Media (Intel® oneAPI Video Processing Library, Intel Media SDK)
Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
mfxVideoParam is too hard
yuanbiao
I can't get parameters from DecodeHeader
Usually like nvdecode only need codecid
Who can give me a minimum mfxVideoParams sample
thank you~
JaideepK_Intel
Thank you for posting in intel communities.
Here you can get details about MFXVideoDECODE_DecodeHeader, please follow the below link
MFXVideoDECODE_DecodeHeader need 3 parameters, which are given below.
mfxSession session, mfxBitstream *bs,mfxVideoParam *par
Parameters
session SDK session handle
bs Pointer to the bitstream
par Pointer to the mfxVideoParam structure
>>For more details:
https://github.com/Intel-Media-SDK/MediaSDK/blob/master/doc/mediasdk-man.md#MFXVideoDECODE_DecodeHeader
In the below link you can get details about mfxVideoParam:
https://github.com/Intel-Media-SDK/MediaSDK/blob/master/doc/mediasdk-man.md#mfxVideoParam
Here is the github link: https://github.com/Intel-Media-SDK/MediaSDK/blob/master/samples/sample_decode/src/pipeline_decode.cpp
Jaideep
JaideepK_Intel
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
