Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
rotation fail
MyMother
hi there,
OS: Ubuntu 12.04
       MediaSamples_Linux_6.0.16043175.175
       MediaServerStudioEssentials2015R6
Platform:  i5-4570S
I got strange problem below when trying some commands
[release] $ time ./sample_encode_x11 h264 -i 1080p.yuv -o 1080p_enc.264 -w 1920 -h 1080
libva info: VA-API version 0.35.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
Encoding Sample Version 0.0.000.0000
Input file format       YUV420
Output video            AVC
Source picture:
        Resolution      1920x1088
        Crop X,Y,W,H    0,0,1920,1080
Destination picture:
Frame rate      30.00
Bit rate(Kbps)  3757
Target usage    balanced
Memory type     system
Media SDK impl          hw
Media SDK version       1.16
Processing started
Frame number: 635
Processing finished
real    0m4.188s
user    0m0.740s
sys     0m0.500s
[release] $ time ./sample_encode_x11 h264 -i 1080p.yuv -o 1080p_enc.264 -w 1920 -h 1080 -angle 180
Return on error: error code 1,  /home/dspuser/Downloads/IntellMediaSDK/MediaSamples_Linux_6.0.16043175.175/samples/sample_encode/src/sample_encode.cpp  656
real    0m0.002s
user    0m0.000s
sys     0m0.002s
[release] $
After checking the Mfxdefs.h, I got the following. But is it just a warning??
    /* warnings >0 */
    MFX_WRN_IN_EXECUTION                = 1,    /* the previous asynchronous operation is in execution */
One more thing I felt weird is
    sts = pPipeline->Init(&Params);
    MSDK_CHECK_RESULT(sts, MFX_ERR_NONE, 1);     ==> this line number is 656 in sample_encode.cpp
I try to find the key word but nothing found...
    [samples] $ grep -rniI "MFX_WRN_IN_EXECUTION" ./sample_encode/
    [samples] $
Then I looked into the code as below in pipeline_encode.cpp and found nothing error before return value.
mfxStatus CEncodingPipeline::Init(sInputParams *pParams)
    if ((pParams->MVC_flags & MVC_ENABLED) != 0 && !CheckVersion(&version, MSDK_FEATURE_MVC)) {
        msdk_printf(MSDK_STRING("error: MVC is not supported in the %d.%d API version\n"),
            version.Major, version.Minor);
        return MFX_ERR_UNSUPPORTED;
    if ((pParams->MVC_flags & MVC_VIEWOUTPUT) != 0 && !CheckVersion(&version, MSDK_FEATURE_MVC_VIEWOUTPUT)) {
        msdk_printf(MSDK_STRING("error: MVC Viewoutput is not supported in the %d.%d API version\n"),
    if ((pParams->CodecId == MFX_CODEC_JPEG) && !CheckVersion(&version, MSDK_FEATURE_JPEG_ENCODE)) {
        msdk_printf(MSDK_STRING("error: Jpeg is not supported in the %d.%d API version\n"),
    if ((pParams->nRateControlMethod == MFX_RATECONTROL_LA) && !CheckVersion(&version, MSDK_FEATURE_LOOK_AHEAD)) {
        msdk_printf(MSDK_STRING("error: Look ahead is not supported in the %d.%d API version\n"),
    sts = ResetMFXComponents(pParams);
    MSDK_CHECK_RESULT(sts, MFX_ERR_NONE, sts);
    return MFX_ERR_NONE;
So what's going on with this phenomenon ?? Any idea??
Jiandong_Z_Intel
Hi Medwin,
we can found libsample_plugin_opencl.so can't be loaded by ./sample_encode_x11
open("/**/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
please add the path of folder <libsample_plugin_opencl.so> to environment variable LD_LIBRARY_PATH
You can refer following command line to export LD_LIBRARY_PATH or other method you like.
$ export LD_LIBRARY_PATH=/opt/intel/mediasdk/lib64:/opt/intel/common/mdf/lib64:/opt/intel/opencl:<SAMPLE_BIN path>:$LD_LIBRARY_PATH
Zachary
Jiandong_Z_Intel
Hi Medwin,
Please use add "-opencl" to your command line for test rotation.
