hi Intel,
OS: Ubuntu 12.04
mediasdk-tutorials-0.0.3
MediaServerStudioEssentials2015R6
Platform: i5-4570S
Q1. I found following and the question is below
// Decode a frame asychronously (returns immediately)
sts = mfxDEC.DecodeFrameAsync(&mfxBS, pSurfaces[nIndex], &pmfxOutSurface, &syncpD);
... ==> why session.SyncOperation(syncpD, 60000) is unnecessary ???
// Encode a frame asychronously (returns immediately)
sts = mfxENC.EncodeFrameAsync(NULL, pmfxOutSurface, &mfxEncBS, &syncpE);
sts = session.SyncOperation(syncpE, 60000); // Synchronize. Wait until frame processing is ready
Hi Medwin,
Are you refer simple_5_transcode in mediasdk-tutorials-0.0.3 for your code ?
You can found following in simple_5_transcode\src\simple_transcode.cpp.
// Ignore warnings if output is available,
// if no output and no action required just repeat the DecodeFrameAsync call
if (MFX_ERR_NONE < sts && syncpD)
sts = MFX_ERR_NONE;
The comments maybe answered your questions.
Zachary
hi Zachary,
When I check simple_2_decode/simple_2_decode_vmem, there're always something below
sts = mfxDEC.DecodeFrameAsync(&mfxBS, pmfxSurfaces[nIndex], &pmfxOutSurface, &syncp);
if (MFX_ERR_NONE < sts && syncp)
sts = MFX_ERR_NONE;
if (MFX_ERR_NONE == sts)
sts = session.SyncOperation(syncp, 60000); // Synchronize. Wait until decoded frame is ready
> How transcoding make sure there're frames ready for encode without above line ??
Hi Medwin,
I have checked the simple_2_decode/simple_2_decode_vmem.
session.SyncOperation is used in page 13 in mediasdk-man.pdf, I think both of them are correct. you can use both them as you wish, I think session.SyncOperation is more better, because session.SyncOperation is used in mediasdk-man.pdf
About this question, I suggest you do some debug to watch "syncp" and "sts", to check when "syncp" is set and the values of "sts" can refer to mfxdefs.h
Zachary
