non-monotonous decodetimestamp in sample_encoder
wang_y_1
i add timestamp to sample_encoder demo.
but the decodetimestamp is non-monotonous.
command line is:
./sample_encode h264 -i '/home/centos/work/transcode/IntelCodecTest/1920X1080_i420.yuv' -o enc.h264 -w 1920 -h 1080
following is the code..
Copyright (c) 2005-2016, Intel Corporation
All rights reserved.
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
1. Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
3. Neither the name of the copyright holder nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
This sample was distributed or derived from the Intel's Media Samples package.
The original version of this sample may be obtained from https://software.intel.com/en-us/intel-media-server-studio
or https://software.intel.com/en-us/media-client-solutions-support.
#include "mfx_samples_config.h"
#include "pipeline_encode.h"
#include "sysmem_allocator.h"
#if D3D_SURFACES_SUPPORT
#include "d3d_allocator.h"
#include "d3d11_allocator.h"
#include "d3d_device.h"
#include "d3d11_device.h"
#endif
#ifdef LIBVA_SUPPORT
#include "vaapi_allocator.h"
#include "vaapi_device.h"
#endif
#include "plugin_loader.h"
#if defined (ENABLE_V4L2_SUPPORT)
#include <pthread.h>
#endif
/* obtain the clock tick of an uninterrupted master clock */
msdk_tick time_get_tick(void)
    return msdk_time_get_tick();
    LARGE_INTEGER t1;
    QueryPerformanceCounter(&t1);
    return t1.QuadPart;*/
} /* vm_tick vm_time_get_tick(void) */
/* obtain the clock resolution */
msdk_tick time_get_frequency(void)
    return msdk_time_get_frequency();
    LARGE_INTEGER t1;
    QueryPerformanceFrequency(&t1);
} /* vm_tick vm_time_get_frequency(void) */
CEncTaskPool::CEncTaskPool()
    m_pTasks  = NULL;
    m_pmfxSession       = NULL;
    m_nTaskBufferStart  = 0;
    m_nPoolSize         = 0;
CEncTaskPool::~CEncTaskPool()
    Close();
mfxStatus CEncTaskPool::Init(MFXVideoSession* pmfxSession, CSmplBitstreamWriter* pWriter, mfxU32 nPoolSize, mfxU32 nBufferSize, CSmplBitstreamWriter *pOtherWriter)
    MSDK_CHECK_POINTER(pmfxSession, MFX_ERR_NULL_PTR);
    MSDK_CHECK_POINTER(pWriter, MFX_ERR_NULL_PTR);
    MSDK_CHECK_ERROR(nPoolSize, 0, MFX_ERR_UNDEFINED_BEHAVIOR);
    MSDK_CHECK_ERROR(nBufferSize, 0, MFX_ERR_UNDEFINED_BEHAVIOR);
    // nPoolSize must be even in case of 2 output bitstreams
    if (pOtherWriter && (0 != nPoolSize % 2))
        return MFX_ERR_UNDEFINED_BEHAVIOR;
    m_pmfxSession = pmfxSession;
    m_nPoolSize = nPoolSize;
    m_pTasks = new sTask [m_nPoolSize];
    MSDK_CHECK_POINTER(m_pTasks, MFX_ERR_MEMORY_ALLOC);
    mfxStatus sts = MFX_ERR_NONE;
    if (pOtherWriter) // 2 bitstreams on output
        for (mfxU32 i = 0; i < m_nPoolSize; i+=2)
            sts = m_pTasks[i+0].Init(nBufferSize, pWriter);
            sts = m_pTasks[i+1].Init(nBufferSize, pOtherWriter);
            MSDK_CHECK_RESULT(sts, MFX_ERR_NONE, sts);
    else
        for (mfxU32 i = 0; i < m_nPoolSize; i++)
            sts = m_pTasks.Init(nBufferSize, pWriter);
    return MFX_ERR_NONE;
mfxStatus CEncTaskPool::SynchronizeFirstTask()
    m_statOverall.StartTimeMeasurement();
    MSDK_CHECK_POINTER(m_pTasks, MFX_ERR_NOT_INITIALIZED);
    MSDK_CHECK_POINTER(m_pmfxSession, MFX_ERR_NOT_INITIALIZED);
    // non-null sync point indicates that task is in execution
    if (NULL != m_pTasks[m_nTaskBufferStart].EncSyncP)
        sts = m_pmfxSession->SyncOperation(m_pTasks[m_nTaskBufferStart].EncSyncP, MSDK_WAIT_INTERVAL);
        if (MFX_ERR_NONE == sts)
            m_statFile.StartTimeMeasurement();
            sts = m_pTasks[m_nTaskBufferStart].WriteBitstream();
            m_statFile.StopTimeMeasurement();
            sts = m_pTasks[m_nTaskBufferStart].Reset();
            // move task buffer start to the next executing task
            // the first transform frame to the right with non zero sync point
                m_nTaskBufferStart = (m_nTaskBufferStart + 1) % m_nPoolSize;
                    break;
        else if (MFX_ERR_ABORTED == sts)
            while (!m_pTasks[m_nTaskBufferStart].DependentVppTasks.empty())
                // find out if the error occurred in a VPP task to perform recovery procedure if applicable
                sts = m_pmfxSession->SyncOperation(*m_pTasks[m_nTaskBufferStart].DependentVppTasks.begin(), 0);
                    m_pTasks[m_nTaskBufferStart].DependentVppTasks.pop_front();
                    sts = MFX_ERR_ABORTED; // save the status of the encode task
                    continue; // go to next vpp task
                else
                    break;
        return sts;
    else
        sts = MFX_ERR_NOT_FOUND; // no tasks left in task buffer
    m_statOverall.StopTimeMeasurement();
    return sts;
mfxU32 CEncTaskPool::GetFreeTaskIndex()
    mfxU32 off = 0;
    if (m_pTasks)
        for (off = 0; off < m_nPoolSize; off++)
            if (NULL == m_pTasks[(m_nTaskBufferStart + off) % m_nPoolSize].EncSyncP)
                break;
    if (off >= m_nPoolSize)
        return m_nPoolSize;
    return (m_nTaskBufferStart + off) % m_nPoolSize;
mfxStatus CEncTaskPool::GetFreeTask(sTask **ppTask)
    MSDK_CHECK_POINTER(ppTask, MFX_ERR_NULL_PTR);
    mfxU32 index = GetFreeTaskIndex();
    if (index >= m_nPoolSize)
        return MFX_ERR_NOT_FOUND;
    // return the address of the task
    *ppTask = &m_pTasks[index];
void CEncTaskPool::Close()
    if (m_pTasks)
            m_pTasks.Close();
    MSDK_SAFE_DELETE_ARRAY(m_pTasks);
    m_nPoolSize = 0;
sTask::sTask()
    : EncSyncP(0)
    , pWriter(NULL)
    MSDK_ZERO_MEMORY(mfxBS);
mfxStatus sTask::Init(mfxU32 nBufferSize, CSmplBitstreamWriter *pwriter)
    Close();
    pWriter = pwriter;
    mfxStatus sts = Reset();
    sts = InitMfxBitstream(&mfxBS, nBufferSize);
    MSDK_CHECK_RESULT_SAFE(sts, MFX_ERR_NONE, sts, WipeMfxBitstream(&mfxBS));
    return sts;
mfxStatus sTask::Close()
    WipeMfxBitstream(&mfxBS);
