question about simple_decode
MyMother
hi Intel-giant,
OS: Ubuntu 12.04
       MediaSamples_Linux_6.0.16043175.175
       MediaServerStudioEssentials2015R6
Platform:  i5-4570S
     I got the same messages as below in the local machine. Please help to clarify. Thanks
     I have referred to  https://software.intel.com/en-us/forums/intel-media-sdk/topic/543365.
[release] $ ./sample_decode_x11 h264 -i 1920x1088.264         ==> this is ok
libva info: VA-API version 0.35.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
Decoding Sample Version 0.0.000.0000
Input video     AVC
Output format   YUV420
Resolution      1920x1088
Crop X,Y,W,H    0,0,0,0
Frame rate      30.00
Memory type             system
MediaSDK impl           hw
MediaSDK version        1.16
Decoding started
Frame number: 8117, fps: 701.897, fread_fps: 0.000, fwrite_fps: 0.000
Decoding finished
[release] $ pwd
/opt/intel/mediasdk/samples/__cmake/intel64.make.release/__bin/release
[_build] $ ./simple_session -hw                                  ==> this is not ok
libva info: va_getDriverName() returns 1
libva error: va_getDriverName() failed with operation failed,driver_name=i965
terminate called after throwing an instance of 'std::bad_alloc'
  what():  std::bad_alloc
Aborted (core dumped)
[_build] $ ./simple_decode -hw                                   ==> this is not ok
error: source file name not set (mandatory)
[_build] $ ./simple_decode -hw 1920x1088.264         ==> this is not ok
[_build] $ pwd
/home/dspuser/Downloads/mediasdk-tutorials-0.0.3/_build
MyMother
after trying with adding sudo to execute, it seems OK,
[_build] $ whoami
dspuser
[_build] $ sudo ./simple_session -hw
[sudo] password for dspuser:
Implementation: HARDWARE                 API Version: 1.16
Jeffrey_M_Intel1
Is your non-root user a member of the video group?  That could explain why sudo/root makes a difference.
Also, for Generic installs (as for Ubuntu) you must set two environment variables:
LIBVA_DRIVERS_PATH=/opt/intel/mediasdk/lib64
LIBVA_DRIVER_NAME=iHD
MyMother
hi Jeffrey Mcallister super-man
   Thanks for your response ~
Q1. Is your non-root user a member of the video group?  That could explain why sudo/root makes a difference.
> from the following, I know I got the same right as video ~
[_build] $ whoami
dspuser
[_build] $ groups
dspuser adm cdrom sudo dip video plugdev lpadmin sambashare
Q2. Also, for Generic installs (as for Ubuntu) you must set two environment variables:
[_build] $ ./simple_session -hw                 ==> it's not ok
[_build] $ cat /etc/environment              ==> make sure recommended variable were filled in this file
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games"
http_proxy="http://10.100.1.20:8080/"
LD_LIBRARY_PATH="/usr/local/lib;/usr/lib64"
[_build] $ source /etc/environment       ==> make the variable effective
[_build] $ export | grep LIBVA              ==> verify if these variables were effective
declare -x LIBVA_DRIVERS_PATH="/opt/intel/mediasdk/lib64"
declare -x LIBVA_DRIVER_NAME="iHD"
[_build] $ ./simple_session -hw            ==> still fail ~  I have no idea ??
