Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
qsv+ffmpeg Segmentation fault
zhao_q_
i am using this edition
pwd
/home/htxk/Downloads/MediaServerStudioEssentials2017/SDK2017Production16.5/CentOS
./cat /proc/cpuinfo
processor       : 1
vendor_id       : GenuineIntel
cpu family      : 6
model           : 94
model name      : Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
stepping        : 3
microcode       : 0x8a
cpu MHz         : 800.000
cache size      : 6144 KB
physical id     : 0
siblings        : 4
core id         : 1
cpu cores       : 4
after installing:
uname -r
3.10.0-327.el7.x86_64
cat /etc/redhat-release
CentOS Linux release 7.2.1511 (Core)
ls /opt/intel/mediasdk/lib64/
iHD_drv_video.so      libmfxhw64.so         libmfxsw64.so
libmfxhw64-p.so.1.19  libmfxsw64-p.so.1.19
env |grep 'LIBVA'
LIBVA_DRIVERS_PATH=/opt/intel/mediasdk/lib64
LIBVA_DRIVER_NAME=iHD
vainfo
error: can't connect to X server!
libva info: VA-API version 0.99.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.99 (libva 1.67.0.pre1)
vainfo: Driver version: 16.5.55964-ubit
vainfo: Supported profile and entrypoints
      VAProfileH264ConstrainedBaseline: VAEntrypointVLD
      VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
      VAProfileH264ConstrainedBaseline: <unknown entrypoint>
      VAProfileH264Main               : VAEntrypointVLD
      VAProfileH264Main               : VAEntrypointEncSlice
      VAProfileH264Main               : <unknown entrypoint>
      VAProfileH264High               : VAEntrypointVLD
      VAProfileH264High               : VAEntrypointEncSlice
      VAProfileH264High               : <unknown entrypoint>
      VAProfileMPEG2Simple            : VAEntrypointEncSlice
      VAProfileMPEG2Simple            : VAEntrypointVLD
      VAProfileMPEG2Main              : VAEntrypointEncSlice
      VAProfileMPEG2Main              : VAEntrypointVLD
      VAProfileVC1Advanced            : VAEntrypointVLD
      VAProfileVC1Main                : VAEntrypointVLD
      VAProfileVC1Simple              : VAEntrypointVLD
      VAProfileJPEGBaseline           : VAEntrypointVLD
      VAProfileJPEGBaseline           : VAEntrypointEncPicture
      VAProfileVP8Version0_3          : VAEntrypointEncSlice
      VAProfileVP8Version0_3          : VAEntrypointVLD
      VAProfileVP8Version0_3          : <unknown entrypoint>
      VAProfileHEVCMain               : VAEntrypointVLD
      VAProfileHEVCMain               : VAEntrypointEncSlice
      VAProfileVP9Profile0            : <unknown entrypoint>
      <unknown profile>               : VAEntrypointVideoProc
      VAProfileNone                   : VAEntrypointVideoProc
      VAProfileNone                   : <unknown entrypoint>
lsmod |grep 'i915'
i915                 1321453  4
i2c_algo_bit           13413  1 i915
drm_ukmd_kms_helper   141060  1 i915
drm_ukmd              369649  3 i915,drm_ukmd_kms_helper
drm_ukmd_compat       109279  1 i915
video                  24400  1 i915
i2c_core               40582  7 drm,i915,i2c_i801,i2c_hid,i2c_algo_bit,drm_ukmd,drm_ukmd_kms_helper
ls -l /dev/dri/
total 0
crw-rw----+ 1 root video 226,   0 Jan 16 01:21 card0
crw-------. 1 root video 226,  64 Jan 16 01:21 controlD64
crw-rw----+ 1 root video 226, 128 Jan 16 01:21 renderD128
groups
htxk video
ffmpeg transcode test_out: Segmentation fault
ffmpeg -y -i testmp4.mp4 -vcodec h264_qsv -acodec copy -b:v 8000k out.mp4
ffmpeg version 2.8.8 Copyright (c) 2000-2016 the FFmpeg developers