    EncSyncP = 0;
    DependentVppTasks.clear();
mfxStatus sTask::WriteBitstream()
    if (!pWriter)
        return MFX_ERR_NOT_INITIALIZED;
printf("out pts: %d \t %d\n",mfxBS.TimeStamp, mfxBS.DecodeTimeStamp);
    return pWriter->WriteNextFrame(&mfxBS);
mfxStatus sTask::Reset()
    // mark sync point as free
    EncSyncP = NULL;
    // prepare bit stream
    mfxBS.DataOffset = 0;
    mfxBS.DataLength = 0;
mfxStatus CEncodingPipeline::AllocAndInitMVCSeqDesc()
    // a simple example of mfxExtMVCSeqDesc structure filling
    // actually equal to the "Default dependency mode" - when the structure fields are left 0,
    // but we show how to properly allocate and fill the fields
    mfxU32 i;
    // mfxMVCViewDependency array
    m_MVCSeqDesc.NumView = m_nNumView;
    m_MVCSeqDesc.NumViewAlloc = m_nNumView;
    m_MVCSeqDesc.View = new mfxMVCViewDependency[m_MVCSeqDesc.NumViewAlloc];
    MSDK_CHECK_POINTER(m_MVCSeqDesc.View, MFX_ERR_MEMORY_ALLOC);
    for (i = 0; i < m_MVCSeqDesc.NumViewAlloc; ++i)
        MSDK_ZERO_MEMORY(m_MVCSeqDesc.View);
        m_MVCSeqDesc.View.ViewId = (mfxU16) i; // set view number as view id
    // set up dependency for second view
    m_MVCSeqDesc.View[1].NumAnchorRefsL0 = 1;
    m_MVCSeqDesc.View[1].AnchorRefL0[0] = 0;     // ViewId 0 - base view
    m_MVCSeqDesc.View[1].NumNonAnchorRefsL0 = 1;
    m_MVCSeqDesc.View[1].NonAnchorRefL0[0] = 0;  // ViewId 0 - base view
    // viewId array
    m_MVCSeqDesc.NumViewId = m_nNumView;
    m_MVCSeqDesc.NumViewIdAlloc = m_nNumView;
    m_MVCSeqDesc.ViewId = new mfxU16[m_MVCSeqDesc.NumViewIdAlloc];
    MSDK_CHECK_POINTER(m_MVCSeqDesc.ViewId, MFX_ERR_MEMORY_ALLOC);
    for (i = 0; i < m_MVCSeqDesc.NumViewIdAlloc; ++i)
        m_MVCSeqDesc.ViewId = (mfxU16) i;
    // create a single operation point containing all views
    m_MVCSeqDesc.NumOP = 1;
    m_MVCSeqDesc.NumOPAlloc = 1;
    m_MVCSeqDesc.OP = new mfxMVCOperationPoint[m_MVCSeqDesc.NumOPAlloc];
    MSDK_CHECK_POINTER(m_MVCSeqDesc.OP, MFX_ERR_MEMORY_ALLOC);
    for (i = 0; i < m_MVCSeqDesc.NumOPAlloc; ++i)
        MSDK_ZERO_MEMORY(m_MVCSeqDesc.OP);
        m_MVCSeqDesc.OP.NumViews = (mfxU16) m_nNumView;
        m_MVCSeqDesc.OP.NumTargetViews = (mfxU16) m_nNumView;
        m_MVCSeqDesc.OP.TargetViewId = m_MVCSeqDesc.ViewId; // points to mfxExtMVCSeqDesc::ViewId
mfxStatus CEncodingPipeline::AllocAndInitVppDoNotUse()
    m_VppDoNotUse.NumAlg = 4;
    m_VppDoNotUse.AlgList = new mfxU32 [m_VppDoNotUse.NumAlg];
    MSDK_CHECK_POINTER(m_VppDoNotUse.AlgList,  MFX_ERR_MEMORY_ALLOC);
    m_VppDoNotUse.AlgList[0] = MFX_EXTBUFF_VPP_DENOISE; // turn off denoising (on by default)
    m_VppDoNotUse.AlgList[1] = MFX_EXTBUFF_VPP_SCENE_ANALYSIS; // turn off scene analysis (on by default)
    m_VppDoNotUse.AlgList[2] = MFX_EXTBUFF_VPP_DETAIL; // turn off detail enhancement (on by default)
    m_VppDoNotUse.AlgList[3] = MFX_EXTBUFF_VPP_PROCAMP; // turn off processing amplified (on by default)
} // CEncodingPipeline::AllocAndInitVppDoNotUse()
void CEncodingPipeline::FreeMVCSeqDesc()
    MSDK_SAFE_DELETE_ARRAY(m_MVCSeqDesc.View);
    MSDK_SAFE_DELETE_ARRAY(m_MVCSeqDesc.ViewId);
    MSDK_SAFE_DELETE_ARRAY(m_MVCSeqDesc.OP);
void CEncodingPipeline::FreeVppDoNotUse()
    MSDK_SAFE_DELETE_ARRAY(m_VppDoNotUse.AlgList);
mfxStatus CEncodingPipeline::InitMfxEncParams(sInputParams *pInParams)
    m_mfxEncParams.mfx.CodecId                 = pInParams->CodecId;
    m_mfxEncParams.mfx.TargetUsage             = pInParams->nTargetUsage; // trade-off between quality and speed
    m_mfxEncParams.mfx.RateControlMethod       = pInParams->nRateControlMethod;
    m_mfxEncParams.mfx.GopRefDist = pInParams->nGopRefDist;
    m_mfxEncParams.mfx.GopPicSize = pInParams->nGopPicSize;
    m_mfxEncParams.mfx.NumRefFrame = pInParams->nNumRefFrame > 0?pInParams->nNumRefFrame : 1;
    m_mfxEncParams.mfx.IdrInterval = pInParams->nIdrInterval;
    if (m_mfxEncParams.mfx.RateControlMethod == MFX_RATECONTROL_CQP)
        m_mfxEncParams.mfx.QPI = pInParams->nQPI;
        m_mfxEncParams.mfx.QPP = pInParams->nQPP;
        m_mfxEncParams.mfx.QPB = pInParams->nQPB;
    else
        m_mfxEncParams.mfx.TargetKbps = pInParams->nBitRate; // in Kbps
    m_mfxEncParams.mfx.NumSlice = pInParams->nNumSlice;
    ConvertFrameRate(pInParams->dFrameRate, &m_mfxEncParams.mfx.FrameInfo.FrameRateExtN, &m_mfxEncParams.mfx.FrameInfo.FrameRateExtD);
    m_mfxEncParams.mfx.EncodedOrder            = 0; // binary flag, 0 signals encoder to take frames in display order
    // specify memory type
    if (D3D9_MEMORY == pInParams->memType || D3D11_MEMORY == pInParams->memType)
        m_mfxEncParams.IOPattern = MFX_IOPATTERN_IN_VIDEO_MEMORY;
    else
        m_mfxEncParams.IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY;
    // frame info parameters
    m_mfxEncParams.mfx.FrameInfo.FourCC       = MFX_FOURCC_NV12;
    m_mfxEncParams.mfx.FrameInfo.ChromaFormat = MFX_CHROMAFORMAT_YUV420;
    m_mfxEncParams.mfx.FrameInfo.PicStruct    = pInParams->nPicStruct;
    // set frame size and crops
    if(pInParams->CodecId==MFX_CODEC_HEVC && !memcmp(pInParams->pluginParams.pluginGuid.Data,MFX_PLUGINID_HEVCE_HW.Data,sizeof(MFX_PLUGINID_HEVCE_HW.Data)))
        // In case of HW HEVC decoder width and height must be aligned to 32 pixels. This limitation is planned to be removed in later versions of plugin
        m_mfxEncParams.mfx.FrameInfo.Width  = MSDK_ALIGN32(pInParams->nDstWidth);
        m_mfxEncParams.mfx.FrameInfo.Height = MSDK_ALIGN32(pInParams->nDstHeight);
    else
        // width must be a multiple of 16
        // height must be a multiple of 16 in case of frame picture and a multiple of 32 in case of field picture
        m_mfxEncParams.mfx.FrameInfo.Width  = MSDK_ALIGN16(pInParams->nDstWidth);
        m_mfxEncParams.mfx.FrameInfo.Height = (MFX_PICSTRUCT_PROGRESSIVE == m_mfxEncParams.mfx.FrameInfo.PicStruct)?
