oneVPL - Device Discovery (Windows Os)
Zanaboni__Gabriele
The oneVPL library describe some functions used in Device Discovery, of which I can't find compare for Windows, for instance:
- int GetDeviceCount(VplDeviceType dtype)
- VplDeviceProperty *GetDeviceProperty(VplDeviceType dtype, uint32_t id)
Please someone may help me understand how to achieve this in windows OS.
Mark_L_Intel1
Hi Gabriele,
Could you check the VPL spec 0.7 and see if it answers your question?
https://spec.oneapi.com/versions/latest/elements/oneVPL/source/index.html#device-discovery
But could you be more specific about your question? My understanding is, user uses this API to retrieve the device count from the current device, this API should be available on both Windows and Linux.
Mark
Zanaboni__Gabriele
Hi Liu,
Thank you for reply.
I have read the spec VPL 0.7 and they are fine. But I can't find this kind of class (DeviceInfo) defined in any namespace none in a class.
So, the question is, where could be found these functions (or class DeviceInfo)?
In attach the only file of library (C:\Program Files (x86)\inteloneapi\vpl\2021.1-beta06\include\vpl\vpl.hpp) that contain the 'namespace vpl' where I supposed to find the vpl::DeviceInfo (but is not there)
In addiction a would like to point out that even the simple_encode, program sample used as reference from Visual
Studio 2017 to show the base-use-case, doesn't use the DeviceInfo class (why?)
Gabriele
Luis_at_Intel
Hi @Zanaboni__Gabriele
I am not able to find these class references in the oneAPI spec for the API descriptions in latest spec https://spec.oneapi.com/versions/latest/elements/oneVPL/source/index.html
I wonder if the documentation included these classes by mistake, as you observed in Beta 07 such documentation references weren't found in sample code.
For the latest Beta 08 release, please check the landing page at: https://software.intel.com/content/www/us/en/develop/tools/oneapi/base-toolkit.html
The new source code is at: https://github.com/oneapi-src/oneVPL
Thank you again for your feedback.
Luis
