recently I have installed MSS 2017R2 on a new supermicro system X11SSV-M4F ( CPU: intel xeon E3-1585 v5, chipset: intel C236, OS CentOS 7.2.1511).
All works fine except metrics_monitor tool, which fails with this message: ERROR: Failed to subscribe for metrics, error code 1
And I can't find out what is wrong.
For example, I have another system running MSS 2017R2, it is intel NUC6i7KYK (mini pc) and here metrics_monitor runs fine. The graphics on both systems is the same Iris Pro 580.
Bellow you will find additional information:
[root@transcoder2 sample]# cat /etc/centos-release CentOS Linux release 7.2.1511 (Core) [root@transcoder2 sample]# uname -ar Linux transcoder2 3.10.0-327.el7.x86_64 #1 SMP Thu Nov 19 22:10:57 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux [root@transcoder2 sample]# lspci -nn -s 00:02.0 00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:193a] (rev 09) [root@transcoder2 sample]# lsmod | grep 'i915' i915 1325693 9 drm_ukmd_kms_helper 141060 1 i915 drm_ukmd 369649 3 i915,drm_ukmd_kms_helper drm_ukmd_compat 109279 1 i915 i2c_algo_bit 13413 3 ast,igb,i915 video 24400 1 i915 i2c_core 40582 11 ast,drm,igb,i915,i2c_i801,i2c_hid,ipmi_ssif,drm_kms_helper,i2c_algo_bit,drm_ukmd,drm_ukmd_kms_helper [root@transcoder2 sample]# vainfo | grep -v unknown error: can't connect to X server! libva info: VA-API version 0.99.0 libva info: va_getDriverName() returns 0 libva info: User requested driver 'iHD' libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so libva info: Found init function __vaDriverInit_0_32 libva info: va_openDriver() returns 0 vainfo: VA-API version: 0.99 (libva 1.67.0.pre1) vainfo: Driver version: 16.5.1.59511-ubit vainfo: Supported profile and entrypoints VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileMPEG2Simple : VAEntrypointEncSlice VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointEncSlice VAProfileMPEG2Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileVP8Version0_3 : VAEntrypointEncSlice VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileNone : VAEntrypointVideoProc [root@transcoder2 sample]# ./run.sh ERROR: Failed to subscribe for metrics, error code 1
It will be nice to receive some suggestions from an expert
Mindaugas
I have the same problem with the same proccessor (1585) but with E3-1275 no problems, works very well. Very strange, why anybody from Intel do not answer?
Rashad
Dear all,
Problem solved! Please try to update or downgrade gcc and g++ to version 4.9 and problem will solved.
Rashad
Hi Rashad,
glad to hear it. Could you give some more details, what have you changed step by step.
I have installed devtoolset-3 which includes gcc and g++ 4.9.2 and have recompiled metrics_monitor with that version but nothing have changed.
Mindaugas
hi Mindaugas,
i`m using Ubuntu 16.04 LTS with gcc and g++ 4.9
Rashad
After upgraded gcc and g++ try to remove libdrm, libva and recompile again from /opt/intel/mediasdk/opensource/lib..
After reboot same problem again. Very strange :(
This is more like a software issue since the other people on the old platform got it.
https://software.intel.com/en-us/forums/intel-media-sdk/topic/540163#comment-1905526
Mark
Hi
I am having a similar problem on an Intel(R) Xeon(R) CPU E3-1285L v4 @ 3.40GHz machine, OS: CentOS 7.2.1511.
Hardware acceleration (decoding/vpp/encoding) is working well. Metrics query always fails to subscribe.
On the other hand, it works perfectly fine on a newer machine: Intel(R) Xeon(R) CPU E3-1275 v5 @ 3.60GHz, OS: CentOS 7.2.1511.
It can't be a GCC version problem (at least not on CentOS 7.2.1511) since it's working on that OS.
Did someone made a progress and managed to fix that issue?
Thank you
Koby
Hi guys,
Any of you could try the following command to and post the log file?