            MSDK_ALIGN16(pInParams->nDstHeight) : MSDK_ALIGN32(pInParams->nDstHeight);
    m_mfxEncParams.mfx.FrameInfo.CropX = 0;
    m_mfxEncParams.mfx.FrameInfo.CropY = 0;
    m_mfxEncParams.mfx.FrameInfo.CropW = pInParams->nDstWidth;
    m_mfxEncParams.mfx.FrameInfo.CropH = pInParams->nDstHeight;
    // we don't specify profile and level and let the encoder choose those basing on parameters
    // we must specify profile only for MVC codec
    if (MVC_ENABLED & m_MVCflags)
        m_mfxEncParams.mfx.CodecProfile = MFX_PROFILE_AVC_STEREO_HIGH;
    // configure and attach external parameters
    if (MVC_ENABLED & pInParams->MVC_flags)
        m_EncExtParams.push_back((mfxExtBuffer *)&m_MVCSeqDesc);
    if (MVC_VIEWOUTPUT & pInParams->MVC_flags)
        // ViewOuput option requested
        m_CodingOption.ViewOutput = MFX_CODINGOPTION_ON;
        m_EncExtParams.push_back((mfxExtBuffer *)&m_CodingOption);
    // configure the depth of the look ahead BRC if specified in command line
    if (pInParams->nLADepth || pInParams->nMaxSliceSize || pInParams->nBRefType)
        m_CodingOption2.LookAheadDepth = pInParams->nLADepth;
        m_CodingOption2.MaxSliceSize   = pInParams->nMaxSliceSize;
        m_CodingOption2.BRefType = pInParams->nBRefType;
        m_EncExtParams.push_back((mfxExtBuffer *)&m_CodingOption2);
    // In case of HEVC when height and/or width divided with 8 but not divided with 16
    // add extended parameter to increase performance
    if ( ( !((m_mfxEncParams.mfx.FrameInfo.CropW & 15 ) ^ 8 ) ||
        !((m_mfxEncParams.mfx.FrameInfo.CropH & 15 ) ^ 8 ) ) &&
        (m_mfxEncParams.mfx.CodecId == MFX_CODEC_HEVC) )
        m_ExtHEVCParam.PicWidthInLumaSamples = m_mfxEncParams.mfx.FrameInfo.CropW;
        m_ExtHEVCParam.PicHeightInLumaSamples = m_mfxEncParams.mfx.FrameInfo.CropH;
        m_EncExtParams.push_back((mfxExtBuffer*)&m_ExtHEVCParam);
    if (!m_EncExtParams.empty())
        m_mfxEncParams.ExtParam = &m_EncExtParams[0]; // vector is stored linearly in memory
        m_mfxEncParams.NumExtParam = (mfxU16)m_EncExtParams.size();
    // JPEG encoder settings overlap with other encoders settings in mfxInfoMFX structure
    if (MFX_CODEC_JPEG == pInParams->CodecId)
        m_mfxEncParams.mfx.Interleaved = 1;
        m_mfxEncParams.mfx.Quality = pInParams->nQuality;
        m_mfxEncParams.mfx.RestartInterval = 0;
        MSDK_ZERO_MEMORY(m_mfxEncParams.mfx.reserved5);
    m_mfxEncParams.AsyncDepth = pInParams->nAsyncDepth;
mfxStatus CEncodingPipeline::InitMfxVppParams(sInputParams *pInParams)
    MSDK_CHECK_POINTER(pInParams,  MFX_ERR_NULL_PTR);
        m_mfxVppParams.IOPattern = MFX_IOPATTERN_IN_VIDEO_MEMORY | MFX_IOPATTERN_OUT_VIDEO_MEMORY;
    else
        m_mfxVppParams.IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY | MFX_IOPATTERN_OUT_SYSTEM_MEMORY;
    // input frame info
    if (isV4L2InputEnabled)
        m_mfxVppParams.vpp.In.FourCC    = v4l2Pipeline.ConvertToMFXFourCC(pInParams->v4l2Format);
#else
    m_mfxVppParams.vpp.In.FourCC    = MFX_FOURCC_NV12;
#endif
    m_mfxVppParams.vpp.In.PicStruct = pInParams->nPicStruct;;
    ConvertFrameRate(pInParams->dFrameRate, &m_mfxVppParams.vpp.In.FrameRateExtN, &m_mfxVppParams.vpp.In.FrameRateExtD);
    m_mfxVppParams.vpp.In.Width     = MSDK_ALIGN16(pInParams->nWidth);
    m_mfxVppParams.vpp.In.Height    = (MFX_PICSTRUCT_PROGRESSIVE == m_mfxVppParams.vpp.In.PicStruct)?
        MSDK_ALIGN16(pInParams->nHeight) : MSDK_ALIGN32(pInParams->nHeight);
    // set crops in input mfxFrameInfo for correct work of file reader
    // VPP itself ignores crops at initialization
    m_mfxVppParams.vpp.In.CropW = pInParams->nWidth;
    m_mfxVppParams.vpp.In.CropH = pInParams->nHeight;
    // fill output frame info
    MSDK_MEMCPY_VAR(m_mfxVppParams.vpp.Out,&m_mfxVppParams.vpp.In, sizeof(mfxFrameInfo));
        m_mfxVppParams.vpp.Out.FourCC    = MFX_FOURCC_NV12;
#endif
    // only resizing is supported
    m_mfxVppParams.vpp.Out.Width = MSDK_ALIGN16(pInParams->nDstWidth);
    m_mfxVppParams.vpp.Out.Height = (MFX_PICSTRUCT_PROGRESSIVE == m_mfxVppParams.vpp.Out.PicStruct)?
    AllocAndInitVppDoNotUse();
    m_VppExtParams.push_back((mfxExtBuffer *)&m_VppDoNotUse);
        m_VppExtParams.push_back((mfxExtBuffer *)&m_MVCSeqDesc);
    m_mfxVppParams.ExtParam = &m_VppExtParams[0]; // vector is stored linearly in memory
    m_mfxVppParams.NumExtParam = (mfxU16)m_VppExtParams.size();
    m_mfxVppParams.AsyncDepth = pInParams->nAsyncDepth;
mfxStatus CEncodingPipeline::CreateHWDevice()
#if MFX_D3D11_SUPPORT
    if (D3D11_MEMORY == m_memType)
        m_hwdev = new CD3D11Device();
    else
#endif // #if MFX_D3D11_SUPPORT
        m_hwdev = new CD3D9Device();
    if (NULL == m_hwdev)
        return MFX_ERR_MEMORY_ALLOC;
    sts = m_hwdev->Init(
        NULL,
        0,
        MSDKAdapter::GetNumber(GetFirstSession()));
#elif LIBVA_SUPPORT
    m_hwdev = CreateVAAPIDevice();
    sts = m_hwdev->Init(NULL, 0, MSDKAdapter::GetNumber(GetFirstSession()));
#endif
mfxStatus CEncodingPipeline::ResetDevice()
    if (D3D9_MEMORY == m_memType || D3D11_MEMORY == m_memType)
        return m_hwdev->Reset();
mfxStatus CEncodingPipeline::AllocFrames()
    MSDK_CHECK_POINTER(GetFirstEncoder(), MFX_ERR_NOT_INITIALIZED);
    mfxFrameAllocRequest EncRequest;
    mfxFrameAllocRequest VppRequest[2];
    mfxU16 nEncSurfNum = 0; // number of surfaces for encoder
    mfxU16 nVppSurfNum = 0; // number of surfaces for vpp
    MSDK_ZERO_MEMORY(EncRequest);
    MSDK_ZERO_MEMORY(VppRequest[0]);
    MSDK_ZERO_MEMORY(VppRequest[1]);
    // Calculate the number of surfaces for components.
    // QueryIOSurf functions tell how many surfaces are required to produce at least 1 output.
    // To achieve better performance we provide extra surfaces.