./sample_encode_x11 h264 -i 1080p.yuv -o 1080p_enc.264 -w 1920 -h 1080 -angle 180 -opencl
Zachary
MyMother
hi Zachary,
    I got the same messages after adding the recommended option. Any further idea ??  Thanks in advance.
[release] $ time ./sample_encode_x11 h264 -i 1080p.yuv -o 1080p_enc.264 -w 1920 -h 1080 -angle 180 -opencl
real    0m0.002s
user    0m0.000s
sys     0m0.002s
[release] $
Jiandong_Z_Intel
Hi Medwin,
Have you upgraded your kernel  to 3.14.5 ?
Can you send the output of following command lines for check your environment ?
$ uname -r
$ ls -l /dev/dri
$ lspci -nn | grep -i vga
$ gcc -v
$ ldd /opt/intel/opencl/*.so | grep found
Zachary
MyMother
hi Zachary,
     see below for requirement. Is there anything wrong?
[samples] $ uname -r
3.14.5
[samples] $ ls -l /dev/dri/
total 0
crw-rw----+ 1 root video 226,   0 Dec 17 02:24 card0
crw-rw----  1 root video 226,  64 Nov 13 02:07 controlD64
crw-rw----  1 root video 226, 128 Nov 13 02:07 renderD128
[samples] $ lspci -nn | grep -i vga
00:02.0 VGA compatible controller [0300]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller [8086:0412] (rev 06)
[samples] $ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.7/lto-wrapper
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.7.3-2ubuntu1~12.04' --with-bugurl=file:///usr/share/doc/gcc-4.7/README.Bugs --enable-languages=c,c++,go,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.7 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.7 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin --with-system-zlib --enable-objc-gc --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-2ubuntu1~12.04)
[samples] $ ldd /opt/intel/opencl/*.so | grep found
        libnuma.so.1 => not found
[samples] $
Thanks.  QQa
Jiandong_Z_Intel
Hi Medwin,
It looks like "libnuma.so.1 => not found" in your system.
http://packages.ubuntu.com/precise/libnuma-dev
Can you check "libnuma.so.1", and try to fix this ?
Maybe "find /usr | grep libnuma" can help to check "libnuma.so.1".
Maybe "sudo apt-get install libnuma-dev libnuma1" can work for you.
Zahcary
MyMother
hi Zahcary,
==> after the following, I still got the same result....
[SDK2015Production16.4.2.1] $ sudo apt-get install libnuma-dev
[sudo] password for dspuser:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following extra packages will be installed:
  libnuma1
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 444 not upgraded.
Need to get 59.9 kB of archives.
After this operation, 241 kB of additional disk space will be used.
Do you want to continue [Y/n]? Y
Get:1 http://us.archive.ubuntu.com/ubuntu/ precise/main libnuma1 amd64 2.0.8~rc3-1 [23.1 kB]
Get:2 http://us.archive.ubuntu.com/ubuntu/ precise/main libnuma-dev amd64 2.0.8~rc3-1 [36.9 kB]
Fetched 59.9 kB in 1s (33.9 kB/s)
Selecting previously unselected package libnuma1.
(Reading database ... 161211 files and directories currently installed.)
Unpacking libnuma1 (from .../libnuma1_2.0.8~rc3-1_amd64.deb) ...
Selecting previously unselected package libnuma-dev.
Unpacking libnuma-dev (from .../libnuma-dev_2.0.8~rc3-1_amd64.deb) ...
Processing triggers for man-db ...
Setting up libnuma1 (2.0.8~rc3-1) ...
Setting up libnuma-dev (2.0.8~rc3-1) ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
[release] $ sudo apt-get install libnuma1
libnuma1 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 444 not upgraded
real    0m0.002s
user    0m0.000s
sys     0m0.002s
[release] $ sudo apt-get install numactl
  numactl
0 upgraded, 1 newly installed, 0 to remove and 444 not upgraded.
Need to get 23.3 kB of archives.
After this operation, 106 kB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu/ precise/universe numactl amd64 2.0.8~rc3-1 [23.3 kB]
Fetched 23.3 kB in 10s (2,180 B/s)
Selecting previously unselected package numactl.
(Reading database ... 161261 files and directories currently installed.)
Unpacking numactl (from .../numactl_2.0.8~rc3-1_amd64.deb) ...
