17:43:36:72 request.Info.ChromaFormat=1
11944 2018-6-3 17:43:36:72 request.Info.reserved2=0
11944 2018-6-3 17:43:36:72 request.Type=322
11944 2018-6-3 17:43:36:72 request.NumFrameMin=2
11944 2018-6-3 17:43:36:72 request.NumFrameSuggested=2
11944 2018-6-3 17:43:36:72 request.reserved2=52428
11944 2018-6-3 17:43:36:72 function: MFXVideoENCODE_QueryIOSurf(0.00572231 msec, status=MFX_ERR_NONE) -
11944 2018-6-3 17:43:36:73 function: MFXVideoENCODE_Init(mfxSession session=0000025236C9DCA0, mfxVideoParam *par=000000BB134FF440) +
11944 2018-6-3 17:43:36:73 mfxSession session=0000025236C9D4C8
11944 2018-6-3 17:43:36:73 par.AllocId=1
11944 2018-6-3 17:43:36:73 par.reserved[]={ 0, 0 }
11944 2018-6-3 17:43:36:73 par.AsyncDepth=0
11944 2018-6-3 17:43:36:73 par.mfx.reserved[]={ 0, 0, 0, 0, 0, 0, 0 }
11944 2018-6-3 17:43:36:73 par.mfx.LowPower=0
11944 2018-6-3 17:43:36:73 par.mfx.BRCParamMultiplier=0
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.reserved[]={ 0, 0, 0, 0 }
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.reserved4=0
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.BitDepthLuma=0
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.BitDepthChroma=0
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.Shift=0
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.mfxFrameId.TemporalId=0
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.mfxFrameId.PriorityId=0
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.mfxFrameId.DependencyId=0
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.mfxFrameId.QualityId=0
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.mfxFrameId.ViewId=0
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.FourCC=RGB4
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.Width=640
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.Height=480
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.CropX=0
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.CropY=0
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.CropW=640
11944 2018-6-3 17:43:36:73 par.mfx.FrameInfo.CropH=480
11944 2018-6-3 17:43:36:74 par.mfx.FrameInfo.BufferSize=31457920
11944 2018-6-3 17:43:36:74 par.mfx.FrameInfo.reserved5=31457920
11944 2018-6-3 17:43:36:74 par.mfx.FrameInfo.FrameRateExtN=1
11944 2018-6-3 17:43:36:74 par.mfx.FrameInfo.FrameRateExtD=60
11944 2018-6-3 17:43:36:74 par.mfx.FrameInfo.reserved3=0
11944 2018-6-3 17:43:36:74 par.mfx.FrameInfo.AspectRatioW=0
11944 2018-6-3 17:43:36:74 par.mfx.FrameInfo.AspectRatioH=0
11944 2018-6-3 17:43:36:74 par.mfx.FrameInfo.PicStruct=1
11944 2018-6-3 17:43:36:74 par.mfx.FrameInfo.ChromaFormat=1
11944 2018-6-3 17:43:36:74 par.mfx.FrameInfo.reserved2=0
11944 2018-6-3 17:43:36:74 par.mfx.CodecId=MFX_CODEC_AVC
11944 2018-6-3 17:43:36:74 par.mfx.CodecProfile=0
11944 2018-6-3 17:43:36:74 par.mfx.CodecLevel=0
11944 2018-6-3 17:43:36:74 par.mfx.NumThread=0
11944 2018-6-3 17:43:36:74 par.mfx.TargetUsage=0