    // 1 extra surface at input allows to get 1 extra output.
    sts = GetFirstEncoder()->QueryIOSurf(&m_mfxEncParams, &EncRequest);
    if (EncRequest.NumFrameSuggested < m_mfxEncParams.AsyncDepth)
    // The number of surfaces shared by vpp output and encode input.
    nEncSurfNum = EncRequest.NumFrameSuggested;
    if (m_pmfxVPP)
        // VppRequest[0] for input frames request, VppRequest[1] for output frames request
        sts = m_pmfxVPP->QueryIOSurf(&m_mfxVppParams, VppRequest);
        // The number of surfaces for vpp input - so that vpp can work at async depth = m_nAsyncDepth
        nVppSurfNum = VppRequest[0].NumFrameSuggested;
        // If surfaces are shared by 2 components, c1 and c2. NumSurf = c1_out + c2_in - AsyncDepth + 1
        nEncSurfNum += nVppSurfNum - m_mfxEncParams.AsyncDepth + 1;
    // prepare allocation requests
    EncRequest.NumFrameSuggested = EncRequest.NumFrameMin = nEncSurfNum;
    MSDK_MEMCPY_VAR(EncRequest.Info, &(m_mfxEncParams.mfx.FrameInfo), sizeof(mfxFrameInfo));
    if (m_pmfxVPP)
        EncRequest.Type |= MFX_MEMTYPE_FROM_VPPOUT; // surfaces are shared between vpp output and encode input
    // alloc frames for encoder
    sts = m_pMFXAllocator->Alloc(m_pMFXAllocator->pthis, &EncRequest, &m_EncResponse);
    // alloc frames for vpp if vpp is enabled
    if (m_pmfxVPP)
        VppRequest[0].NumFrameSuggested = VppRequest[0].NumFrameMin = nVppSurfNum;
        MSDK_MEMCPY_VAR(VppRequest[0].Info, &(m_mfxVppParams.mfx.FrameInfo), sizeof(mfxFrameInfo));
            VppRequest[0].Type |= MFX_MEMTYPE_EXPORT_FRAME;
#endif
        sts = m_pMFXAllocator->Alloc(m_pMFXAllocator->pthis, &(VppRequest[0]), &m_VppResponse);
    // prepare mfxFrameSurface1 array for encoder
    m_pEncSurfaces = new mfxFrameSurface1 [m_EncResponse.NumFrameActual];
    MSDK_CHECK_POINTER(m_pEncSurfaces, MFX_ERR_MEMORY_ALLOC);
    for (int i = 0; i < m_EncResponse.NumFrameActual; i++)
        memset(&(m_pEncSurfaces), 0, sizeof(mfxFrameSurface1));
        MSDK_MEMCPY_VAR(m_pEncSurfaces.Info, &(m_mfxEncParams.mfx.FrameInfo), sizeof(mfxFrameInfo));
        if (m_bExternalAlloc)
            m_pEncSurfaces.Data.MemId = m_EncResponse.mids;
        else
            // get YUV pointers
            sts = m_pMFXAllocator->Lock(m_pMFXAllocator->pthis, m_EncResponse.mids, &(m_pEncSurfaces.Data));
    // prepare mfxFrameSurface1 array for vpp if vpp is enabled
    if (m_pmfxVPP)
        m_pVppSurfaces = new mfxFrameSurface1 [m_VppResponse.NumFrameActual];
        MSDK_CHECK_POINTER(m_pVppSurfaces, MFX_ERR_MEMORY_ALLOC);
        for (int i = 0; i < m_VppResponse.NumFrameActual; i++)
            MSDK_ZERO_MEMORY(m_pVppSurfaces);
            MSDK_MEMCPY_VAR(m_pVppSurfaces.Info, &(m_mfxVppParams.mfx.FrameInfo), sizeof(mfxFrameInfo));
                m_pVppSurfaces.Data.MemId = m_VppResponse.mids;
            else
                sts = m_pMFXAllocator->Lock(m_pMFXAllocator->pthis, m_VppResponse.mids, &(m_pVppSurfaces.Data));
mfxStatus CEncodingPipeline::CreateAllocator()
        sts = CreateHWDevice();
        mfxHDL hdl = NULL;
        mfxHandleType hdl_t =
            D3D11_MEMORY == m_memType ? MFX_HANDLE_D3D11_DEVICE :
            MFX_HANDLE_D3D9_DEVICE_MANAGER;
        sts = m_hwdev->GetHandle(hdl_t, &hdl);
        // handle is needed for HW library only
        mfxIMPL impl = 0;
        m_mfxSession.QueryIMPL(&impl);
        if (impl != MFX_IMPL_SOFTWARE)
            sts = m_mfxSession.SetHandle(hdl_t, hdl);
        // create D3D allocator
            m_pMFXAllocator = new D3D11FrameAllocator;
            MSDK_CHECK_POINTER(m_pMFXAllocator, MFX_ERR_MEMORY_ALLOC);
            D3D11AllocatorParams *pd3dAllocParams = new D3D11AllocatorParams;
            MSDK_CHECK_POINTER(pd3dAllocParams, MFX_ERR_MEMORY_ALLOC);
            pd3dAllocParams->pDevice = reinterpret_cast<ID3D11Device *>(hdl);
            m_pmfxAllocatorParams = pd3dAllocParams;
        else
            m_pMFXAllocator = new D3DFrameAllocator;
            D3DAllocatorParams *pd3dAllocParams = new D3DAllocatorParams;
            pd3dAllocParams->pManager = reinterpret_cast<IDirect3DDeviceManager9 *>(hdl);
        /* In case of video memory we must provide MediaSDK with external allocator
        thus we demonstrate "external allocator" usage model.
        Call SetAllocator to pass allocator to Media SDK */
        sts = m_mfxSession.SetFrameAllocator(m_pMFXAllocator);
        m_bExternalAlloc = true;
#endif
        /* It's possible to skip failed result here and switch to SW implementation,
        but we don't process this way */
        mfxHDL hdl = NULL;
        sts = m_hwdev->GetHandle(MFX_HANDLE_VA_DISPLAY, &hdl);
        // provide device manager to MediaSDK
        sts = m_mfxSession.SetHandle(MFX_HANDLE_VA_DISPLAY, hdl);
        // create VAAPI allocator
        m_pMFXAllocator = new vaapiFrameAllocator;
        vaapiAllocatorParams *p_vaapiAllocParams = new vaapiAllocatorParams;
        MSDK_CHECK_POINTER(p_vaapiAllocParams, MFX_ERR_MEMORY_ALLOC);
        p_vaapiAllocParams->m_dpy = (VADisplay)hdl;
        m_pmfxAllocatorParams = p_vaapiAllocParams;
        Call SetAllocator to pass allocator to mediasdk */
#endif
    else
        //in case of system memory allocator we also have to pass MFX_HANDLE_VA_DISPLAY to HW library
        mfxIMPL impl;
        if(MFX_IMPL_HARDWARE == MFX_IMPL_BASETYPE(impl))
            mfxHDL hdl = NULL;
#endif
        // create system memory allocator
        m_pMFXAllocator = new SysMemFrameAllocator;
        /* In case of system memory we demonstrate "no external allocator" usage model.
        We don't call SetAllocator, Media SDK uses internal allocator.