  built with gcc 4.8.5 (GCC) 20150623 (Red Hat 4.8.5-4)
  configuration: --enable-nonfree --enable-ffmpeg --enable-libmfx
  libavutil      54. 31.100 / 54. 31.100
  libavcodec     56. 60.100 / 56. 60.100
  libavformat    56. 40.101 / 56. 40.101
  libavdevice    56.  4.100 / 56.  4.100
  libavfilter     5. 40.101 /  5. 40.101
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  2.101 /  1.  2.101
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'testmp4.mp4':
  Metadata:
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isom
    creation_time   : 2015-05-06 01:12:21
    encoder         : FormatFactory : www.pcfreetime.com
  Duration: 00:00:11.01, start: 0.000000, bitrate: 2364 kb/s
    Stream #0:0(und): Video: mpeg4 (Simple Profile) (mp4v / 0x7634706D), yuv420p, 968x544 [SAR 1:1 DAR 121:68], 2252 kb/s, 25 fps, 25 tbr, 25k tbn, 25 tbc (default)
    Metadata:
      handler_name    : video
    Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 125 kb/s (default)
    Metadata:
      handler_name    : sound
Segmentation fault (core dumped)
sample decode : ok
 ./sample_decode h264 -i streams/test_stream.264 -o out.yuv -w 16 -h 16 -hw
Decoding Sample Version 7.0.16053497
Input video     AVC
Output format   NV12 (using vpp)
Input:
  Resolution    176x96
  Crop X,Y,W,H  0,0,0,0
Output:
  Resolution    16x16
Frame rate      30.00
Memory type             system
MediaSDK impl           hw
MediaSDK version        1.19
Decoding started
Frame number:  101, fps: 1560.834, fread_fps: 0.000, fwrite_fps: 0.000
Decoding finished
What am i missing?
can anybody help me?
best regards.
su_g_
root@mos:~/mscore_src/extern/src/intel/MediaSamples_Linux_2017/samples/_bin/x64# /cat /proc/cpuinfo
processor    : 7
cpu family    : 6
model        : 94
model name    : Intel(R) Core(TM) i7-6770HQ CPU @ 2.60GHz
stepping    : 3
microcode    : 0x8a
cpu MHz        : 1082.656
physical id    : 0
siblings    : 8
core id        : 3
cpu cores    : 4
apicid        : 7
initial apicid    : 7
fpu        : yes
fpu_exception    : yes
cpuid level    : 22
wp        : yes
flags        : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch epb intel_pt tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx rdseed adx smap clflushopt xsaveopt xsavec xgetbv1 dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp
bugs        :
bogomips    : 5183.91
clflush size    : 64
cache_alignment    : 64
address sizes    : 39 bits physical, 48 bits virtual
power management:
root@mos:~/mscore_src/extern/src/intel/MediaSamples_Linux_2017/samples/_bin/x64# uname -a
Linux mos 4.4.0-59-generic #80-Ubuntu SMP Fri Jan 6 17:47:47 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
root@mos:~/mscore_src/extern/src/intel/MediaSamples_Linux_2017/samples/_bin/x64# ls /opt/intel/mediasdk/lib64/
iHD_drv_video.so  libmfxhw64-p.so.1.19  libmfxhw64.so  libmfxsw64-p.so.1.19  libmfxsw64.so
root@mos:~/mscore_src/extern/src/intel/MediaSamples_Linux_2017/samples/_bin/x64# env |grep 'LIBVA'
root@mos:~/mscore_src/extern/src/intel/MediaSamples_Linux_2017/samples/_bin/x64# vainfo
root@mos:~/mscore_src/extern/src/intel/MediaSamples_Linux_2017/samples/_bin/x64# lsmod |grep 'i915'
i915_bpo             1302528  4
intel_ips              20480  1 i915_bpo
i2c_algo_bit           16384  1 i915_bpo
drm_kms_helper        155648  1 i915_bpo
drm                   364544  5 i915_bpo,drm_kms_helper
video                  40960  1 i915_bpo