[root@localhost _bin]# strace ./metrics_monitor
Mark
Hello, here is strace ./metrics_monitor:
[root@gputest2 _bin]# strace ./metrics_monitor execve("./metrics_monitor", ["./metrics_monitor"], 0x7ffe9a633c20 /* 31 vars */) = 0 brk(NULL) = 0x1db7000 mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f7ea2718000 access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory) open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3 fstat(3, {st_mode=S_IFREG|0644, st_size=84042, ...}) = 0 mmap(NULL, 84042, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f7ea2703000 close(3) = 0 open("/lib64/tls/x86_64/libcttmetrics.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) stat("/lib64/tls/x86_64", 0x7ffc381c61f0) = -1 ENOENT (No such file or directory) open("/lib64/tls/libcttmetrics.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) stat("/lib64/tls", {st_mode=S_IFDIR|0555, st_size=4096, ...}) = 0 open("/lib64/x86_64/libcttmetrics.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) stat("/lib64/x86_64", 0x7ffc381c61f0) = -1 ENOENT (No such file or directory) open("/lib64/libcttmetrics.so", O_RDONLY|O_CLOEXEC) = 3 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\300\r\0\0\0\0\0\0"..., 832) = 832 fstat(3, {st_mode=S_IFREG|0755, st_size=14624, ...}) = 0 mmap(NULL, 2112176, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f7ea22f1000 mprotect(0x7f7ea22f4000, 2093056, PROT_NONE) = 0 mmap(0x7f7ea24f3000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f7ea24f3000 close(3) = 0 open("/lib64/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = 3 read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\270\10\0\0\0\0\0"..., 832) = 832 fstat(3, {st_mode=S_IFREG|0755, st_size=1590720, ...}) = 0 mmap(NULL, 3699296, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f7ea1f69000 mprotect(0x7f7ea20e1000, 2097152, PROT_NONE) = 0 mmap(0x7f7ea22e1000, 49152, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x178000) = 0x7f7ea22e1000 mmap(0x7f7ea22ed000, 12896, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f7ea22ed000 close(3) = 0 open("/lib64/libm.so.6", O_RDONLY|O_CLOEXEC) = 3 read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 W\0\0\0\0\0\0"..., 832) = 832 fstat(3, {st_mode=S_IFREG|0755, st_size=1169408, ...}) = 0 mmap(NULL, 3178728, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f7ea1c60000 mprotect(0x7f7ea1d68000, 2093056, PROT_NONE) = 0 mmap(0x7f7ea1f67000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x107000) = 0x7f7ea1f67000 close(3) = 0 open("/lib64/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 3 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\240*\0\0\0\0\0\0"..., 832) = 832 fstat(3, {st_mode=S_IFREG|0755, st_size=92872, ...}) = 0 mmap(NULL, 2188336, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f7ea1a49000 mprotect(0x7f7ea1a5f000, 2093056, PROT_NONE) = 0 mmap(0x7f7ea1c5e000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x15000) = 0x7f7ea1c5e000 close(3) = 0 open("/lib64/libc.so.6", O_RDONLY|O_CLOEXEC) = 3 read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \5\2\0\0\0\0\0"..., 832) = 832 fstat(3, {st_mode=S_IFREG|0755, st_size=2115824, ...}) = 0 mmap(NULL, 3955040, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f7ea1683000 mprotect(0x7f7ea1840000, 2093056, PROT_NONE) = 0 mmap(0x7f7ea1a3f000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1bc000) = 0x7f7ea1a3f000 mmap(0x7f7ea1a45000, 14688, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f7ea1a45000 close(3) = 0 mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f7ea2701000 mmap(NULL, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f7ea26fe000 arch_prctl(ARCH_SET_FS, 0x7f7ea26fe740) = 0 mprotect(0x7f7ea1a3f000, 16384, PROT_READ) = 0 mprotect(0x7f7ea1c5e000, 4096, PROT_READ) = 0 mprotect(0x7f7ea1f67000, 4096, PROT_READ) = 0 mprotect(0x7f7ea22e1000, 40960, PROT_READ) = 0 mprotect(0x7f7ea24f3000, 4096, PROT_READ) = 0 mprotect(0x601000, 4096, PROT_READ) = 0 mprotect(0x7f7ea271a000, 4096, PROT_READ) = 0 munmap(0x7f7ea2703000, 84042) = 0 brk(NULL) = 0x1db7000 brk(0x1de9000) = 0x1de9000 rt_sigaction(SIGINT, {sa_handler=0x401020, sa_mask=[INT], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f7ea16b8990}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0 getuid() = 0 open("/sys/bus/pci/devices", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 3 fstat(3, {st_mode=S_IFDIR|0755, st_size=0, ...}) = 0 getdents(3, /* 23 entries */, 32768) = 720 open("/sys/bus/pci/devices/0000:00:00.0/class", O_RDONLY) = 4 fstat(4, {st_mode=S_IFREG|0444, st_size=4096, ...}) = 0 read(4, "0x060000\n", 4096) = 9 close(4) = 0 open("/sys/bus/pci/devices/0000:00:02.0/class", O_RDONLY) = 4 fstat(4, {st_mode=S_IFREG|0444, st_size=4096, ...}) = 0 read(4, "0x038000\n", 4096) = 9 close(4) = 0 open("/sys/bus/pci/devices/0000:00:02.0/vendor", O_RDONLY) = 4 fstat(4, {st_mode=S_IFREG|0444, st_size=4096, ...}) = 0 read(4, "0x8086\n", 4096) = 7 close(4) = 0 close(3) = 0 open("/sys/kernel/debug/dri/0/i915_ringstats", O_RDONLY) = -1 ENOENT (No such file or directory) open("/sys/kernel/debug/dri/128/i915_ringstats", O_RDONLY) = 3 fstat(3, {st_mode=S_IFREG|0444, st_size=0, ...}) = 0 read(3, "render ring:0:-1:-1:-1:-1:-1\nbsd"..., 4096) = 152 read(3, "", 4096) = 0 close(3) = 0 open("/sys/class/drm/card0/gt_act_freq_mhz", O_RDONLY) = -1 ENOENT (No such file or directory) write(2, "ERROR: Failed to subscribe for m"..., 53ERROR: Failed to subscribe for metrics, error code 1 ) = 53 exit_group(1) = ? +++ exited with 1 +++
Thanks so much,
We have found this problem and the solution will be available in the next release.
The problem is:
("/sys/class/drm/card0/gt_act_freq_mhz") is not exist on Intel(R) Xeon(R) E3-1285 v4 , so the configuration failed.
As a work around before the new release, you can apply the attached patch to cttmetrics_sample.cpp and recompile it.
Mark
Thank you for the patch Mark.
Any idea when the MSS R3 will be released ?
Thank you very much for the patch, Mark. At least I can see the GPU load now.
Hi Benjamin,
I am glad to see the issue is fixed, Let me know if there is still a problem.
As far as I can see, it should be release quite soon, I can't tell you the exact date, but it should be within a month or two.
Mark