        We use system memory allocator simply as a memory manager for application*/
    // initialize memory allocator
    sts = m_pMFXAllocator->Init(m_pmfxAllocatorParams);
void CEncodingPipeline::DeleteFrames()
    // delete surfaces array
    MSDK_SAFE_DELETE_ARRAY(m_pEncSurfaces);
    MSDK_SAFE_DELETE_ARRAY(m_pVppSurfaces);
    // delete frames
    if (m_pMFXAllocator)
        m_pMFXAllocator->Free(m_pMFXAllocator->pthis, &m_EncResponse);
        m_pMFXAllocator->Free(m_pMFXAllocator->pthis, &m_VppResponse);
void CEncodingPipeline::DeleteHWDevice()
    MSDK_SAFE_DELETE(m_hwdev);
void CEncodingPipeline::DeleteAllocator()
    // delete allocator
    MSDK_SAFE_DELETE(m_pMFXAllocator);
    MSDK_SAFE_DELETE(m_pmfxAllocatorParams);
    DeleteHWDevice();
CEncodingPipeline::CEncodingPipeline()
    m_pmfxENC = NULL;
    m_pmfxVPP = NULL;
    m_pMFXAllocator = NULL;
    m_pmfxAllocatorParams = NULL;
    m_memType = SYSTEM_MEMORY;
    m_bExternalAlloc = false;
    m_pEncSurfaces = NULL;
    m_pVppSurfaces = NULL;
    m_MVCflags = MVC_DISABLED;
    m_nNumView = 0;
    m_FileWriters.first = m_FileWriters.second = NULL;
    MSDK_ZERO_MEMORY(m_MVCSeqDesc);
    m_MVCSeqDesc.Header.BufferId = MFX_EXTBUFF_MVC_SEQ_DESC;
    m_MVCSeqDesc.Header.BufferSz = sizeof(m_MVCSeqDesc);
    MSDK_ZERO_MEMORY(m_VppDoNotUse);
    m_VppDoNotUse.Header.BufferId = MFX_EXTBUFF_VPP_DONOTUSE;
    m_VppDoNotUse.Header.BufferSz = sizeof(m_VppDoNotUse);
    MSDK_ZERO_MEMORY(m_CodingOption);
    m_CodingOption.Header.BufferId = MFX_EXTBUFF_CODING_OPTION;
    m_CodingOption.Header.BufferSz = sizeof(m_CodingOption);
    MSDK_ZERO_MEMORY(m_CodingOption2);
    m_CodingOption2.Header.BufferId = MFX_EXTBUFF_CODING_OPTION2;
    m_CodingOption2.Header.BufferSz = sizeof(m_CodingOption2);
    MSDK_ZERO_MEMORY(m_ExtHEVCParam);
    m_ExtHEVCParam.Header.BufferId = MFX_EXTBUFF_HEVC_PARAM;
    m_ExtHEVCParam.Header.BufferSz = sizeof(m_ExtHEVCParam);
    m_hwdev = NULL;
#endif
    MSDK_ZERO_MEMORY(m_mfxEncParams);
    MSDK_ZERO_MEMORY(m_mfxVppParams);
    MSDK_ZERO_MEMORY(m_EncResponse);
    MSDK_ZERO_MEMORY(m_VppResponse);
    isV4L2InputEnabled = false;
    m_nFramesToProcess = 0;
CEncodingPipeline::~CEncodingPipeline()
    Close();
void CEncodingPipeline::SetMultiView()
    m_FileReader.SetMultiView();
mfxStatus CEncodingPipeline::InitFileWriter(CSmplBitstreamWriter **ppWriter, const msdk_char *filename)
    MSDK_CHECK_ERROR(ppWriter, NULL, MFX_ERR_NULL_PTR);
    MSDK_SAFE_DELETE(*ppWriter);
    *ppWriter = new CSmplBitstreamWriter;
    MSDK_CHECK_POINTER(*ppWriter, MFX_ERR_MEMORY_ALLOC);
    mfxStatus sts = (*ppWriter)->Init(filename);
    return sts;
mfxStatus CEncodingPipeline::InitFileWriters(sInputParams *pParams)
    MSDK_CHECK_POINTER(pParams, MFX_ERR_NULL_PTR);
    // prepare output file writers
    // ViewOutput mode: output in single bitstream
    if ( (MVC_VIEWOUTPUT & pParams->MVC_flags) && (pParams->dstFileBuff.size() <= 1))
        sts = InitFileWriter(&m_FileWriters.first, pParams->dstFileBuff[0]);
        m_FileWriters.second = m_FileWriters.first;
    // ViewOutput mode: 2 bitstreams in separate files
    else if ( (MVC_VIEWOUTPUT & pParams->MVC_flags) && (pParams->dstFileBuff.size() <= 2))
        sts = InitFileWriter(&m_FileWriters.second, pParams->dstFileBuff[1]);
    // ViewOutput mode: 3 bitstreams - 2 separate & 1 merged
    else if ( (MVC_VIEWOUTPUT & pParams->MVC_flags) && (pParams->dstFileBuff.size() <= 3))
        std::auto_ptr<CSmplBitstreamDuplicateWriter> first(new CSmplBitstreamDuplicateWriter);
        // init first duplicate writer
        MSDK_CHECK_POINTER(first.get(), MFX_ERR_MEMORY_ALLOC);
        sts = first->Init(pParams->dstFileBuff[0]);
        sts = first->InitDuplicate(pParams->dstFileBuff[2]);
        // init second duplicate writer
        std::auto_ptr<CSmplBitstreamDuplicateWriter> second(new CSmplBitstreamDuplicateWriter);
        MSDK_CHECK_POINTER(second.get(), MFX_ERR_MEMORY_ALLOC);
        sts = second->Init(pParams->dstFileBuff[1]);
        sts = second->JoinDuplicate(first.get());
        m_FileWriters.first = first.release();
        m_FileWriters.second = second.release();
    // not ViewOutput mode
    else
    return sts;
mfxStatus CEncodingPipeline::Init(sInputParams *pParams)
#if defined ENABLE_V4L2_SUPPORT
    isV4L2InputEnabled = pParams->isV4L2InputEnabled;
#endif
    if (!isV4L2InputEnabled)
        // prepare input file reader
        sts = m_FileReader.Init(pParams->strSrcFile,
            pParams->ColorFormat,
            pParams->numViews,
            pParams->srcFileBuff);
    m_MVCflags = pParams->MVC_flags;
    sts = InitFileWriters(pParams);
    mfxInitParam initPar;
    mfxVersion version;     // real API version with which library is initialized
    MSDK_ZERO_MEMORY(initPar);
    // we set version to 1.0 and later we will query actual version of the library which will got leaded
    initPar.Version.Major = 1;
    initPar.Version.Minor = 0;
    initPar.GPUCopy = pParams->gpuCopy;
    // Init session
    if (pParams->bUseHWLib) {
        // try searching on all display adapters
        initPar.Implementation = MFX_IMPL_HARDWARE_ANY;
        // if d3d11 surfaces are used ask the library to run acceleration through D3D11
        // feature may be unsupported due to OS or MSDK API version
        if (D3D11_MEMORY == pParams->memType)
            initPar.Implementation |= MFX_IMPL_VIA_D3D11;
        sts = m_mfxSession.InitEx(initPar);
        // MSDK API version may not support multiple adapters - then try initialize on the default
        if (MFX_ERR_NONE != sts) {
            initPar.Implementation = (initPar.Implementation & !MFX_IMPL_HARDWARE_ANY) | MFX_IMPL_HARDWARE;
    } else {
        initPar.Implementation = MFX_IMPL_SOFTWARE;
    sts = MFXQueryVersion(m_mfxSession , &version); // get real API version of the loaded library
    if ((pParams->MVC_flags & MVC_ENABLED) != 0 && !CheckVersion(&version, MSDK_FEATURE_MVC)) {
        msdk_printf(MSDK_STRING("error: MVC is not supported in the %d.%d API version\n"),
            version.Major, version.Minor);
        return MFX_ERR_UNSUPPORTED;
    if ((pParams->MVC_flags & MVC_VIEWOUTPUT) != 0 && !CheckVersion(&version, MSDK_FEATURE_MVC_VIEWOUTPUT)) {
        msdk_printf(MSDK_STRING("error: MVC Viewoutput is not supported in the %d.%d API version\n"),
    if ((pParams->CodecId == MFX_CODEC_JPEG) && !CheckVersion(&version, MSDK_FEATURE_JPEG_ENCODE)) {
        msdk_printf(MSDK_STRING("error: Jpeg is not supported in the %d.%d API version\n"),
