Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
qsv color conversion yuv to rgb32
jain__ankit
Hi , I am using intel ffmpeg plugins with qsv , i need to do color conversion on decoded frame to RGB32 to render it on weston surface . currently i am using swscale for it , but is there any to convert it using qsv or  mediasdk?
QS
You may use intel ipp, but it's assembly optimized, not gpu optimized.
Mark_L_Intel1
Hi Ankit,
There should be a qsv VPP filter argument in the ffmpeg command line. You could check and use it.
Mark
