Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
2935 Discussions
sample_decode.exe -hw can't work in Media SDK 2012 32/64bit installation on win7 64bit system
PAUL_Y_Intel
This is the command line:
sample_decode.exe h264 -i sample.h264 -o sample_hw.yuv -hw
There are three environments under test:
1. Media SDK 2012 32bit installation on Win7 32bit system.
2. Media SDK 2012 32bit installation on win7 64bit system.
3. Media SDK 2012 64bit installation on win7 64bit system.
The hardware decode testcase works on case (1), but it fail in case (2) and case (3).
Return on error:error code -3, pipeline_decode.cpp line 388.
it is MFX_ERR_UNSUPPORTED from MFXInit.
By the way, software decode in all 3 cases are all ok by following command line:
sample_decode.exe h264 -i sample.h264 -o sample_sw.yuv
System:
Intel i5-2515E with 8GB RAM
Windows 7 Ultimate SP1 32/64 bit english
Intel Media SDK 2012 build 3.0.014 Gold
Eric_S_Intel
Can you try an update the graphics driver on the failing systems? The hardware support is packaged with the drivers, and it looks like sample_decode cannot find the DLL.
Eric
PAUL_Y_Intel
Dear Eric,
I've exhausted all Window updates, can you specify thename and version of these DLLs used in decoding scenario in 32/64 bit installations on 64-bit win7 systems? Thanks a lot!
Br,
Paul
Eric_S_Intel
Hi Paul,
I am sorry but I learned just recently that the drivers on Windows update do not carry the Intel Media SDK in the package. Instead, I would recommend downloading them via downloadcenter.intel.com.
The DLL that sample_decode is searching for should be located in this location: C:\Program Files\Common Files\Intel\Media SDK\s1\2.0 (or something similar depending on your platform and version)
The sample is using the standard dispatching process. Its checking [HKEY_LOCAL_MACHINE\SOFTWARE\Intel\MediaSDK\Dispatch\hw64-s1-1] to see the location
Of the DLL, then loads it. Please verify the path and registry keys are present, if they are not then please download and install the driver off intel.com.
-Eric
PAUL_Y_Intel
Hi Eric,
This is really useful information. For my current MediaSDK 2012 installation, neither the registry key nor the DLL fileexist in 64-bit windows 7 system.But they did exist in 32-bit Windows 7 system. This explains the HW decode works on 32-bit system but can't work on 64-bit system.
Then on the 64-bit Windows system. I uninstall MediaSDK 2012 and re-install all MediaSDKreleases I collected {2.0 Gold,3.0beta 3, 2012, 2012 R2 } x {32-bit msi, 64-bit msi }, from the oldest release on. And in each run I check out the existence of both the registry key and the DLL file. No, they never appears....
Then on the same HW, I useclean 32-bit Windows 7 system to install 2.0 Gold. At the first time the registry key and the DLL appear.
I tested 32-bitMediaSDK on 32-bit system since Sep/2011.Maybe I'd better startedtesting 64-bit version earlier.
Paul