Setting up numactl (2.0.8~rc3-1) ...
real    0m0.002s
user    0m0.000s
sys     0m0.002s
==> I try to confirm ldd /opt/intel/opencl/*.so | grep found again and got
[release] $ ldd /opt/intel/opencl/*.so | grep found
[release] $                                                         ==> it looks every link is fine.
Any further idea??
Jiandong_Z_Intel
Hi Medwin,
First you should use the parameter "-open -vaapi",
another, "libsample_plugin_opencl.so" and "ocl_rotate.cl" should be exist the same fold with  ./sample_encode_x11, please have a check.
Did your machine install other Intel Media Server Studio versions or OpenCL versions before ?
Can you send output of following command lines ?
$ cat /etc/OpenCL/vendors/intel.icd
$ strace ./sample_encode_x11 h264 -i 1080p.yuv -o 1080p_enc.264 -w 1920 -h 1080 -angle 180 -opencl -hw -vaapi
Zachary
MyMother
hi Zachary,
Q1. First you should use the parameter "-open -vaapi", another, "libsample_plugin_opencl.so" and "ocl_rotate.cl" should be exist the same fold with ./sample_encode_x11, please have a check.
[release] $ ls -l
-rw-rw-r-- 1 dspuser dspuser  1975104000 Dec 16 13:41 1080p.yuv
-rwxrwxr-x 1 dspuser dspuser      157920 Dec 29 01:53 libsample_plugin_opencl.so
-rwxrwxr-x 1 dspuser dspuser      108720 Dec 29 01:53 libsample_rotate_plugin.so
-rwxr-xr-x 1 dspuser dspuser       22392 Dec 29 01:53 libsample_spl_mux.so
-rwxrwxr-x 1 dspuser dspuser        2538 Dec 29 01:53 ocl_rotate.cl
-rwxrwxr-x 1 dspuser dspuser      366511 Dec 28 04:18 sample_decode_drm
-rwxrwxr-x 1 dspuser dspuser      366256 Dec 28 04:18 sample_decode_x11
-rwxrwxr-x 1 dspuser dspuser      368314 Dec 16 14:40 sample_decvpp_drm
-rwxrwxr-x 1 dspuser dspuser      363963 Dec 16 14:40 sample_decvpp_x11
-rwxrwxr-x 1 dspuser dspuser      388230 Dec 24 22:49 sample_encode_drm
-rwxrwxr-x 1 dspuser dspuser      384044 Dec 24 22:49 sample_encode_x11
-rwxrwxr-x 1 dspuser dspuser      475448 Dec 16 14:40 sample_multi_transcode_drm
-rwxrwxr-x 1 dspuser dspuser      471097 Dec 16 14:40 sample_multi_transcode_x11
-rwxrwxr-x 1 dspuser dspuser      325665 Dec 16 14:40 sample_vpp_drm
-rwxrwxr-x 1 dspuser dspuser      325352 Dec 16 14:40 sample_vpp_x11
[release] $ cat /etc/OpenCL/vendors/intel.icd
/opt/intel/opencl/libIntelOpenCL.so
Q2. Did your machine install other Intel Media Server Studio versions or OpenCL versions before ?
>> No...