root@mos:~/mscore_src/extern/src/intel/MediaSamples_Linux_2017/samples/_bin/x64# ls -l /dev/dri/
总用量 0
crw-rw----+ 1 root video 226,   0 1月  18 18:18 card0
crw-rw----  1 root video 226,  64 1月  18 18:18 controlD64
crw-rw----+ 1 root video 226, 128 1月  18 18:18 renderD128
root@mos:~/mscore_src/extern/src/intel/MediaSamples_Linux_2017/samples/_bin/x64# groups
root video
root@mos:~/mscore_src/extern/src/intel/MediaSamples_Linux_2017/samples/_bin/x64# ./sample_multi_transcode -i::h264 ../content/test_stream.264 -o::h264 test_out.h264 -hw
Multi Transcoding Sample Version 7.0.16053497
Pipeline surfaces number (DecPool): 20
Return on error: error code -3,    /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_multi_transcode/src/pipeline_transcode.cpp    2924
Return on error: error code -3,    /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK4/git/mdp_msdk-samples/samples/sample_multi_transcode/src/sample_multi_transcode.cpp    307
root@mos:~/mscore_src/extern/src/ffmpeg# /usr/local/bin/ffmpeg -hwaccel qsv -c:v h264_qsv -vsync 0 -i udp://224.2.2.2:9000 -look_ahead 0 -pix_fmt nv12 -c:v h264_qsv -c:a copy  -b:v 2M -preset veryfast -f mpegts udp://127.0.0.1:10000
Input #0, mpegts, from 'udp://224.2.2.2:9000':
  Duration: N/A, start: 60850.147611, bitrate: N/A
  Program 1
    Stream #0:0[0x1010]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 720x576 [SAR 16:11 DAR 20:11], 25 fps, 50 tbr, 90k tbn, 50 tbc
    Stream #0:1[0x1011]: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 127 kb/s
root@mos:/opt/intel/mediasdk/tools/metrics_monitor/sample# ls
build.sh  cttmetrics_sample.cpp  metrics_monitor  run.sh
root@mos:/opt/intel/mediasdk/tools/metrics_monitor/sample# ./run.sh
ERROR: Failed to initialize metrics monitor, error code -10
I meet the same problem,can anyone help ?
zhao_q_
processor    : 7
cpu family    : 6
model        : 94
stepping    : 3
microcode    : 0x8a
cpu MHz        : 1082.656
physical id    : 0
siblings    : 8
core id        : 3
cpu cores    : 4
apicid        : 7
initial apicid    : 7
fpu        : yes
fpu_exception    : yes
cpuid level    : 22
wp        : yes
bugs        :
bogomips    : 5183.91
clflush size    : 64
power management:
i915_bpo             1302528  4
总用量 0
root video
  Program 1
it seems i successfully installed . maybe, the ./sample_multi_transcode instruction showing
indicates the successful installing. maybe you enter wrong parameters.
now , i can normally use the ffmpeg instruction using h264_qsv codec.
you should write libmfx.pc like this other than amend the config.mak:
prefix=/opt/intel/mediasdk
exec_prefix=${prefix}
libdir=${exec_prefix}/lib/lin_x64
includedir=${exec_prefix}/include
Description: Intel Media SDK dispatcher.
Version: 2015r6
Libs: -L${libdir} -lmfx -lva -lstdc++ -ldl -lva-drm -ldrm
Cflags: -I${includedir} -I/usr/include/libdrm
if any processing, please let me know.
su_g_
zhao qi wrote:
Quote:
processor    : 7
cpu family    : 6
model        : 94
stepping    : 3
microcode    : 0x8a
cpu MHz        : 1082.656
physical id    : 0
siblings    : 8
core id        : 3
cpu cores    : 4
apicid        : 7
initial apicid    : 7
fpu        : yes
fpu_exception    : yes
cpuid level    : 22
wp        : yes
bugs        :
bogomips    : 5183.91
clflush size    : 64
power management:
i915_bpo             1302528  4
总用量 0
root video
  Program 1
Version: 2015r6
I already add the libmfx.pc at the path,and it is vaild;
I cannot run ./metrics_monitor also
And I change the os to ubuntu 14.04, the wrong isnot  avoided?