11944 2018-6-3 17:43:36:74 par.mfx.GopPicSize=0
11944 2018-6-3 17:43:36:74 par.mfx.GopRefDist=0
11944 2018-6-3 17:43:36:74 par.mfx.GopOptFlag=0
11944 2018-6-3 17:43:36:74 par.mfx.IdrInterval=0
11944 2018-6-3 17:43:36:74 par.mfx.RateControlMethod=0
11944 2018-6-3 17:43:36:74 par.mfx.InitialDelayInKB=0
11944 2018-6-3 17:43:36:74 par.mfx.QPI=0
11944 2018-6-3 17:43:36:74 par.mfx.Accuracy=0
11944 2018-6-3 17:43:36:74 par.mfx.BufferSizeInKB=0
11944 2018-6-3 17:43:36:74 par.mfx.TargetKbps=6000
11944 2018-6-3 17:43:36:74 par.mfx.QPP=6000
11944 2018-6-3 17:43:36:74 par.mfx.ICQQuality=6000
11944 2018-6-3 17:43:36:74 par.mfx.MaxKbps=0
11944 2018-6-3 17:43:36:74 par.mfx.QPB=0
11944 2018-6-3 17:43:36:74 par.mfx.Convergence=0
11944 2018-6-3 17:43:36:74 par.mfx.NumSlice=0
11944 2018-6-3 17:43:36:74 par.mfx.NumRefFrame=0
11944 2018-6-3 17:43:36:74 par.mfx.EncodedOrder=1
11944 2018-6-3 17:43:36:74 par.mfx.DecodedOrder=0
11944 2018-6-3 17:43:36:74 par.mfx.ExtendedPicStruct=0
11944 2018-6-3 17:43:36:74 par.mfx.TimeStampCalc=0
11944 2018-6-3 17:43:36:74 par.mfx.SliceGroupsPresent=0
11944 2018-6-3 17:43:36:74 par.mfx.MaxDecFrameBuffering=0
11944 2018-6-3 17:43:36:74 par.mfx.EnableReallocRequest=0
11944 2018-6-3 17:43:36:74 par.mfx.reserved2[]={ 0, 0, 6000, 0, 0, 0, 1 }
11944 2018-6-3 17:43:36:74 par.mfx.JPEGChromaFormat=0
11944 2018-6-3 17:43:36:74 par.mfx.Rotation=0
11944 2018-6-3 17:43:36:74 par.mfx.JPEGColorFormat=0
11944 2018-6-3 17:43:36:74 par.mfx.InterleavedDec=0
11944 2018-6-3 17:43:36:74 par.mfx.reserved3[]={ 6000, 0, 0, 0, 1 }
11944 2018-6-3 17:43:36:74 par.mfx.Interleaved=0
11944 2018-6-3 17:43:36:74 par.mfx.Quality=0
11944 2018-6-3 17:43:36:74 par.mfx.RestartInterval=0
11944 2018-6-3 17:43:36:74 par.mfx.reserved5[]={ 0, 0, 0, 0, 0, 6000, 0, 0, 0, 1 }11944 2018-6-3 17:43:36:74 par.Protected=0
11944 2018-6-3 17:43:36:74 par.IOPattern=MFX_IOPATTERN_IN_SYSTEM_MEMORY; MFX_IOPATTERN_OUT_SYSTEM_MEMORY;
11944 2018-6-3 17:43:36:74 par.NumExtParam=0
11944 2018-6-3 17:43:36:74 par.ExtParam=000000000000000011944 2018-6-3 17:43:36:74 par.reserved2=0
11944 2018-6-3 17:43:36:77 >> MFXVideoENCODE_Init called
11944 2018-6-3 17:43:36:77 function: MFXVideoENCODE_Init(2.45367 msec, status=MFX_ERR_INVALID_VIDEO_PARAM) -
11944 2018-6-3 17:43:36:77 function: MFXClose(mfxSession session=0000025236C9DCA0) +
11944 2018-6-3 17:43:36:77 mfxSession session=0000025236C9DCA0
11944 2018-6-3 17:43:36:77 >> MFXClose called
11944 2018-6-3 17:43:36:78 mfxSession session=0000025236C9DCA0
11944 2018-6-3 17:43:36:78 function: MFXClose(0.586688 msec, status=MFX_ERR_NONE) -
11944 2018-6-3 17:43:36:78 function: DLLMain() DLL_PROCESS_DETACH +
11944 2018-6-3 17:43:36:78 function: DLLMain() DLL_PROCESS_DETACH -
Relevant hardware:
- i5-3570K
- GTX 960
- 24GB of system RAM
Software:
- Windows 10 Pro x64
- Visual Studio 2017
- Intel Media SDK 2018 R1
- Tags:
- Development Tools
- Graphics
- Intel® Media SDK
- Intel® Media Server Studio
- Media Processing
- Optimization
