Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
return error information -3 or -4 or -17
hui1234
Hi
I have a question,
I used InitRunDecodeClose function at for loop,about decode 500 frame and then
close decode function,restart init decoderun decodeclose deocde.
After running several times will return error information -3 or -4 or -17
Please tell me this may be what causes the error?
System Environment
OS : windows 7 64bit
CPU : I7 2600K
RAM : 8G
Intel Media SDK 2.0 HW 32bit
Anthony_P_Intel
I'm not sure if it would be related to your issue, but I noticed you are using 32bit version of Intel Media SDK 2.0.
There is currently an issue seen with 32-bit applications are used.
We are working on root causing this issue as explained in earlier post. In the meantime, are you able to try using the 64-bit version of the SDK? If this works, it might indicate that you are seeing the same issue.
Please watch these forums for updates.
-Tony