    if ((pParams->nRateControlMethod == MFX_RATECONTROL_LA) && !CheckVersion(&version, MSDK_FEATURE_LOOK_AHEAD)) {
        msdk_printf(MSDK_STRING("error: Look ahead is not supported in the %d.%d API version\n"),
    if (CheckVersion(&version, MSDK_FEATURE_PLUGIN_API)) {
        /* Here we actually define the following codec initialization scheme:
        *  1. If plugin path or guid is specified: we load user-defined plugin (example: HEVC encoder plugin)
        *  2. If plugin path not specified:
        *    2.a) we check if codec is distributed as a mediasdk plugin and load it if yes
        *    2.b) if codec is not in the list of mediasdk plugins, we assume, that it is supported inside mediasdk library
        if (pParams->pluginParams.type == MFX_PLUGINLOAD_TYPE_FILE && msdk_strnlen(pParams->pluginParams.strPluginPath,sizeof(pParams->pluginParams.strPluginPath)))
            m_pUserModule.reset(new MFXVideoUSER(m_mfxSession));
            m_pPlugin.reset(LoadPlugin(MFX_PLUGINTYPE_VIDEO_ENCODE, m_mfxSession, pParams->pluginParams.pluginGuid, 1, pParams->pluginParams.strPluginPath, (mfxU32)msdk_strnlen(pParams->pluginParams.strPluginPath,sizeof(pParams->pluginParams.strPluginPath))));
            if (m_pPlugin.get() == NULL) sts = MFX_ERR_UNSUPPORTED;
        else
            if (AreGuidsEqual(pParams->pluginParams.pluginGuid, MSDK_PLUGINGUID_NULL))
                mfxIMPL impl = pParams->bUseHWLib ? MFX_IMPL_HARDWARE : MFX_IMPL_SOFTWARE;
                pParams->pluginParams.pluginGuid = msdkGetPluginUID(impl, MSDK_VENCODE, pParams->CodecId);
            if (!AreGuidsEqual(pParams->pluginParams.pluginGuid, MSDK_PLUGINGUID_NULL))
                m_pPlugin.reset(LoadPlugin(MFX_PLUGINTYPE_VIDEO_ENCODE, m_mfxSession, pParams->pluginParams.pluginGuid, 1));
            if(sts==MFX_ERR_UNSUPPORTED)
                msdk_printf(MSDK_STRING("Default plugin cannot be loaded (possibly you have to define plugin explicitly)\n"));
    // set memory type
    m_memType = pParams->memType;
    // create and init frame allocator
    sts = CreateAllocator();
    sts = InitMfxEncParams(pParams);
    sts = InitMfxVppParams(pParams);
    // MVC specific options
        sts = AllocAndInitMVCSeqDesc();
    // create encoder
    m_pmfxENC = new MFXVideoENCODE(m_mfxSession);
    MSDK_CHECK_POINTER(m_pmfxENC, MFX_ERR_MEMORY_ALLOC);
    // create preprocessor if resizing was requested from command line
    // or if different FourCC is set in InitMfxVppParams
    if (pParams->nWidth  != pParams->nDstWidth ||
        pParams->nHeight != pParams->nDstHeight ||
        m_mfxVppParams.vpp.In.FourCC != m_mfxVppParams.vpp.Out.FourCC)
        m_pmfxVPP = new MFXVideoVPP(m_mfxSession);
        MSDK_CHECK_POINTER(m_pmfxVPP, MFX_ERR_MEMORY_ALLOC);
    sts = ResetMFXComponents(pParams);
    InitV4L2Pipeline(pParams);
    m_nFramesToProcess = pParams->nNumFrames;
void CEncodingPipeline::InitV4L2Pipeline(sInputParams *pParams)
        int i;
        v4l2Pipeline.Init(pParams->DeviceName,
            pParams->nWidth, pParams->nHeight,
            m_VppResponse.NumFrameActual,
            pParams->v4l2Format,
            pParams->MipiMode,
            pParams->MipiPort);
        v4l2Pipeline.V4L2Alloc();
        for(i=0; i<m_VppResponse.NumFrameActual; i++)
            buffers.index = i;
            struct vaapiMemId *vaapi = (struct vaapiMemId *)m_pVppSurfaces.Data.MemId;
            buffers.fd = vaapi->m_buffer_info.handle;
            v4l2Pipeline.V4L2QueueBuffer(&buffers);
#endif
mfxStatus CEncodingPipeline::CaptureStartV4L2Pipeline()
        v4l2Pipeline.V4L2StartCapture();
        v4l2Device *m_v4l2Display = &v4l2Pipeline;
        if (pthread_create(&m_PollThread, NULL, PollingThread, (void *)m_v4l2Display))
            msdk_printf(MSDK_STRING("Couldn't create v4l2 polling thread\n"));
            return MFX_ERR_UNKNOWN;
#endif
void CEncodingPipeline::CaptureStopV4L2Pipeline()
        pthread_join(m_PollThread, NULL);
        v4l2Pipeline.V4L2StopCapture();
#endif
void CEncodingPipeline::Close()
    if (m_FileWriters.first)
        msdk_printf(MSDK_STRING("Frame number: %u\r\n"), m_FileWriters.first->m_nProcessedFramesNum);
#ifdef TIME_STATS
        mfxF64 ProcDeltaTime = m_statOverall.GetDeltaTime() - m_statFile.GetDeltaTime() - m_TaskPool.GetFileStatistics().GetDeltaTime();
        msdk_printf(MSDK_STRING("Encoding fps: %.0f"), m_FileWriters.first->m_nProcessedFramesNum / ProcDeltaTime);
#endif
    MSDK_SAFE_DELETE(m_pmfxENC);
    MSDK_SAFE_DELETE(m_pmfxVPP);
    FreeMVCSeqDesc();
    FreeVppDoNotUse();
    DeleteFrames();
    m_pPlugin.reset();
    m_TaskPool.Close();
    m_mfxSession.Close();
    m_FileReader.Close();
    FreeFileWriters();
    // allocator if used as external for MediaSDK must be deleted after SDK components
    DeleteAllocator();
void CEncodingPipeline::FreeFileWriters()
    if (m_FileWriters.second == m_FileWriters.first)
        m_FileWriters.second = NULL; // second do not own the writer - just forget pointer
        m_FileWriters.first->Close();
    MSDK_SAFE_DELETE(m_FileWriters.first);
    if (m_FileWriters.second)
        m_FileWriters.second->Close();
    MSDK_SAFE_DELETE(m_FileWriters.second);
mfxStatus CEncodingPipeline::ResetMFXComponents(sInputParams* pParams)
    MSDK_CHECK_POINTER(m_pmfxENC, MFX_ERR_NOT_INITIALIZED);
    sts = m_pmfxENC->Close();
    MSDK_IGNORE_MFX_STS(sts, MFX_ERR_NOT_INITIALIZED);
    if (m_pmfxVPP)
        sts = m_pmfxVPP->Close();
    // free allocated frames
    DeleteFrames();
    m_TaskPool.Close();
    sts = AllocFrames();
    sts = m_pmfxENC->Init(&m_mfxEncParams);
    if (MFX_WRN_PARTIAL_ACCELERATION == sts)
        msdk_printf(MSDK_STRING("WARNING: partial acceleration\n"));
        MSDK_IGNORE_MFX_STS(sts, MFX_WRN_PARTIAL_ACCELERATION);
    if (m_pmfxVPP)
        sts = m_pmfxVPP->Init(&m_mfxVppParams);
    mfxU32 nEncodedDataBufferSize = m_mfxEncParams.mfx.FrameInfo.Width * m_mfxEncParams.mfx.FrameInfo.Height * 4;
    sts = m_TaskPool.Init(&m_mfxSession, m_FileWriters.first, m_mfxEncParams.AsyncDepth, nEncodedDataBufferSize, m_FileWriters.second);
mfxStatus CEncodingPipeline::AllocateSufficientBuffer(mfxBitstream* pBS)
    MSDK_CHECK_POINTER(pBS, MFX_ERR_NULL_PTR);
    mfxVideoParam par;
    MSDK_ZERO_MEMORY(par);
    // find out the required buffer size
    mfxStatus sts = GetFirstEncoder()->GetVideoParam(&par);
    // reallocate bigger buffer for output
    sts = ExtendMfxBitstream(pBS, par.mfx.BufferSizeInKB * 1000);
    MSDK_CHECK_RESULT_SAFE(sts, MFX_ERR_NONE, sts, WipeMfxBitstream(pBS));
mfxStatus CEncodingPipeline::GetFreeTask(sTask **ppTask)
