Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3056 Discussions
oneVPL | A TargetBitrate value above 65536 causes an overflow
Max_Gud
Hello, I ran into a limitation of the 16-bit value for TargetBitrate in the oneVPL library, any values above 65536 cause an overflow.
Therefore, the question arises, is it possible to expand the value to 32 bits, or are there possible workarounds to set values higher than 65536?
Max_Gud
OK, I found a solution with installing mfx.BRCParamMultiplier
Max_Gud
ThasneemV_Intel
Glad to know that your issue is resolved.Thanks for sharing it with the community.If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thasneem Vazim
