Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
mfxVideoParam is too hard
yuanbiao
I can't get parameters from DecodeHeader
Usually like nvdecode only need codecid
Who can give me a minimum mfxVideoParams sample
thank you~
JaideepK_Intel
Thank you for posting in intel communities.
Here you can get details about MFXVideoDECODE_DecodeHeader, please follow the below link
MFXVideoDECODE_DecodeHeader need 3 parameters, which are given below.
mfxSession session, mfxBitstream *bs,mfxVideoParam *par
Parameters
session SDK session handle
bs Pointer to the bitstream
par Pointer to the mfxVideoParam structure
>>For more details:
https://github.com/Intel-Media-SDK/MediaSDK/blob/master/doc/mediasdk-man.md#MFXVideoDECODE_DecodeHeader
In the below link you can get details about mfxVideoParam:
https://github.com/Intel-Media-SDK/MediaSDK/blob/master/doc/mediasdk-man.md#mfxVideoParam
Here is the github link: https://github.com/Intel-Media-SDK/MediaSDK/blob/master/samples/sample_decode/src/pipeline_decode.cpp
Jaideep
JaideepK_Intel
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