Q3. $ cat /etc/OpenCL/vendors/intel.icd
Q4. strace ./sample_encode_x11 h264 -i 1080p.yuv -o 1080p_enc.264 -w 1920 -h 1080 -angle 180 -opencl -hw -vaapi
[release] $ strace ./sample_encode_x11 h264 -i 1080p.yuv -o 1080p_enc.264 -w 1920 -h 1080 -angle 180 -opencl -hw -vaapi
execve("./sample_encode_x11", ["./sample_encode_x11", "h264", "-i", "1080p.yuv", "-o", "1080p_enc.264", "-w", "1920", "-h", "1080", "-angle", "180", "-openc l", "-hw", "-vaapi"], [/* 25 vars */]) = 0
brk(0)                                  = 0x7f8fba002000
access("/etc/ld.so.nohwcap", F_OK)      = -1 ENOENT (No such file or directory)
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f8fb84f5000
access("/etc/ld.so.preload", R_OK)      = -1 ENOENT (No such file or directory)
open("/usr/local/lib/tls/x86_64/libva-x11.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/tls/x86_64", 0x7fffab48ef90) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/tls/libva-x11.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/tls", 0x7fffab48ef90) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/x86_64/libva-x11.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/local/lib/x86_64", 0x7fffab48ef90) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libva-x11.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\300\36\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=252610, ...}) = 0
mmap(NULL, 2126872, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb80cd000
mprotect(0x7f8fb80d4000, 2093056, PROT_NONE) = 0
mmap(0x7f8fb82d3000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f8fb82d3000
close(3)                                = 0
open("/usr/local/lib/libX11.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib64/tls/x86_64/libX11.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib64/tls/x86_64", 0x7fffab48ef60) = -1 ENOENT (No such file or directory)
open("/usr/lib64/tls/libX11.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib64/tls", 0x7fffab48ef60)  = -1 ENOENT (No such file or directory)
open("/usr/lib64/x86_64/libX11.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib64/x86_64", 0x7fffab48ef60) = -1 ENOENT (No such file or directory)
open("/usr/lib64/libX11.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib64", 0x7fffab48ef60)      = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=111484, ...}) = 0
mmap(NULL, 111484, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f8fb84d9000
close(3)                                = 0
open("/usr/lib/x86_64-linux-gnu/libX11.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0p\212\1\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1265056, ...}) = 0
mmap(NULL, 3362032, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb7d98000
mprotect(0x7f8fb7ec8000, 2097152, PROT_NONE) = 0
mmap(0x7f8fb80c8000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x130000) = 0x7f8fb80c8000
close(3)                                = 0
open("/usr/local/lib/libva.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`/\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=321215, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f8fb84d8000
mmap(NULL, 2190208, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb7b81000
mprotect(0x7f8fb7b96000, 2093056, PROT_NONE) = 0
mmap(0x7f8fb7d95000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x7f8fb7d95000
mmap(0x7f8fb7d97000, 2944, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f8fb7d97000
close(3)                                = 0
open("/usr/local/lib/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340\r\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=14768, ...}) = 0
mmap(NULL, 2109704, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb797d000
mprotect(0x7f8fb797f000, 2097152, PROT_NONE) = 0
mmap(0x7f8fb7b7f000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f8fb7b7f000
close(3)                                = 0
open("/usr/local/lib/libpthread.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200l\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=135366, ...}) = 0
mmap(NULL, 2212904, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb7760000
mprotect(0x7f8fb7778000, 2093056, PROT_NONE) = 0
mmap(0x7f8fb7977000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17000) = 0x7f8fb7977000
mmap(0x7f8fb7979000, 13352, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f8fb7979000
close(3)                                = 0
open("/usr/local/lib/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0PE\6\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1094136, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f8fb84d7000
mmap(NULL, 3202240, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb7452000
mprotect(0x7f8fb7554000, 2093056, PROT_NONE) = 0
mmap(0x7f8fb7753000, 40960, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x101000) = 0x7f8fb7753000
mmap(0x7f8fb775d000, 11456, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f8fb775d000
close(3)                                = 0
open("/usr/local/lib/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260*\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=92472, ...}) = 0
mmap(NULL, 2188320, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb723b000
mprotect(0x7f8fb7251000, 2093056, PROT_NONE) = 0
mmap(0x7f8fb7450000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x15000) = 0x7f8fb7450000
close(3)                                = 0