I donot know  how to do?
zhao_q_
the output
indicates you have successfully installed. try this command as root, it works on my computer
cpu family      : 6
model           : 94
 ffmpeg -y -i VID_20161224_172717.mp4 -vcodec h264_qsv -acodec copy -s 856x480 out10.flv
 ./sample_decode h264 -i ../content/test_stream.264 -hw -h 16 -h 16 -o out.yuv
Input video     AVC
Output format   NV12
Input:
  Resolution    176x96
Output:
  Resolution    176x96
Frame rate      30.00
Memory type             system
MediaSDK impl           hw
Decoding started
Frame number:  101, fps: 975.902, fread_fps: 0.000, fwrite_fps: 0.00009
Decoding finished
su_g_
I have check all the install step !
Is the cpu support qsv?( Intel(R) Core(TM) i7-6770HQ CPU @ 2.60GHz)
The sample  cannot run on my pc,I will change my os to CentOS Linux release 7.2.1511
My wechat is :Prodigals
zhao_q_
MediaServerStudioEssentials2016 dont support intel 6th family cpu as mentioned in the tutorial paper . Changing os is a advisable solution. the compatibility brings strange problem.
su_g_
I use MediaServerStudioEssentials2017,It support support intel 6th family cpu!!
I have contact the intel sales,they tell me it  need path to support ffmpeg qsv!!! Hope can resolve my problem!
su_g_
need patch
su_g_
I am successed at centos 7.2,I will test the ffmpeg+qvs later!
su_g_
I test with the command:
ffmpeg -hwaccel qsv -c:v h264_qsv -i http://192.168.1.64:8010/ch3.ts ; -pix_fmt nv12 -c:v h264_qsv -c:a copy -b:v 2M  -f mpegts udp://127.0.0.1:10000
result:decode error
ffmpeg -hwaccel  -i http://192.168.1.64:8010/ch3.ts ; -pix_fmt nv12 -c:v h264_qsv -c:a copy -b:v 2M  -f mpegts udp://127.0.0.1:10000
result:It is success,but video and audio not sync,and the cpu uarg 30% with:
RENDER usage: 2.00,    VIDEO usage: 0.00,    VIDEO_E usage: 0.00    VIDEO2 usage: 0.00    GT Freq: 350.00
Input #0, mpegts, from 'http://192.168.1.64:8010/ch3.ts':
  Duration: N/A, start: 56643.097678, bitrate: N/A
  Program 1
    Stream #0:0[0x1030]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 720x576 [SAR 16:11 DAR 20:11], 25 fps, 50 tbr, 90k tbn, 50 tbc
    Stream #0:1[0x1031]: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 127 kb/s
[h264_qsv @ 0x263c8e0] Encoder will work with partial HW acceleration
Output #0, mpegts, to 'udp://127.0.0.1:10000':
  Metadata:
    encoder         : Lavf57.58.101
    Stream #0:0: Video: h264 (h264_qsv), nv12, 720x576 [SAR 16:11 DAR 20:11], q=2-31, 2000 kb/s, 25 fps, 90k tbn, 25 tbc
    Metadata:
      encoder         : Lavc57.66.108 h264_qsv
    Side data:
      cpb: bitrate max/min/avg: 0/0/2000000 buffer size: 0 vbv_delay: -1
    Stream #0:1: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 127 kb/s
Stream mapping:
  Stream #0:0 -> #0:0 (h264 (native) -> h264 (h264_qsv))
  Stream #0:1 -> #0:1 (copy)