    sts = m_TaskPool.GetFreeTask(ppTask);
    if (MFX_ERR_NOT_FOUND == sts)
        sts = m_TaskPool.SynchronizeFirstTask();
        // try again
    return sts;
int64_t timstmp = 1;
mfxStatus CEncodingPipeline::Run()
    mfxFrameSurface1* pSurf = NULL; // dispatching pointer
    sTask *pCurrentTask = NULL; // a pointer to the current task
    mfxU16 nEncSurfIdx = 0;     // index of free surface for encoder input (vpp output)
    mfxU16 nVppSurfIdx = 0;     // index of free surface for vpp input
    mfxSyncPoint VppSyncPoint = NULL; // a sync point associated with an asynchronous vpp call
    bool bVppMultipleOutput = false;  // this flag is true if VPP produces more frames at output
    // than consumes at input. E.g. framerate conversion 30 fps -> 60 fps
    // Since in sample we support just 2 views
    // we will change this value between 0 and 1 in case of MVC
    mfxU16 currViewNum = 0;
    mfxU32 nFramesProcessed = 0;
    sts = MFX_ERR_NONE;
        msdk_printf(MSDK_STRING("Press Ctrl+C to terminate this application\n"));
#endif
    // main loop, preprocessing and encoding
    while (MFX_ERR_NONE <= sts || MFX_ERR_MORE_DATA == sts)
        if ((m_nFramesToProcess != 0) && (nFramesProcessed == m_nFramesToProcess))
            break;
        if (v4l2Pipeline.GetV4L2TerminationSignal() && isV4L2InputEnabled)
            break;
#endif
        // get a pointer to a free task (bit stream and sync point for encoder)
        sts = GetFreeTask(&pCurrentTask);
        MSDK_BREAK_ON_ERROR(sts);
        // find free surface for encoder input
        nEncSurfIdx = GetFreeSurface(m_pEncSurfaces, m_EncResponse.NumFrameActual);
        MSDK_CHECK_ERROR(nEncSurfIdx, MSDK_INVALID_SURF_IDX, MFX_ERR_MEMORY_ALLOC);
        // point pSurf to encoder surface
        pSurf = &m_pEncSurfaces[nEncSurfIdx];
        if (!bVppMultipleOutput)
            // if vpp is enabled find free surface for vpp input and point pSurf to vpp surface
            if (m_pmfxVPP)
                    nVppSurfIdx = v4l2Pipeline.GetOffQ();
#else
                nVppSurfIdx = GetFreeSurface(m_pVppSurfaces, m_VppResponse.NumFrameActual);
                MSDK_CHECK_ERROR(nVppSurfIdx, MSDK_INVALID_SURF_IDX, MFX_ERR_MEMORY_ALLOC);
#endif
                pSurf = &m_pVppSurfaces[nVppSurfIdx];
            // load frame from file to surface data
            // if we share allocator with Media SDK we need to call Lock to access surface data and...
                // get YUV pointers
                sts = m_pMFXAllocator->Lock(m_pMFXAllocator->pthis, pSurf->Data.MemId, &(pSurf->Data));
            pSurf->Info.FrameId.ViewId = currViewNum;
                sts = m_FileReader.LoadNextFrame(pSurf);
pSurf->Data.TimeStamp =timstmp++ * 90000; // for test
printf("in: tm %d\n",pSurf->Data.TimeStamp);
            if (MVC_ENABLED & m_MVCflags) currViewNum ^= 1; // Flip between 0 and 1 for ViewId
            // ... after we're done call Unlock
                sts = m_pMFXAllocator->Unlock(m_pMFXAllocator->pthis, pSurf->Data.MemId, &(pSurf->Data));
        // perform preprocessing if required
        if (m_pmfxVPP)
            bVppMultipleOutput = false; // reset the flag before a call to VPP
            for (;;)
                sts = m_pmfxVPP->RunFrameVPPAsync(&m_pVppSurfaces[nVppSurfIdx], &m_pEncSurfaces[nEncSurfIdx],
                    NULL, &VppSyncPoint);
                if (MFX_ERR_NONE < sts && !VppSyncPoint) // repeat the call if warning and no output
                    if (MFX_WRN_DEVICE_BUSY == sts)
                        MSDK_SLEEP(1); // wait if device is busy
                else if (MFX_ERR_NONE < sts && VppSyncPoint)
                    sts = MFX_ERR_NONE; // ignore warnings if output is available
                    break;
                else
                    break; // not a warning
            // process errors
            if (MFX_ERR_MORE_DATA == sts)
                continue;
            else if (MFX_ERR_MORE_SURFACE == sts)
                bVppMultipleOutput = true;
            else
        // save the id of preceding vpp task which will produce input data for the encode task
        if (VppSyncPoint)
            pCurrentTask->DependentVppTasks.push_back(VppSyncPoint);
        for (;;)
            // at this point surface for encoder contains either a frame from file or a frame processed by vpp
            sts = m_pmfxENC->EncodeFrameAsync(NULL, &m_pEncSurfaces[nEncSurfIdx], &pCurrentTask->mfxBS, &pCurrentTask->EncSyncP);
            if (MFX_ERR_NONE < sts && !pCurrentTask->EncSyncP) // repeat the call if warning and no output
            else if (MFX_ERR_NONE < sts && pCurrentTask->EncSyncP)
                break;
            else if (MFX_ERR_NOT_ENOUGH_BUFFER == sts)
                sts = AllocateSufficientBuffer(&pCurrentTask->mfxBS);
            else
                // get next surface and new task for 2nd bitstream in ViewOutput mode
                MSDK_IGNORE_MFX_STS(sts, MFX_ERR_MORE_BITSTREAM);
                break;
        nFramesProcessed++;
    // means that the input file has ended, need to go to buffering loops
    MSDK_IGNORE_MFX_STS(sts, MFX_ERR_MORE_DATA);
    // exit in case of other errors
    if (m_pmfxVPP)
        // loop to get buffered frames from vpp
        while (MFX_ERR_NONE <= sts || MFX_ERR_MORE_DATA == sts || MFX_ERR_MORE_SURFACE == sts)
            // MFX_ERR_MORE_SURFACE can be returned only by RunFrameVPPAsync
            // MFX_ERR_MORE_DATA is accepted only from EncodeFrameAsync
            // find free surface for encoder input (vpp output)
            for (;;)
                sts = m_pmfxVPP->RunFrameVPPAsync(NULL, &m_pEncSurfaces[nEncSurfIdx], NULL, &VppSyncPoint);
                    break;
                else
                continue;
            else
            // get a free task (bit stream and sync point for encoder)
            if (VppSyncPoint)
            for (;;)
                    break;
                else
                    break;
        // MFX_ERR_MORE_DATA is the correct status to exit buffering loop with
        // indicates that there are no more buffered frames
    // loop to get buffered frames from encoder
    while (MFX_ERR_NONE <= sts)
        for (;;)
            sts = m_pmfxENC->EncodeFrameAsync(NULL, NULL, &pCurrentTask->mfxBS, &pCurrentTask->EncSyncP);
                break;
            else
                // get new task for 2nd bitstream in ViewOutput mode
                break;
    // synchronize all tasks that are left in task pool
    while (MFX_ERR_NONE == sts)
    // MFX_ERR_NOT_FOUND is the correct status to exit the loop with
