sample_full_transcode , Video is not converted properly using Hardware acceleration.
Ram_S_
HI,
 On going through sample_full_transcode provide @ https://software.intel.com/sites/default/files/MediaSamples_Windows_5.0.491.98719.msi
I observed trancoding video is good with Software acceleration, on providing hardware acceleration option video is not converted properly facing lot issue.
Please find the information below:
System info:
    CPU:    Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
    OS:    Microsoft Windows 7 Enterprise
    Arch:    64-bit
Intel(R) HD Graphics                         9.17.10.3517        Active
Commandline : sample_full_transcode.exe -i "c:\1\Sample.mp4" -o c:\1\out.m2ts -v:b 1000 -acodec:copy -hw
player used : VLC
Issue nature : after completing in transcode using hardware acceleration , on opening file in VLC player progress status of video is end, if we try fast forward video getting struct and only i am able to hear audio no video seen. Note: Same issue is not happening when i used software acceleration in command line.
Also attaching media analyzer log and snapshot off issue in attachment.
Surbhi_M_Intel
Hi Ram,
I have checked it on my system(i5-4300U) and I didn't see any issue with HW. From your analyzer logs it seems that HW is not supported from API version 1.5, can you please query which version is being used?
Also you are using a 2nd generation system, due to which it is possible that it would not support MSDK capabilities completely.
-Surbhi
Surbhi_M_Intel
Hi Ram,
Thank you for reporting the issue. Unfortunately, we are not able to download the system analyzer, can you please upload it again. Also can you please download latest drivers from downloadcenter.intel.com. It can might be a driver issue. Please let us know your results with latest driver.
-Surbhi
Ram_S_
@ SURBHI - I have attached "mediasdk_sys_analyzer" log now.
Note : This is also reproducible in other system also[so far i have tested the sample in three machine]
mediasdk_sys_analyzer Log:
Intel Media SDK System Analyzer (64 bit)
The following versions of Media SDK API are supported by platform/driver:
    Version    Target    Supported    Dec    Enc
    1.0    HW    Yes        X    X
    1.0    SW    Yes        X    X
    1.1    HW    Yes        X    X
    1.1    SW    Yes        X    X
    1.3    HW    Yes        X    X
    1.3    SW    Yes        X    X
    1.4    HW    Yes        X    X
    1.4    SW    Yes        X    X
    1.5    HW    No
    1.5    SW    Yes        X    X
    1.6    HW    No
    1.6    SW    Yes        X    X
    1.7    HW    No
    1.7    SW    Yes        X    X
    1.8    HW    No
    1.8    SW    Yes        X    X
Graphics Devices:
    Name                                         Version             State
System info:
    Arch:    64-bit
Installed Media SDK packages (be patient...processing takes some time):
    Intel® Media SDK 2014 R2 for Clients (x64)
Installed Media SDK DirectShow filters:
Installed Intel Media Foundation Transforms:
  Intel® Hardware VC-1 Decoder MFT : {059A5BAE-5D7A-4C5E-8F7A-BFD57D1D6AAA}
  Intel® Hardware H.264 Decoder MFT : {45E5CE07-5AC7-4509-94E9-62DB27CF8F96}
  Intel® Hardware MPEG-2 Decoder MFT : {CD5BA7FF-9071-40E9-A462-8DC5152B1776}
  Intel® Quick Sync Video H.264 Encoder MFT : {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}
  Intel® Hardware Preprocessing MFT : {EE69B504-1CBF-4EA6-8137-BB10F806B014}
Analysis complete... [press ENTER]
Ram_S_
Any update.
Is it happening only in my system or any known issue with sample code.
If any of you have faced the same issue. please do share your thought.
RAM
Surbhi_M_Intel
Hi Ram,
-Surbhi
Ram_S_
I have also tested on haswell[4th Genration ] system and the sample is working fine and use API version 1.7
where as in 2nd and 3rd Generation it use API version 1.4 only, so this might be reason for the issue.
still i am doing lot of testing :)
@Surbhi thanks for the information.
RAM S
Surbhi_M_Intel
Great you got it working on the 4th generation! Thanks for this info.
-Surbhi