open("/usr/local/lib/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\30\2\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1815224, ...}) = 0
mmap(NULL, 3929304, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb6e7b000
mprotect(0x7f8fb7030000, 2097152, PROT_NONE) = 0
mmap(0x7f8fb7230000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1b5000) = 0x7f8fb7230000
mmap(0x7f8fb7236000, 17624, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f8fb7236000
close(3)                                = 0
open("/usr/local/lib/libXext.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libXext.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\2204\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=69504, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f8fb84d6000
mmap(NULL, 2165304, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb6c6a000
mprotect(0x7f8fb6c7a000, 2093056, PROT_NONE) = 0
mmap(0x7f8fb6e79000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf000) = 0x7f8fb6e79000
close(3)                                = 0
open("/usr/local/lib/libXfixes.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libXfixes.so.3", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\240\24\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=22536, ...}) = 0
mmap(NULL, 2117864, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb6a64000
mprotect(0x7f8fb6a69000, 2093056, PROT_NONE) = 0
mmap(0x7f8fb6c68000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f8fb6c68000
close(3)                                = 0
open("/usr/local/lib/libdrm.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\2403\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=203103, ...}) = 0
mmap(NULL, 2145224, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb6858000
mprotect(0x7f8fb6863000, 2093056, PROT_NONE) = 0
mmap(0x7f8fb6a62000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa000) = 0x7f8fb6a62000
close(3)                                = 0
open("/usr/local/lib/libxcb.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libxcb.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P\223\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=121232, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f8fb84d5000
mmap(NULL, 2216528, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb663a000
mprotect(0x7f8fb6657000, 2093056, PROT_NONE) = 0
mmap(0x7f8fb6856000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1c000) = 0x7f8fb6856000
close(3)                                = 0
open("/usr/local/lib/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libm.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0pU\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1030512, ...}) = 0
mmap(NULL, 3125544, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb633e000
mprotect(0x7f8fb6439000, 2093056, PROT_NONE) = 0
mmap(0x7f8fb6638000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xfa000) = 0x7f8fb6638000
close(3)                                = 0
open("/usr/local/lib/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/librt.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340!\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=31752, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f8fb84d4000
mmap(NULL, 2128984, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb6136000
mprotect(0x7f8fb613d000, 2093056, PROT_NONE) = 0
mmap(0x7f8fb633c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f8fb633c000
close(3)                                = 0
open("/usr/local/lib/libXau.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libXau.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220\r\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=10328, ...}) = 0
mmap(NULL, 2105600, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb5f33000
mprotect(0x7f8fb5f35000, 2093056, PROT_NONE) = 0
mmap(0x7f8fb6134000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f8fb6134000
close(3)                                = 0
open("/usr/local/lib/libXdmcp.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libXdmcp.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220\20\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=22504, ...}) = 0
mmap(NULL, 2117760, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f8fb5d2d000
mprotect(0x7f8fb5d32000, 2093056, PROT_NONE) = 0
mmap(0x7f8fb5f31000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f8fb5f31000
close(3)                                = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f8fb84d3000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f8fb84d2000
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f8fb84d0000
arch_prctl(ARCH_SET_FS, 0x7f8fb84d0740) = 0
mprotect(0x7f8fb7230000, 16384, PROT_READ) = 0
mprotect(0x7f8fb5f31000, 4096, PROT_READ) = 0
mprotect(0x7f8fb6134000, 4096, PROT_READ) = 0
mprotect(0x7f8fb7977000, 4096, PROT_READ) = 0
mprotect(0x7f8fb633c000, 4096, PROT_READ) = 0
mprotect(0x7f8fb6638000, 4096, PROT_READ) = 0
mprotect(0x7f8fb6856000, 4096, PROT_READ) = 0
mprotect(0x7f8fb6a62000, 4096, PROT_READ) = 0
mprotect(0x7f8fb7b7f000, 4096, PROT_READ) = 0
mprotect(0x7f8fb80c8000, 4096, PROT_READ) = 0
mprotect(0x7f8fb6c68000, 4096, PROT_READ) = 0
mprotect(0x7f8fb6e79000, 4096, PROT_READ) = 0
mprotect(0x7f8fb7450000, 4096, PROT_READ) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f8fb84cf000