    // EncodeFrameAsync and SyncOperation don't return this status
    MSDK_IGNORE_MFX_STS(sts, MFX_ERR_NOT_FOUND);
    // report any errors that occurred in asynchronous part
    return sts;
void CEncodingPipeline::PrintInfo()
    msdk_printf(MSDK_STRING("Encoding Sample Version %s\n"), MSDK_SAMPLE_VERSION);
    msdk_printf(MSDK_STRING("\nInput file format\t%s\n"), ColorFormatToStr(m_FileReader.m_ColorFormat));
    msdk_printf(MSDK_STRING("Output video\t\t%s\n"), CodecIdToStr(m_mfxEncParams.mfx.CodecId).c_str());
    mfxFrameInfo SrcPicInfo = m_mfxVppParams.vpp.In;
    mfxFrameInfo DstPicInfo = m_mfxEncParams.mfx.FrameInfo;
    msdk_printf(MSDK_STRING("Source picture:\n"));
    msdk_printf(MSDK_STRING("\tResolution\t%dx%d\n"), SrcPicInfo.Width, SrcPicInfo.Height);
    msdk_printf(MSDK_STRING("\tCrop X,Y,W,H\t%d,%d,%d,%d\n"), SrcPicInfo.CropX, SrcPicInfo.CropY, SrcPicInfo.CropW, SrcPicInfo.CropH);
    msdk_printf(MSDK_STRING("Destination picture:\n"));
    msdk_printf(MSDK_STRING("\tResolution\t%dx%d\n"), DstPicInfo.Width, DstPicInfo.Height);
    msdk_printf(MSDK_STRING("\tCrop X,Y,W,H\t%d,%d,%d,%d\n"), DstPicInfo.CropX, DstPicInfo.CropY, DstPicInfo.CropW, DstPicInfo.CropH);
    msdk_printf(MSDK_STRING("Frame rate\t%.2f\n"), DstPicInfo.FrameRateExtN * 1.0 / DstPicInfo.FrameRateExtD);
    if (m_mfxEncParams.mfx.RateControlMethod != MFX_RATECONTROL_CQP)
        msdk_printf(MSDK_STRING("Bit rate(Kbps)\t%d\n"), m_mfxEncParams.mfx.TargetKbps);
    else
        msdk_printf(MSDK_STRING("QPI\t%d\nQPP\t%d\nQPB\t%d\n"), m_mfxEncParams.mfx.QPI, m_mfxEncParams.mfx.QPP, m_mfxEncParams.mfx.QPB);
    msdk_printf(MSDK_STRING("Gop size\t%d\n"), m_mfxEncParams.mfx.GopPicSize);
    msdk_printf(MSDK_STRING("Ref dist\t%d\n"), m_mfxEncParams.mfx.GopRefDist);
    msdk_printf(MSDK_STRING("Ref number\t%d\n"), m_mfxEncParams.mfx.NumRefFrame);
    msdk_printf(MSDK_STRING("Idr Interval\t%d\n"), m_mfxEncParams.mfx.IdrInterval);
    msdk_printf(MSDK_STRING("Target usage\t%s\n"), TargetUsageToStr(m_mfxEncParams.mfx.TargetUsage));
    const msdk_char* sMemType =
#if defined(_WIN32) || defined(_WIN64)
        m_memType == D3D9_MEMORY  ? MSDK_STRING("d3d")
#else
        m_memType == D3D9_MEMORY  ? MSDK_STRING("vaapi")
#endif
        : (m_memType == D3D11_MEMORY ? MSDK_STRING("d3d11")
        : MSDK_STRING("system"));
    msdk_printf(MSDK_STRING("Memory type\t%s\n"), sMemType);
    mfxIMPL impl;
    GetFirstSession().QueryIMPL(&impl);
    const msdk_char* sImpl = (MFX_IMPL_VIA_D3D11 == MFX_IMPL_VIA_MASK(impl)) ? MSDK_STRING("hw_d3d11")
        : (MFX_IMPL_HARDWARE & impl)  ? MSDK_STRING("hw")
        : MSDK_STRING("sw");
    msdk_printf(MSDK_STRING("Media SDK impl\t\t%s\n"), sImpl);
    mfxVersion ver;
    GetFirstSession().QueryVersion(&ver);
    msdk_printf(MSDK_STRING("Media SDK version\t%d.%d\n"), ver.Major, ver.Minor);
    msdk_printf(MSDK_STRING("\n"));
what is wrong with me?
how can i solve it?
wang_y_1
console output content is:
libva info: VA-API version 0.99.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
Encoding Sample Version 0.0.000.0000
Input file format    YUV420
Output video        AVC
Source picture:
    Resolution    1920x1088
    Crop X,Y,W,H    0,0,1920,1080
Frame rate    30.00
Bit rate(Kbps)    3757
Gop size    0
Ref dist    0
Ref number    1
Idr Interval    0
Target usage    balanced
Memory type    system
Media SDK impl        hw
Media SDK version    1.19
Processing started
in: tm 90000
in: tm 180000
in: tm 270000
in: tm 360000
in: tm 450000
in: tm 540000
in: tm 630000
out pts: 90000      87000
in: tm 720000 1
out pts: 360000      351000
in: tm 810000
out pts: 180000      180000
in: tm 900000
out pts: 270000      270000
in: tm 990000
out pts: 630000      621000
in: tm 1080000
out pts: 450000      450000
in: tm 1170000
out pts: 540000      540000
in: tm 1260000
out pts: 900000      891000
in: tm 1350000
out pts: 720000      720000
in: tm 1440000
out pts: 810000      810000
in: tm 1530000
out pts: 1170000      1161000
in: tm 1620000
out pts: 990000      990000
in: tm 1710000
out pts: 1080000      1080000
in: tm 1800000
out pts: 1440000      1431000
in: tm 1890000
out pts: 1260000      1260000
in: tm 1980000
out pts: 1350000      1350000
in: tm 2070000
out pts: 1710000      1701000
in: tm 2160000
out pts: 1530000      1530000
in: tm 2250000
out pts: 1620000      1620000
in: tm 2340000
out pts: 1980000      1971000
in: tm 2430000
out pts: 1800000      1800000
in: tm 2520000
out pts: 1890000      1890000
in: tm 2610000
out pts: 2250000      2241000
in: tm 2700000
out pts: 2070000      2070000
in: tm 2790000
out pts: 2160000      2160000
in: tm 2880000
out pts: 2520000      2511000
in: tm 2970000
out pts: 2340000      2340000
in: tm 3060000
out pts: 2430000      2430000
in: tm 3150000
out pts: 2790000      2781000
in: tm 3240000
out pts: 2610000      2610000
in: tm 3330000
out pts: 2700000      2700000
in: tm 3420000
out pts: 3060000      3051000
in: tm 3510000
out pts: 2880000      2880000
in: tm 3600000
out pts: 2970000      2970000
in: tm 3690000
out pts: 3330000      3321000
in: tm 3780000
out pts: 3150000      3150000
in: tm 3870000
out pts: 3240000      3240000
in: tm 3960000
out pts: 3600000      3591000
in: tm 4050000
out pts: 3420000      3420000
in: tm 4140000
out pts: 3510000      3510000
in: tm 4230000
out pts: 3870000      3861000
in: tm 4320000
out pts: 3690000      3690000
in: tm 4410000
out pts: 3780000      3780000
in: tm 4500000
out pts: 4140000      4131000
in: tm 4590000
out pts: 3960000      3960000
in: tm 4680000
out pts: 4050000      4050000
in: tm 4770000
out pts: 4410000      4401000
in: tm 4860000
out pts: 4230000      4230000
in: tm 4950000
out pts: 4320000      4320000
in: tm 5040000
out pts: 4680000      4671000
in: tm 5130000
out pts: 4500000      4500000
in: tm 5220000
out pts: 4590000      4590000
in: tm 5310000
out pts: 4950000      4941000
in: tm 5400000
Mark_L_Intel1
Can you read the following post to see if it solved your question:
https://software.intel.com/en-us/forums/intel-media-sdk/topic/311726
Mark
wang_y_1
Mark
it's useless for me. my question is output's TimeStamp and DecodeTimeStamp are both non-monotonic
whatever encode order or display order, must hava one monotonic.
sorry for my English, its not my mother language.
Mark_L_Intel1
Yes, I think this should be fine as long as the output can be played in the correct order.
The Media SDK is an asynchronized framework, each frame will be running in parallel when processing, so they are not guarantee to finish in the order as they read from the file.
Mark
