Media (Intel® oneAPI Video Processing Library, Intel Media SDK)
Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
question on simple_encode
MyMother
hello Intel-friends,
OS: Ubuntu 12.04
       mediasdk-tutorials-0.0.3
       MediaServerStudioEssentials2015R6
Platform:  i5-4570S
     As I trace the code of Simple_encode.cpp, I found something below and have question about reason of restriction of 2048. Do you know why?? Hardware design or else?? I have checked https://software.intel.com/sites/default/files/mediasdk-man.pdf but found no answer.
    w /= 2;
    h /= 2;
    ptr = pData->UV + pInfo->CropX + (pInfo->CropY / 2) * pitch;
    if (w > 2048)        ==> what the restriction means ??
        return MFX_ERR_UNSUPPORTED;
Sravanthi_K_Intel
If you see our Release Notes, the maximum supported resolution for AVC encoder is 4096x2304. https://software.intel.com/sites/default/files/managed/de/2e/media_server_studio_sdk_release_notes_linux.pdf
w /= 2 is 2048, hence the check.
MyMother
hi Sravanthi ,
   many thanks for your response. More question are
Q1.  the maximum supported resolution is due to hardware of software?? if software, then what's max for hardware??
H.264 decoder Supported Profiles:  Baseline  Main  High Maximum supported resolution: 4096x2304
Q2. By your speaking, there should be more limitation like the following, right ??
 if (h > 1157)
Sravanthi_K_Intel
Hi Medwin - good question. It is our SW limitation (in the sense, validation wise). Our HW limitation is 4Kx4K - so you can feed up to 4Kx4K streams as well.
You can remove the tutorial limitation for width and height - so long as you keep within 4Kx4K, you shoud be alright.
MyMother
hi Sravanthi ,
   many thanks for your response. more question are
Q1. the mentioned limitation is also for decoder ??
Q2. what're the meaning of the following, because I can't find any info in https://software.intel.com/sites/default/files/managed/de/2e/media_server_studio_sdk_release_notes_l...
/* TargetUsages: from 1 to 7 inclusive */
enum {
    MFX_TARGETUSAGE_1    =1,      what's this??
    MFX_TARGETUSAGE_2    =2,      ...
    MFX_TARGETUSAGE_3    =3,      ...
    MFX_TARGETUSAGE_4    =4,      ...
    MFX_TARGETUSAGE_5    =5,
    MFX_TARGETUSAGE_6    =6,
    MFX_TARGETUSAGE_7    =7,
Sravanthi_K_Intel
Yes, both decoder and encoder.
Reg Q2, what are you referring to? Can you please clarify?
Reg TU modes, MSDK supports 7 target usage modes 1 through 7, with 1 being best quality and 7 being best speed (4 is balanced).So, the application developer can specify the target usage mode for his application.
If this was not what you asked, please clarify. Thanks.
MyMother
hi Sravanthi,
   Many thanks for your reply. I have several questions as below
Q1. Is this API  EncodeFrameAsync() thread-safe??
Q2. Is it normal to open multi session for encode ??
Sravanthi_K_Intel
Yes, they are thread-safe if they are executing in their own session.
Here is how MSDK implementation works: Each session is similar to a process, and each session basically spawns multiple threads (thread/task pool) internally and schedules the work on it. The scheduler then manages each of these threads for the session in iterms of memory and synchronization. Now, the application only has control on creating sessions, everything after that is managed internally by MSDK.
If you create multiple sessions in an application, and do not "join" them, then each session has its own resources. If you join the sessions, then MSDK creates a parent and multiple child sessions, all sharing the thread pool and scheduler managing it internally.
All this is not visible to application layer, it is internal implementation. At application level, each session will behave like a process.
Now, when you ask if it is thread safe, what thread are you talking about? If the answer above is not what you're looking for, give me some more context and may be an example.
Req (2), yes, multiple sessions within an encode is a very common scenario. Esp when you want to encode multiple streams in parallel (N:N use-case), or have one feed to other (1:N). See the readme file in "sample_multi_transcode" folder for more details on 1:N, N:N, multiple session etc.
Sravanthi_K_Intel
Hi there - your questions are not related to your original form question on "question on simple_encode" anymore. Please do not add any more questions unrelated to simple_encode here. Start a new thread - it is easier for us to log and respond that way.