mprotect(0x7f8fb7753000, 32768, PROT_READ) = 0
mprotect(0x7f8fb7d95000, 4096, PROT_READ) = 0
mprotect(0x7f8fb82d3000, 4096, PROT_READ) = 0
mprotect(0x7f8fb8743000, 12288, PROT_READ) = 0
mprotect(0x7f8fb84f7000, 4096, PROT_READ) = 0
munmap(0x7f8fb84d9000, 111484)          = 0
set_tid_address(0x7f8fb84d0a10)         = 20976
set_robust_list(0x7f8fb84d0a20, 0x18)   = 0
futex(0x7fffab48f88c, FUTEX_WAIT_BITSET_PRIVATE|FUTEX_CLOCK_REALTIME, 1, NULL, 7f8fb84d0740) = -1 EAGAIN (Resource temporarily unavailable)
rt_sigaction(SIGRTMIN, {0x7f8fb7766750, [], SA_RESTORER|SA_SIGINFO, 0x7f8fb776fcb0}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0x7f8fb77667e0, [], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7f8fb776fcb0}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY}) = 0
brk(0x7f8fba034000)                     = 0x7f8fba034000
futex(0x7f8fb775de8c, FUTEX_WAKE_PRIVATE, 2147483647) = 0
futex(0x7f8fb775de98, FUTEX_WAKE_PRIVATE, 2147483647) = 0
futex(0x7f8fb7b800b0, FUTEX_WAKE_PRIVATE, 2147483647) = 0
open("/usr/local/lib/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
close(3)                                = 0
open("/lib/x86_64-linux-gnu/tls/x86_64/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu/tls/x86_64", 0x7fffab48e180) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/tls/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu/tls", 0x7fffab48e180) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/x86_64/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu/x86_64", 0x7fffab48e180) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/usr/lib/x86_64-linux-gnu/tls/x86_64/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/tls/x86_64", 0x7fffab48e180) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/tls/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/tls", 0x7fffab48e180) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/x86_64/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/x86_64", 0x7fffab48e180) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu", {st_mode=S_IFDIR|0755, st_size=36864, ...}) = 0
open("/lib/tls/x86_64/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/tls/x86_64", 0x7fffab48e180) = -1 ENOENT (No such file or directory)
open("/lib/tls/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/tls", 0x7fffab48e180)        = -1 ENOENT (No such file or directory)
open("/lib/x86_64/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64", 0x7fffab48e180)     = -1 ENOENT (No such file or directory)
open("/lib/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/usr/lib/tls/x86_64/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/tls/x86_64", 0x7fffab48e180) = -1 ENOENT (No such file or directory)
open("/usr/lib/tls/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/tls", 0x7fffab48e180)    = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64", 0x7fffab48e180) = -1 ENOENT (No such file or directory)
open("/usr/lib/libsample_plugin_opencl.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib", {st_mode=S_IFDIR|0755, st_size=36864, ...}) = 0
fstat(1, {st_mode=S_IFCHR|0620, st_rdev=makedev(136, 5), ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f8fb84f4000
write(1, "\n", 1
)                       = 1
write(1, "Return on error: error code 1,\t/"..., 155Return on error: error code 1,      /home/dspuser/Downloads/IntellMediaSDK/MediaSamples_Linux_6.0.160431 75.175/samples/sample_encode/src/sample_encode.cpp      656
) = 155
exit_group(1)                           = ?
[release] $
Jiandong_Z_Intel
Hi Medwin,
Zachary
MyMother
hi, Zachary
   By the above recommendation, we can do that ~ Wow. Many thanks ~ ^^y
   And it looks like -angle and -opencl are independent function ~
[release] $ ./sample_encode_x11 h264 -i 1080p.yuv -o 1080p_enc.264 -w 1920 -h 1080 -angle 180 -opencl -hw -vaapi
Info: try to open file (ocl_rotate.cl) in the current directory
info: using GPU OpenCL device with media sharing extension
Pipeline with rotation plugin
NOTE: Some of command line options may have been ignored as non-supported for this pipeline. For details see readme-encode.rtf.
Output video            AVC
Source picture:
        Resolution      0x0
        Crop X,Y,W,H    0,0,0,0
Frame rate      30.00
Bit rate(Kbps)  3757
Memory type     d3d
Media SDK impl          hw
Processing started
Frame number: 635
Processing finished
[release] $ ./sample_encode_x11 h264 -i 1080p.yuv -o 1080p_enc.264 -w 1920 -h 1080 -angle 180 -hw -vaapi
Output video            AVC
Source picture:
        Resolution      0x0
Frame rate      30.00
Bit rate(Kbps)  3757
Memory type     d3d
Media SDK impl          hw
Processing started
Frame number: 635
Processing finished
[release] $
Jiandong_Z_Intel
Hi Medwin,
Great to know it works for you. just want you know, we can find following in readme-encode.pdf
-angle 180 Invokes sample plug-in for 180 degrees picture rotation.
CPU implementation is used by default. Rotate plugin module
sample_rotate_plugin.so must be available when running the application with
this option.
-opencl Invokes Intel® OpenCL™ implementation of 180 degrees picture rotation. Rotate
plugin module libsample_plugin_opencl.so must be available. File
ocl_rotate.cl must exist in the local folder when running the application with this
option.
Zachary
Jiandong_Z_Intel
Hi Medwin,
I am closing this thread, please feel free to start new post if you have other questions.
Zachary
